Results 1 to 3 of 3
    Jul 2013
    What lenght Reverb dropper poust for XL The One?
    Hi!
    Im hurry about my order from German, it will leave monday so I still have time to add reverb dropper poust. So it has to 30,9 125mm drop. Just dont know which lenght would be best for XL frame, 355,380 or 420? Im 191 cm tall and inseam is 90 cm.
    Kratos
    Hi Kratos-
    At your height (6'2"), you can get by with any size really. I'd recommend 380 or 420mm post. You will have plenty of seat post insertion on an XL frame and still have more than enough adjustment range.
    Quote Originally Posted by gollub01 View Post
    Hi Kratos-
    Agreed.
    Also, the drop length is the same on all of them, so only the post size is different. This means the different lengths will only vary the amount of post that you can have inserted into the seat tube. At 6'0 and on a large, I only have about 1.5" of seat tube exposed (in the lowest position) and that is more than enough. At full extension with that my leg is almost fully extended, perfect pedal strokes!
    Aaand...
    The Reverb Stealth works well with THE ONE, here is a write up I did on that.
  1. Replies: 34
    Last Post: 05-16-2016, 10:12 AM
  2. Trek Fuel EX and Reverb dropper post cable routing
    By GTMile in forum Bike and Frame discussion
    Last Post: 08-08-2013, 05:05 PM
  3. reverb dropper post question
    By jgutz71 in forum General Discussion
    Last Post: 07-07-2013, 03:13 PM
  4. Rock Shox Reverb Stealth Dropper Seatpost
    By maw77712 in forum General Discussion
    Last Post: 05-30-2013, 05:33 AM
  5. Reverb/Dropper Post on a Tallboy
    By Ike Turner in forum Santa Cruz
    Last Post: 11-09-2011, 08:03 PM
