Results 1 to 12 of 12
    Oct 2013
    Too many chainring choices!!!
    I can't choose....
    I'm building a 1x10 setup Yelli and have a X9 (2x) crank. Removing spider and rings and going with direct-mount ring. I don't want to run any sort of chain guide; so far, i've considered:
    MRP Bling ring - no narrow/wide teeth?
    Absolute Black - any reviews? real world experience?
    Wolftooth - pricey but so far best solution.
    Any help/suggestions/experience would be greatly appreciated.
    Thanks in advance!
    Follow my MTB blog...
    http://cdmountain.blogspot.com
    I am running a 32T bling ring on an X9 crank on my Yelli and it is very tight.
    Here's a pic to give you an idea how snug it is.
    Oct 2013
    ok, I was under the assumption that 30t was the biggest you could fit on the yelli. If you don't mind me asking what swayed you to go with the bling ring vs the others? how do you like the 32t? plan on sticking with that size? thanks.
    I had it setup on my previous bike and just moved it over to my Yelli. At the time there were very few options for a direct mount chainring so I was limited. There have been no issues at all with the setup.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Im using a X9 crank/North Shore Billet 26t on my Kona 29er with an 11/36 10 speed cassette. I am running a chain guide so thats no help to you but I just wanted to comment that I do like the gearing. 26/36 gives me a reasonable climbing gear and 26/11 is all the high end I need for this bike.
    FWIW I did ride it a couple times without the guide and didn't drop the chain, but I had it so I put it on for insurance.
    No moss...
    Reputation: Banjopickin's Avatar
    You cant run a Race Face N/W 32t?
    Im building my yelli up and planned on running my SLX crank with a 32 Race Face N/W. Ran it on my nomad with a XT shadow+ with zero chain drop...not even chain slap.
    Reputation: riiz's Avatar
    Quote Originally Posted by Banjopickin View Post
    You can, I ran a Wolftooth 30t and Sram Type x9 RD, no issues.
    Quote Originally Posted by cbd5600 View Post
    That's a lot more clearance than I have on my YS with a 32t Raceface N/W on a turbine crankset, and I've never had problems. . I went 32T Wolftooth + X9 on a SS Nimble9 build, I should be finishing up later this week. I wanted N/W in case I'm too weak for SS and have to put gears on it. And because my LBS had one in stock. Buying US made and local made it worth the extra bucks. Wolf tooth quality is also top notch, not to say MRP is not.
    "You can't drink all day if you don't start in the morning." ShakyPuddin
    Oct 2013
    Pretty sure I'll be going with the Wolftooth...now just need to convince myself either 30t or 32t.....
    Reputation: Gouda Cheez's Avatar
    Feb 2013
    Minimal difference between the two really. What cranks are you running? I know there are some limitations / modifications that need to happen with some cranks and the 32T.
    I opted for a 30T because I climb often.
    Quote Originally Posted by riiz View Post
    Good. Hope those extra 2 teeth dont cause any problems. Worst case scenario I space out the BB a little bit.
  1. Choices, Choices, Choices... Could you help me find the right one?
    By AKnRDR in forum Videos and POV Cameras
    Last Post: 11-05-2013, 08:02 PM
  2. Replies: 38
    Last Post: 10-15-2013, 06:29 AM
  3. 1x9 chainring choices
    By Dr.Mushy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-25-2013, 02:34 PM
  4. September 30th races... choices, choices...
    By Empty_Beer in forum California - Norcal
    Last Post: 09-26-2012, 09:59 AM
  5. Going 1X10....questions about chainring choices, chain guide vs. bash guard
    By trumpus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2011, 06:29 AM
