Results 1 to 11 of 11
    Mar 2013
    Want to build a Yelli Screamy - What parts can I swap over from my current bike?
    I am wanting to build up a Yelli Screamy and would like to know what parts I can swap over from my old bike and what additional parts I will need to complete the build. I am planning on purchasing a 140mm fork to go along with the new frame.
    Here is what I currently have:
    Fork RockShox Reba RL 29 w/Lock-Out, tapered steer, 100mm
    Headset Ahead Sealed Cartridge 1 1/8" to 1.5" tapered
    Brake Levers Avid Elixir 7
    Brakes Avid Elixir 7 Hydraulic Disc
    Rotors Avid 180mm front, 160mm rear
    Shifters SRAM X-7 2x10
    F Derailleur SRAM X-7 2x10
    R Derailleur SRAM X-7 2x10 Mid-Cage
    Cassette SRAM PG-1050 11-36T 10-Speed
    Chain SRAM Powerchain 1051
    Crank SRAM X-7 2x10, 38/24 rings
    Bottom Bracket SRAM XR GXP Sealed BB
    Pedals NONE
    Rims WTB SpeedDisc I-19 Alloy Double-Walled with eyelets
    Hubs KT HiFlange Sealed Bearing 32H
    Spokes Black 14g Stainless
    Tires GEAX AKA 2.2"
    Handlebar AIRBORNE Alloy Flat, 640mm width
    Stem AIRBORNE Alloy +/- 7 Degree Rise, size specific
    Saddle Selle San Marco Ponza Power
    Seat Post AIRBORNE Alloy 31.6mm Diameter, 350mm Length
    I am trying to keep costs to an absolute minimum so the more I can swap the better! Also, if anyone wants to help with an additional question - what 140mm fork deals are there out there?
    Jul 2013
    Is your fork thru axle? Are the hubs thru axle compatible? If it's not it's gonna be hard finding a 140mm fork with a standard qr
    Mar 2013
    I would really like to have 15mm or 20mm axle.. so this would be cause for additional parts. Based on that info, what all would I NEED in order to complete the swap?
    Jan 2014
    everything should swap over. You could bump the Reba up to 120mm and spend almost nothing except for some shock oil, shifter cable housing and BB spacers. The 2X drivetrain will take a little time to get setup.
    Reputation: eurospek's Avatar
    You'll need a new seatpost. Yelli's 30.9.
    konahonzo
    MakinMoves - Glad you are stoked on the Yelli!
    Looking at your list you will need:
    30.9 Seatpost
    35.0 Seatpost Clamp
    I can tell if your Front Derailleur is a direct mount, Sram HO series or not. If not, you will need one.
    Confirm that your current wheel is a 135x10 QR.
    That should be about it to get you rolling. Feel free to give us a call with any other build questions.
    Cheers!
    Oct 2013
    I Just took advantage of price points sale on tower pro 140mm for $250!!
    Can't wait to get it
    Follow my MTB blog...
    http://cdmountain.blogspot.com
    Mar 2013
    Quote Originally Posted by KillingtonVT View Post
    30.9 Seatpost
    35.0 Seatpost Clamp
    Cheers!
    Thanks for the reply!! I definitely will!
    I saw that manitou for $250 a couple days ago too! Went back and forth on it.. May have to revisit!
    I have the Tower Pro 120mm 15qr on my Yelli and I love it. That being said, I picked up the 140 as well. Haven't made the switch yet, hopefully this weekend.
    Oct 2013
    Quote Originally Posted by cbd5600 View Post
    Good to hear...for the price i was wondering if it was too good to be true...any tips/advice on tuning or making adjustments to the fork?
    There is a huge thread on the tower pro in 29er components. For me I have the rebound set midway and I run ~110 PSI.
  1. The Help me Build a Yelli Screamy thread
    By SundayRiverRider in forum Canfield
    Last Post: 06-06-2015, 05:49 AM
  2. My First-ever Build: Yelli Screamy
    By Gouda Cheez in forum Canfield
    Last Post: 03-09-2015, 02:47 PM
  3. Canfield Bros 'Yelli Screamy' build
    By FatTireGoose in forum 29er Bikes
    Last Post: 08-09-2013, 04:30 AM
  4. Build up RDO Jet 9 OR swap parts over from current Jet 9
    By Radical Rad in forum Niner Bikes
    Last Post: 03-04-2013, 06:17 PM
  5. Good Donor Bike for Yelli Screamy Build-up?
    By MadMalibu in forum Canfield
    Last Post: 12-28-2012, 08:11 AM
