Results 1 to 2 of 2
    yelli front der adjustment
    My new Yelli has an XO front der (direct mount of course) that isn't parallel with the rings, It is a 2x10 set up and with the current situation I can't adjust it so it shift like it should. What should I do barring eliminating the front der?
    Reputation: Joules's Avatar
    That high-direct mount that the Yelli uses, I don't think any angular adjustment is possible.
    If the derailleur cage isn't lining up, I believe that means either something is wrong with the derailleur, or the mount on the frame is out of alignment. How far out is it? Can you post a picture?
