Results 1 to 12 of 12
    yelli rear tire width check
    How wide of a rear tire are you running on the rear wheel? I am considering the Ardent 2.4 for the front but not sure if I should go 2.25 or 2.4 on the rear. Any suggestions are helpful
    Steel is Real
    I run an Ardent 2.4 on Stan's Flow with no probs at all, plenty of clearance.
    Reputation: gulljammer's Avatar
    Oct 2010
    I run Hans Dampf's front and rear on Canfield' rims with no real issues. Occasional rub if I lay the bike down hard thru a turn at speed, but no big deal.
    neg rep for contributing to thread deterioration and posting useless comment. - wadafuq.
    www.fattiremassive.com
    Nov 2012
    I just put a GEAX sturdy 2.3 in there and there is clearance but man does it look tight to me but i'm not a pro. perhaps the geax run big?
    May 2014
    Reviving an old thread, but are any of you running 2x or 3x up front or all 1x? Thanks.
    Nov 2012
    I was running 3x up front until a couple months ago
    Now 1x
    Its worth noting that I was able to run a front derailleur and a 2.4 ardent on my first gen frame but not on the frame I got about a year ago (2nd gen?). I would not call the tire clearance ample but its fine unless its really muddy. I'm talking super thick and sticky mud that you should never be riding in.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Re: yelli rear tire width check
    I had a 2.4 Specialized Purgatory on mine. No issues
    No moss...
    Cracker
    Reputation: thecrackerasscracker's Avatar
    Seems like tire clearance is not the same on all the frames they have produced
    It might get a little steep from here
    The White Jeff W
    My Yelli is a 1st gen
    No moss...
    Reputation: savo's Avatar
    I've a 2011 (1st gen for sure) with plenty of clearance for an Ardent 2.4 on a P35 rim... I'm thinking of swithcing to Velocity Duallys...
    what are the changes in the 2nd gen yellis?
    May 2014
    Other than apparently a little less rear tire clearance discussed here, the frame material changed from 7005 to 6061 aluminum for 2013/14 which apparently was for anodizing purposes. I'm not aware of any other changes from my reading.
