Results 1 to 3 of 3
    Jan 2016
    Older-model Yelli + Angleset?
    Anyone ever run one of them Angleset things? I like the head angle of my Yelli Screamy as-is, but I want to put a longer-travel fork on it without making the stack height ridiculous (already running flat bars, being short is hard). I was thinking the Angleset might bring the front end down a little and offset an extra 10-20mm of travel. Thoughts?
    Reputation: twd953's Avatar
    How long of a fork are you trying to put on there? If you're not going over 140mm, I wouldn't worry about it.
    Rule of thumb is adding 20mm of travel to your fork slackens your head tube angle by about 1 degree.
    Adding 20 mm of fork travel will also raise the front end by about 15 mm assuming you are starting off with a 68 degree HT angle going from 120mm to 140 mm fork (not sure what year Yelli or what length fork you are running so that might vary). Now you'll be at ~67 degree HT angle.
    Angleset could slacken you out a further 1.5 degrees, say down to about 65.5. 1.5 degrees slacker with an angleset would lower the front end by about 5 mm, so a net difference of 10 mm higher than what you started with before a new fork and angleset.
    However, adding a 20mm longer fork and 1.5 degree angleset would also lengthen your wheel base by touch over 20mm.
    I rode it with 120 fork and 1.5' CC angleset, loved it
    Attached Thumbnails Attached Thumbnails Older-model Yelli + Angleset?-img_2648-large-.jpg
  1. Older model specs
    By Kofaram in forum Santa Cruz
    Last Post: 04-14-2016, 04:15 PM
  2. Yelli Screamy Help anyone have an older frame?
    By strangedejavu506 in forum 29er Bikes
    Last Post: 01-13-2014, 02:12 PM
  3. Replies: 4
    Last Post: 07-22-2013, 08:46 PM
  4. Older Klein. Model name? Rebuild?
    By NErider in forum Bike and Frame discussion
    Last Post: 04-21-2012, 09:17 PM
  5. Older Model Bikes
    By ianjt in forum Idaho, Montana, Wyoming
    Last Post: 03-19-2011, 12:32 PM
