Results 1 to 25 of 25
    Aug 2010
    Riot chainring clearance
    Mocking up my new Riot and wondering what acceptable clearance is for front chainring/chain stay?
    My caliper says about 5mm. Iím running Canfield cranks, Canfield/GXP BB with one spacer in drive side, and 30T SRAM Xsync spider/chainring which from what I can tell is 6mm standard offset.
    Mar 2015
    Quote Originally Posted by racefit View Post
    Itís going to sound counter intuitive, but you need to get rid of that drive side spacer to properly install cranks with a gxp bottom bracket. I destroyed two bottom brackets before learning this lesson; that spacer isnít actually moving the chainring out from your chainstay.
    Aug 2010
    Quote Originally Posted by mothertruckinsteve View Post
    Iím not the expert on GXP BBís, but Iíve run SRAM cranks and GXP BBís on my bikes for the last 5 years. All had 1 driveside spacer and theyíve all been flawless. IIRC SRAM shows spacers as an option for install.
    As far as moving the chainring out I canít see how it wouldnít. It would just shorten the available spindle interface on the NDS no?
    EDIT: Here are the install instructions from Canfield for their crank and BB. It seems you donít NEED spacers, but itís allowable as an option. It also seems you can decrease chainring clearance by adding a spacer to the NDS. If this is true you would shorten the available spindle space on the NDS by the same amount as doing it on the DS, no? Am I missing something?
    Mar 2015
    Iím not an expert on them either, but my understanding is they there is some float on the bearings and those spacers adjust that as opposed to the position of the chainring, it may be appropriate or needed on some frames but the Riot is not one of them.
    In my experience running Canfield cranks on a riot that spacer will cause one of two things to happen. Either the left crank arm will loosen and fall off in the middle of your ride, or it will tighten and annihilate the bottom bracket cups and seals. Neither of which are much fun to deal with
    Aug 2010
    Two of the most respected LBSís locally actually recommended using a DS spacer on previous builds. One saying he always uses one.
    Not trying to prove my point, just expressing my experiences and understand my options.
    If I did decide to go without a spacer, my chainring would be that much closer,2.5mm with my caliper. Things would be getting tight at that point and it makes me think I should go with a 3mm chainring to gain back some clearance. Having said that, Iíve had some VERY tight clearances on some Nimbles 9s and never had a problem.
    Mar 2015
    Iím just trying to save you troubles that I went through when building up the same frame with the same cranks. The Bros also weighed in on this topic in the main forum thread about the Riot and said their cranks should be run without spacers on the Riot. You can call/email them to confirm.
    After multiple frustrating rides with crank arms falling off and bottom bracket cups destroyed I removed said spacer from the equation and those cranks have worked flawlessly on my Riot for 2 years, using a direct mount 6mm offset 30 tooth Absolute Black chainring. Clearances look tight, but have never been an issue.
    Aug 2010
    I appreciate the feedback, glad I asked before going forward.
    Here what it looks like without the spacer installed. I canít even get the calipers inside to measure, but Iíd estimate about 1.5mm clearance.
    Mar 2015
    No problem, and agree that it looks really tight, but itís always looked uncomfortably tight on every Canfield Iíve owned (4), and Iíve never had issues. Iíd put calipers on mine or take pictures but Iím away from my bike for another week. If youíre unsure email some pics of your setup to Canfield, theyíll make sure youíve got the best setup info available.
    For reference, with these cranks, when tightening the bolt on the nondriveside crank arm it should tighten until you feel a hard bottom out. If you werenít getting that feeling with the spacer (I never did) then they werenít installed correctly.
    Aug 2010
    Agreed on tight clearances in Canfields. One of my N9s I couldnít even see a space with the naked eye. Chainring never touched to stays though.
    My last pics are without torquing down. Not sure how much more inward it will move after torquing but with this clearance it makes me nervous, especially with a FS rear triangle, as I would imagine there is more chance of lateral movement when the suspension goes through its movement as it ages and linkage breaks in.
    We haveít even talked about chainline yet...
    Oct 2015
    Judging by your pick, I run mine that close or even a little closer. No issues. I did check my pivots during (3◊ a ride) the first few rides. And weekly there after.
    Aug 2010
    Just torqued the B.B. cups and it moved close enough that the chain rubs the stay. Clears without the chain but ainít gonna work with it on.
    Now I either get a 3mm chainring or use a spacer.
    Aug 2010
    Just checked out Canfield chainrings on their site and theyíre listed as -3mm offset.
    Reputation: OwenM's Avatar
    Oct 2012
    No drive side spacer with a GXP and 73mm BB. Everything is spaced and held together on the NDS. Using a DS spacer can only increase your chainring clearance if it is forcing the crankarm out by pushing the bearing cover on the drive side against it, and in doing so keeping the NDS of the spindle from seating in the crankarm properly. That's why the talk of trashed bearings(I suppose from crushing the cover into the bearings when torquing the NDS bolt down and causing it to bind?) and cranks falling off.
    Canfield does sell 3mm offset chainrings, but my ovals are the standard 6mm. They are close, like in your pics, but haven't been a problem. So close that when I built my Riot, I lubed the chain heavily, forgot to wipe it down in my excitement to ride the bike, and had sludge wiping off on the chainstay. First thought: "Holy crap, chainring's rubbing!" But it wasn't...
    Notice there is no "tip" on those instructions for moving the chainring *further* from the frame, only closer to it.
