Results 1 to 6 of 6
    '12 Cannondale Trail SL 3R Crank and EBB Question
    I've swapped around nearly all the components since picking up the bike last year to suit my personal tastes and the crank is the last thing I'd like to upgrade. I've tried contacting Cannondale for specifics on the eccentric bottom bracket and they pass me off to my local dealer, who in turn, isn't willing to give up information without purchasing a crank from them before hand.
    Anyhow, I'm looking to swap out the Truvativ Isoflow 1.0G with Tange LN-3912 bottom bracket for a Shimano XT or XTR SS modded setup. I haven't been able to find any information on the type of eccentric bottom bracket the bike came with to see if it'll work with the Shimano or if it won't, what type of eccentric bottom bracket I need to go with so it will be compatible. It's also not clear whether or not my frame is a pressfit 30 style either.
    Does anyone know if the stock eccentric bottom bracket will work with Shimano or if not, what type of replacement eccentric I need to make it work?
    I thought that was a BB30 bottom bracket with an eccentric adapter in it. Bit I could be wrong
    The bottom bracket is a BB30 attached to a separate EBB. I'm just not sure if the EBB is a standard or press fit 30.
    Reputation: BoostN7's Avatar
    Dec 2010
    Get a new dealer. They should help you out!
    and no, I am not missing the other half of my fork....
    Dec 2011
Size:  36.4 KBI went with a new Bushnell EBB and the Shimano SLX M660-10 (modified) crank and have and no issues. My rig is the 2011 SL3 Trail 9ner. The bottom bracket threaded into the new EBB like any normal frame.
    Thanks for the info! I was just about to order a bushnell to see if it'd work.
  1. '12 Cannondale Trail SL 3R Crank Question
    By redrock_z71 in forum Singlespeed
    Last Post: 03-11-2013, 10:32 AM
  2. 2011 cannondale trail sl3 vs 2012 cannondale trail 5
    By idon'tlikepink in forum Beginner's Corner
    Last Post: 08-22-2012, 07:56 AM
  3. Cannondale crank on bsa frame
    By mikemax99 in forum 29er Components
    Last Post: 04-25-2012, 08:47 AM
  4. prob with my cannondale f5 crank
    By jimmy1981 in forum Cannondale
    Last Post: 09-20-2011, 05:17 PM
  5. GXP1 Cannondale Crank help..
    By neoison in forum Cannondale
    Last Post: 07-23-2011, 04:03 PM
