Results 1 to 31 of 31
Thread: Not Happy...
    Reputation: jtnord's Avatar
    Jun 2010
    Not Happy...
    So I had a flawless Thompson Masterpiece w/set back that I ran on my last bike for about 2 years. Pretty impressive since I ride hilly areas and I normally adjust my post 5-20x a ride.
    Well here it is and the seat tube after 1, just 1, short ride (7-8 adjustments) on my brand new The One...
    Needless to say Im pissed. Yes, if I was more attentive I could have reduced the damage some, but still...
    Any suggestions on what I can do? Clearly there are some burrs or something down near where the top tube meets the seat tube but now the whole seat tube is cut up. What are my best options?
    6'5" 230lbs
    My Build: Vitalmtb - Bike Check
    Reputation: riiz's Avatar
    Get a file and de-burr it.
    But it also looks like something was wedged between the post and the seat-tube, rock, metal, etc. Because both have the same pattern of wear from being adjusted.
    Reputation: rsullivan's Avatar
    When you first installed the post, did it slide right in or was it tough then. Usually if there is a burr/or weld deposit it will be noticed at be first install. Also after which adjustment did you notice the friction while moving it. As far as repair goes, a small flapper wheel and a flexible extension for your drill. Best yet a adjustable reamer(straight) would work
    Jun 2010
    Quote Originally Posted by rsullivan View Post
    Prior to putting the post in, I throughly cleaned it and greased it. I also did a quick visual inspection of the seat tube and wiped down the top 4-6 inches that I could easily reach.
    It went in with out any problems. Then when I was adjusting there was some resistance hence the twisting. But Ive had the same or similar resistance before with other bikes with out causing any damage to the post or seat tube. The difference this time is that it got noticeably worse in 1-2 adjustments and I started hearing the grinding.
    It seems unrealistic to think I could have completely prevented all the scratches with out reaming from the start. Any scratches on a mint $150 seat post would piss me off. I guess I should be thoroughly prepping all my seat tubes from now on...
    Whats going to be better? A reamer or a flex hone? and can anyone recommend a particular one? Thanks in advance!
    Flex Hones, Flexible Honing, Flex-Hone®
    6'5" 230lbs
    Jun 2010
    Quote Originally Posted by riiz View Post
    It certainly is strange as it was happening on the left and right side at the same time while also happening on the front but only at the very bottom. Certainly wasnt rock because I wasnt even on the trail yet. Im pretty sure the seat tube wasnt properly reamed/ prepped.
    6'5" 230lbs
    Jun 2010
    Quote Originally Posted by TheRage43 View Post
    Unfortunately, I dont really see that as an option at all. At risk of starting a dropper post thread: I want a set back, its 1+ lbs added weight, more maintenance and problems, Im 6'5" and none adjust very far, Im currently 240lbs naked.
    6'5" 230lbs
    Reputation: Calhoun's Avatar
    Nov 2008
    how did you not notice this happening the first time? It looks like the post was moved up and down several times. why not just stop moving the seat after the first scratch was noticed and get it fixed?
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Jun 2010
    Like I mentioned above, with in a couple adjustments I realized something was wrong. At this point most of the damage was done and since I was mid ride, i continued a bit further before I got back to the parking lot.
    I dont see how having 1/3 the scratches would be any better than where it is now. You cannot simply "fix" the scratches on the seat post and nothing would have changed with regards to the seat tube.
    6'5" 230lbs
    Based on those marks, it looks like the seat post was fitting pretty tight in the tube. When I loosen my clamp, my seat can be slid straight up and down, on the wiggle back and forth, while pulling it up motion your post shows. I would think you could hear that, and feel that while you were adjusting.
    Either way, it sucks!! But I kinda like that pattern. Keep going up the post, all the way to the setback. It will look cool.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Maybe there was some grit on the post the first time you lowered it on your ride, and dropping the post let it get between the tube and post. Once it was in there it's trapped with no way out except pulling the post and wiping it all down. It sure does suck that it happened, whatever the reason.
    You want to be careful honing it or you'll be posting next about your post slipping.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Quote Originally Posted by jonshonda View Post
    At this point I think this may be the best option
    Reputation: Christina L's Avatar
    Sep 2012
    I ordered a flex hone from eBay and it worked fine. 32 mm and a medium grit I think. Get an air compressor and blow as much air as you can up into the tube piercings. I used some short stiff tubing to extend down into the hole from the air nozzle. Try to do it with the bike leaned back with the fork in the air so anything that's inside there can fall out.
    240 grit seems safe. You will also need an extension to get it in there far enough.