    Aug 2010
    Quote Originally Posted by OwenM View Post
    I did notice that and thought it was odd since my experience with Canfield frames has always been about getting the chainring further away.
    Is there something different about the Canfield cranks vs. the SRAM design?
    Reputation: shiggy's Avatar
    Dec 1998
    You are not understanding how the GXP BB/crank works.
    The scrank spindle captures the NDS bearing to laterally fix the crank. The spindle is free floating in the DS bearing.
    By the Canfield instructions ( http://canfieldbrothers.com/wp-conte...k-Assembly.pdf ), a 1mm spacer between the spindle and NDS bearing may be used to move the chainline outboard.
    A spacer under the NDS cup is used to move the chainline inboard.
    Spacers under the DS cup do nothing to change the chainline.
    No fundamental difference between the SRAM and Canfield designs.
    weekdays..
    Dec 2009
    Make sure you have the steel fixing bolt (w/o the washer) if you put in the nds internal extender/spacer, some Truvativ/Sram one's are aluminum and the threads strip right off the bolt.
    video=youtube;][/video]...
    Aug 2010
    Spoke to Canfield last night and they do not recommend a DS spacer.
    Now I need a 0mm chainring.
    Oct 2012
    I wouldn't. It'll give you more chainring clearance(which you don't need, IMO), but make your chainline worse.
    If you're just gonna do it anyway, hit me up via PM. I've got a 0 offset direct mount AB oval 32T that was briefly used on a SS setup with my Yelli Screamy and could use some purpose in life...
    Aug 2010
    After speaking to Sean at Canfield, he recommended I get a 0mm or -3mm chainring.
    Reputation: J.B. Weld's Avatar
    I'm not quite understanding how the chainring clears but the chain doesn't, the last pic on post #10 shows the chain wrapping around the ring but obviously it doesn't run that way. Maybe I'm missing something but from what I see the clearance is ok, how is the chainline?
    Shiggy (is back!) of course is right, the ND side cup is what controls the chainline.
    I brake for stinkbugs
    Reputation: cpolism's Avatar
    Iíve got the Hope crankset with the spiderless narrow/wide ring which I believe is a 3mm offset. It is extremely close as well, and there are wear marks on the stays. Iím glad I saw this, because I was about to purchase the new RF Next R cranks with the absolute black oval ring thatís 6mm. Now this has me second guessing. On a Ď16 Riot for what itís worth...
    I had issues with my 175 RF Next cranks rubbing the back chainstay. You can forget about using the rubber boot and they absolutely needed a DS spacer. I switched to 170 SixC and the issue is relieved. I can't scientifically say if it was the stiffer crank or the -5mm length that mitigated the issue, but I would definitely not recommend 175 RF Next.
    I am running a 32t AB oval btw, there is very little clearance but no metal on metal rubbing. The oval does illicit a bit more movement due to the constantly changing AS values. So, I get smoother pedaling circles, but more suspension bob. For me, at least it is worth the trade.
    Oct 2015
    You can get some 1mm spacers on Amazon really cheap. I find they are essential to getting as close as possible to the chainstays fo keep a better chain line.
    Quote Originally Posted by abeck View Post
    So that 32t AB oval youíre using is -6mm offset right? Iím looking at using the WolfTooth cinch ring, and they offer standard (12/142) at -6mm offset and also boost at -3mm. Iím currently using a -3mm on the Hope which Iím guessing is boost. I do have the issue where it drops from the 42 tooth when I backpedal, but that was resolved by not backpedaling haha. Iím guessing the -6mm takes care of that issue. Iím stumped on what to do...
    Man I wish I would have seen this earlier...
    I had this exact issue and it took me a bit to figure it out, but I did, with Sean's help. **This info only applies to the C2 Cranks with the GPX style BB**
    Get rid of the spider and the -6mm offset ring, get a direct-mount SRAM-style boost -3m offset ring ( I use the Absolute Black ).
    The BB should mount to the frame with NO spacers on either side. As someone else said, adding a spacer behind the BB will either destroy the bearings (with proper torque on the spindle) or the spindle will be loose and come out during a ride. If there is any play in the spindle (after you torque it properly), then re-do it and use the 1mm spacers that (should) come with the cranks, if you didn't get any just ask Sean, he sent me some and all I needed was 1. I could even send you some if you need, free of charge.
    This will get your spindle in with the correct torque and the ring will have 3-5mm of clearance which is plenty.
    Even if you do manage to get the spacers and spindle to work with the -6mm offset ring, your chain line will be off and your shifting will be shite.
    The only problem I had after this point was that the bolts for the DM ring inside the DS spindle rub on the shell of the BB. I put 1x of the 1mm spindle spacers on the DS to cure this and it worked!
    Feel free to ask if you need any help, I've built probably 15 Canfield bikes in the last few years.
  1. Oh, that Yelli chainring clearance...again...
    By canyonrat in forum Canfield
    Last Post: 12-01-2011, 07:03 PM
  2. WFO chainring clearance?
    By JanBoothius in forum Niner Bikes
    Last Post: 05-21-2011, 08:49 PM
  3. XO 2x10 for Tallboy, 42 chainring clearance?
    By Lenz43 in forum 29er Bikes
    Last Post: 04-22-2011, 06:24 AM
  4. Scale 29er Elite Chainring Clearance
    By BobShort in forum Scott Sports
    Last Post: 04-06-2011, 02:49 PM
  5. Chainring clearance?
    By bikerboyj17 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2011, 04:59 PM
Members who have read this thread: 59
