Results 1 to 15 of 15
    Apr 2013
    Riot bearing service
    Has anyone broken down the links on their Riot and done bearing service? My Riot has developed the most annoying creaking coming from the links. I equate it to a really muddy ride I had this past winter and the washing that took place following the ride. I just want to know what the service is like? Do I need a bearing push/pull or can it all be done without removal?
    Thanks for any input.
    Help I've Fallen
    Reputation: dwick37's Avatar
    Nov 2007
    I would call Canfield Bros, they have awesome customer service.
    2016 Canfield Bros EPO
    2016 Santa Cruz Hightower
    2013 Niner S.I.R. 9 SS
    Apr 2013
    will do.
    Unit 91
    Reputation: TheProphet's Avatar
    May 2005
    I've done it before and had a few less than ideal bearings, but no stuck bearings. I carefully pulled the seals off them, cleaned/cycled them with a mixture of PB blaster and speed clean until they rolled smooth. Then pack them 1/2-3/4 full with fresh grease (like slick honey), pushed the seals back in and gave them a few rotations. They felt good after that. I try to disassemble everything at least once a year to avoid any larger issues.
    If you have any stuck bearings, I would replace them. A bearing puller and press is the best tool, but it can be done with them.
    Bikes
    Apr 2013
    After looking at consumable replacement parts there is only the two 15mm bearings and the rest are pivot bolts. I sent a message to customer service to see what they say. Regardless, I'll probably spend my Friday night trying to get rid of the sound.
    Unit 91
    May 2005
    Do you check your bolt tightness regularly?
    Bikes
    first step always in dis-assembly, cleaning, inspecting and re-greasing. Its amazing the places creaks reverberate from. Sometimes they lead you in the other direction but starting with individual components and isolating things 1 at a time. Let us know your findings!
    Apr 2013
    I took all the pivots apart last night. I didnt remove any bearings but checked each one to make sure it rotated smoothly. I cleaned up all the mating faces of the pivots and put a little bit of grease on the pivot bolts. I bounced around on the bike last night and it was quiet. I wont know for sure if I got the exact sound out that I was hoping for until my next ride.
    The sound Im hunting for is recreated when I push the wheel from side to side just above the seat stays. It makes a small creak and popping noise. Im hoping I got it last night by disassembling, cleaning, regreasing, and tightening everything back up.
    Dec 2015
    took my linkages aparts last night. most of the bearings apeared dry. greased them up real good. worked the grease into the bearings. seal up. assemble back. took me about 2 hours. real smooth now.
    Apr 2013
    More of an FYI for anyone that is looking to do this.
    The upper pivot links are direction specific even though the shape is completely symmetrical. How far the bearing sits into its seat is what makes each side unique. If put in backwards, the pivot bolts will not go in as far as intended.
    The markings to tell the direction is "forward-rt" and "forward-lt" and is written around the front pivot bearing of each link.
    Reputation: Raleighguy29's Avatar
    Jan 2014
    I just did this service last week on my riot. And was blown away on how easy it was. My old stumpys were a pain in the ass to do this on. And now I'm back to having a quite happy riot
    Older thread, but I just went through my bearings on my 2016 Riot last night. It uses 8x 6902 bearings, which if memory serves me correctly means that it uses the same bearings as the Balance, which means you can order the kit from RWC for the Balance.
    Unfortunately my 2016 Balance had the same shitty BOLU bearings as my Balance. Made in china junk, although at least this time they were lubricated with decent bearing grease and not white lithium like on my Balance.
    Not a bearing expert... Are these the way to go?
    (from this URL: ENDURO MAX BEARINGS: ULTIMATE SUSPENSION PIVOT BEARINGS! )
    Formerly of Kent
    Reputation: Le Duke's Avatar
    They’re an Enduro product, so, no.
    NTN, SKF, or NSK all make better products.
    Death from Below.
    Quote Originally Posted by CWnSWCO View Post
    Yeah. You can get a full set here (just order the kit for the Balance, they're the same):
    CANFIELD Suspension Pivot Bearing Kits from RWC
    Le Duke is not necessarily wrong, but NTN/SKF/NSK bearings are all about $15-25 each, versus $6.37 for the Enduro bearings if you buy 8 at a time. The Enduro Max bearings will hold up for a season at least and they are what Canfield used to spec on the frames.
  1. Bearing service ?
    By woodsgroovin in forum Tooltime
    Last Post: 02-19-2013, 05:52 AM
  2. Lower bearing service.
    By coghi in forum Intense
    Last Post: 05-14-2012, 05:05 PM
  3. Heckler Bearing service?
    By cman8 in forum Santa Cruz
    Last Post: 01-02-2012, 08:50 PM
  4. '10 Enduro Frame Bearing service
    By thrasher_s in forum Specialized
    Last Post: 10-26-2011, 12:19 PM
  5. Time for bearing service . . .
    By 007 in forum Santa Cruz
    Last Post: 09-14-2011, 03:17 PM
Members who have read this thread: 43
