Results 1 to 3 of 3
    dft
    dft is offline
    Reputation: dft's Avatar
    seat adjustment with the One
    How much can you drop the seat with 2012 the One for a medium frame?
    What is the absolute most that is can be dropped? I'm hopping enough for full climbing and descending.
    I use a 5" dropper post and, at least for me, that is the perfect amount. Fully depressed I sit right where I want to be for steep DH, and fully extended puts me up in the XC pedal range.
    I can safely say you'd have at least 6" of post adjustment, which should be enough for most.
    dft
    dft is offline
    Thanks. Yea I want to use a non-dropper post and like to drop 6 inches for the steeps, etc. I'm fairly light, so I can go 1/2-3/4 inch less than the minimum lines on the seat tube if I need to.
