Results 1 to 3 of 3
    May 2010
    Shimano bottom bracket on Riot
    Quick question for those running a Shimano bottom bracket and cranks on a Riot: are you using BB spacers- where? What kind of chainring are you running?
    Boost or 142 wheels?
    How is your chainline looking?
    Okay- a lot of questions.
    This is my first frame up build.
    I'm running boost wheel, shimano BB with 1 drive side spacer, a oneup oval 32. By eyeballing the chainline looks too far towards the high gears on the cassette (small cogs). Definitely does not look centered.
    Start by taking out that BB spacer?or trying one of the shimano boost chain rings that came with the build kit?
    Oct 2015
    I bought some 1mm spacers and fine tuned the spacing so the chain ring was 3mm from the chainstay. I also put one of them on the cassette (same size) works good enough to not have any backpedaling issues.
    Since moved to a Sram crank and it's better with the direct mount and easier to find tune.
    I am running xt m8000 non boost cranks with 1 spacer on the drive side. 142 x 12 rear. I get a much better chain line using a Oneup m8000 offset chainring. The chainring is oval and I donít know if they make a round version or if it matters to you.
  1. Replies: 3
    Last Post: 12-16-2016, 11:49 AM
  2. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  3. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  4. Bottom Bracket Spacers - Upgrade from Shimano FC-M542 to Chris King
    By noynek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-03-2011, 09:11 AM
  5. Hole in bottom of frame on bottom bracket?
    By concrete sledge in forum General Discussion
    Last Post: 05-03-2007, 11:45 PM
Members who have read this thread: 28
