Results 1 to 2 of 2
    Apr 2013
    ┐Fox Float RP23 Low Volume 2012 + prophet?
    Hi, now i have a 200x57 dhx 5.0 2007 and i want an air shock to lose weight. I have found a Fox Float RP23 Low Volume 2012 (200x51)
    Is true that prophet needs a low volume can? Is it the correct for the prophet?
    That is the correct eye to eye and stroke 200x50. I had that on my Prophet.
    As for the low vol can,
    You are correct on the prophet needing that. If you run the higher one, you will blow through the travel too fast. If you then tweak the pressure, the ride gets harsh.
    Lead by my Lefty............... right down the trail, no brakes.
  1. RP23 High Volume Air Sleeve
    By FR Wannabe in forum Ibis
    Last Post: 08-15-2012, 11:48 PM
  2. Where to buy RP23 volume reducer kit and seal kit?
    By veryavgwhtguy in forum Shocks and Suspension
    Last Post: 06-27-2012, 09:14 AM
  3. What is the volume of the air canister on RP23?
    By masm71 in forum Shocks and Suspension
    Last Post: 03-21-2012, 04:22 AM
  4. RP23 Volume Kit for F'bird
    By half_man_half_scab in forum Pivot Cycles
    Last Post: 10-17-2011, 07:50 PM
  5. RP23 for Prophet
    By mickeydesadist in forum Cannondale
    Last Post: 05-15-2011, 05:56 PM
