Results 1 to 3 of 3
    Nov 2008
    08 Carbon Team Rush Bb30 Help
    Can I use a standard BB on this frame or does it need the bb30 FROM cDALE. Also do they make an adaspter for the bb30 where can I get it???
    Reputation: jason.R's Avatar
    You can run any BB30 crank. There are a few companies that make bb30 now, not just cannondale. And you can run a standard bottom bracket, you will just need an adapter. It glues into the frame and has threads to use a standard bb. The cranks or adapter should be available at your local bike shop. If not in stock, they can order it.
    Jan 2005
    I just removed the adapter from my frame so that I could install an Extralite E- Bones BB30 crankset. It was easy to press it out of the frame. It doesn't seem like Cannondale used any type of adhesive or locktite to hold it in place. It's in mint condition and I have no further use for it if you're looking for one.
