Results 1 to 3 of 3
    09 Taurine and 2x9 set up
    A friend picked up a Taurine 1 and wants to go 2x9.
    He'd like to keep the stock crank and us Blackspire rings in the small(64) and middle (104)positions and use 28ish/40ish rings.
    If using the stock crank and using a bigger ring in the granny position...what is the biggest ring that will fit inside the chainstay?( it looks tight in there)
    Or...has anyone put a XX BB30 crank on a Taurine? What Q factor and ring size did you go with?
    I have a Cannondale Carbon Si crankset. 28t on the small 64 and 38 on the middle 104.
    It works without hitting the aluminium chainstay protector. You can buy some BB30 spacers if you want more space. The spacers look like THIS.
