Results 1 to 8 of 8
    Jan 2011
    "The One" double barrel coil settings
    I've been messing with my double barrel shock a little bit to dial it in to get as much pop/per-load as I can for hitting doubles and jumps.
    What is every ones HSC, LSC, HSR, LSR settings for big jumps?
    Quote Originally Posted by t-sixtyfive View Post
    This is a great starting point and where I settled in on my One when I was running the DB Coil:
    Reputation: katsooba's Avatar
    Nov 2008
    hey Killington,
    did you recently change the base tune setting for the one and Jedi?
    i remmember seing different settings last month
    14' Canfield Jedi - The fast just got faster!
    15' Canfield Balance - The go to guy of the bike world!
    We updated the Base Tune Coil settings about a week ago after further testing. The DB Air stayed the same.
    Reputation: socalfyre's Avatar
    Dec 2010
    Vin - Are the Lows a lot different from before or is just me?
    I was also curious about this...
    The latest tunes are the same for The One and for the Jedi, where as they were different before.
    Is it truly right at the same settings for both bikes?
    Yes, we settled on the same settings for both the Jedi and the One on the coil. The DB Air is different as it is not as linear.
    Please keep in mind, these shocks are NOT custom valved. We only have them set the settings to our preferences. These are a merely a good starting point as everyone has different preferences on how we like things to feel, the terrain we ride, the speed we ride and how we like to ride.
    Hope that helps!
    Vin
    Jan 2011
    This helps a ton, thanks in advance. I think I'll start with your recommend and go from there, thanks in advance!
  1. Replies: 0
    Last Post: 09-22-2012, 10:00 AM
  2. Replies: 0
    Last Post: 06-23-2012, 06:26 PM
  3. Double Barrel Base Settings for a V10c?
    By IntenseMack10 in forum Santa Cruz
    Last Post: 02-22-2012, 05:14 AM
  4. cane creek double barrel settings
    By sundace in forum Shocks and Suspension
    Last Post: 11-23-2011, 07:19 PM
  5. Double Barrel settings on your Podium?
    By Sethimus in forum Knolly
    Last Post: 05-07-2011, 08:25 AM
