Results 1 to 2 of 2
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    stealth routed '13 N9
    so long story short, broke an external routed dropper a year ago, been riding a fixed post since. found a good deal on a lev, but it was integra then i had an , just mod the frame. the frame is straight wall 4130 so i figure this idea is feasible and i ordered the dropper. came home after a ride on friday and the lev was sitting at my door. modifications began instantly.
    1st step was to source o-rings from cheapo depot. i used 2) 3/8" round and 1) 1/2" round. took my caliper and smashed one down until i could somewhat easily install the cable housing while still being snug. the routing would start just behind the ht on the dt located a 1/2" off the 1st housing guide used for rear brake. then out the dt on the nds and into the st. well the 2nd hole started off as a 3/8, but quickly turned to the 1/2" due to the fact there was a slim chance i could retrieve the housing from in the dt. i ended up setting up the saddle and while seeing people having probs with the top plate and the cone nuts, i torqued the bolts and hit em hard with green loctite, probably won't help but it's all i have. setting up the trigger as intended just felt awkward and the noodle is too exposed. so i flipped it over and although it still looks awkward it's a better fluid motion for me and the noodle gets tucked up in the brake lever . time will tell if this "mod" was a good idea or not.
    tools used:
    2# hammer
    center punch
    tape
    1/8" and 1/4" drills
    dremmel with deburring bit
    dental floss - pulling housing through dt
    boot lace - pulling housing up st
    shop vac for sucking up swarf from bb and getting laces and floss through frame
    chillum
    tequila
    good tunes
    Attached Thumbnails Attached Thumbnails stealth routed '13 N9-20170415_085737.jpg
    en den
    Attached Thumbnails Attached Thumbnails stealth routed '13 N9-20170415_203331.jpg
  1. Replies: 17
    Last Post: 04-16-2015, 11:07 PM
  2. Stealth Routed Droppers
    By beammescotty in forum All Mountain
    Last Post: 12-13-2014, 07:30 PM
  3. Getting re-routed to the Osprey Site
    By discombobulated_conundrum in forum Site Feedback/Issues
    Last Post: 04-30-2013, 06:04 AM
  4. Fantom29s: why are the cables routed on top of the top tube?
    By Things and Stuff in forum Motobecane
    Last Post: 08-09-2012, 10:38 AM
  5. Internally routed cables
    By def156 in forum Frame Building
    Last Post: 03-18-2011, 03:00 PM