    1 1 4" 32mm Engine Cylinder Flex Hone Flexhone 240 Grit | eBay
    Reputation: socalfyre's Avatar
    Dec 2010
    Quote Originally Posted by jtnord View Post
    This happened to me too. Pretty much the exact same way. Cleaned and greased the post and seat tube, went in fine with no resistance or abnormalities. Only when I went to remove the post and do other adjustments did it start scratching my dropper post in that same exact pattern. Initially I could not see or feel what was causing it, but eventually de-burred what I thought was the problem and it seemed to have done the job. I guess it's a good thing it's on the section of the dropper post that stays in the seat tube that I don't see the scratches.
    Hope you take care of the problem!
    7MGTE
    Reputation: supramk388's Avatar
    Before you posted this thread did you even try calling the Canfield Brothers?
    If I had an issue with my bike I would just pick up the phone not post on mtbr?
    Every time I have a question or needed help on my frame, Canfield Brothers has ALWAYS been eager to help.
    Reputation: katsooba's Avatar
    Nov 2008
    can you guess what scratched what?
    that look whack!
    17' Canfield Jedi 27.5" - The fast just got faster!
    15' Canfield Balance - The go to guy of the bike world!
    Jun 2010
    Quote Originally Posted by socalfyre View Post
    Glad to know Im not the only one. I hope this thread will help others who run into this problem!
    6'5" 230lbs
    Jun 2010
    Update: I talked to Canfield on Monday and they recommended taking it to a shop to have it honed with a ball / flex hone. A reamer would risk taking material off where as the hone will just smooth it out.
    I brought it to a shop and had the honing done. Much better now. The seat post was very lightly smoothed with steel wool, mainly just the bottom 2 inches. The problem appears solved, although permanent damage done to the post and seat tube.
    Thanks to a couple of you who actually offered advice/help!
    I will be honing all my seat tubes from now on...
    6'5" 230lbs
    Jun 2010
    Quote Originally Posted by supramk388 View Post
    How would customers know of potential problems then?
    6'5" 230lbs
    7MGTE
    So you were trying to help? By ranting on the internet before even calling the mfg.? That makes sense, well I guess to you.
    And when you did call this happened:
    " I talked to Canfield on Monday and they recommended taking it to a shop to have it honed with a ball / flex hone. A reamer would risk taking material off where as the hone will just smooth it out. "
    Sounds like issue got addressed once you called. So what potential customers can know is if you have an issue a Canfield frame it will get taken care of once they know of it.
    7MGTE
    Do you build your bikes?
    Here is why I ask. I do and I enjoy it very much.
    First mountain bike I ever owned/built was a Yeti 575. The color was Yeti Factory colors. The paint for some reason chipped real easy on that frame. Also speaking of seat post I had a brand NEW Thompson Masterpiece but not a setback. I did not have the same issue as you but close enough. I scratch was straight up not zig zag like yours. My local Yeti deal fixed once I drove to the shop. As far as the paint they said some fames did that and I got handed a bottle of touch up paint, lol.
    Frame issue was fixed and mfg was aware of paint issue already. Did I go ranting on mtbr, no. I just fig once in a while Yeti (or whoever) might have a frame slip through with a minor issue. I did not feel the need to tell the masses I guess since issue was addressed.
    Later I had a SC Nomad first gen. I put a 36 Fox Talas on and the crowns touched the DT. I was a little bummed but called Santa Cruz. I was told they were aware of it and next years SC Nomad would not have the issue. I had a Chris King headset so I fixed the issue with 5mm CK base plate. It fixed the issue and slacked out the bike some which I wanted.
    Again did I go in the SC forum to rant, no.
    I guess what I am trying to convey is that if you do build your own bikes then you would know sometimes issues come up on the build, hell during the first ride. When things come up you fix/address them and move on man.
    Focus on how amazing your bike is and how much enjoyment you will receive from it.
    At least your MP was not new like mine, lol.
    Jun 2010
    Im sorry, you think I was ranting. I don't feel I was, nor was it my intent. Had I seen a similar thread prior to building my frame, I would have paid much closer attention to the seat tube prior to install and might have prevented any problems. I would have been grateful that the other forum member was willing to share their experience.
    Also this thread will serve as reference to others (including non canfield owners - via the google) about this general issue and the best approach to fixing it. When I first encountered the issue I did not run to mtbr to post a rant thread. Rather I spend a good amount of time searching on the internet. The results were meager and not particularly helpful. It seemed a lot of people were recommending a reamer for the same problem and few were knowledgable about hones. I knew little to nothing about reaming and honing prior to researching. Between the research, canfield, and my shop, I now know a lot more.
    I'm all for sharing this kind of information for the benefit of others. I will not keep it between me and my bike shop or me and the manufacturer. Again it was not my goal to "flame" or "rant" nor do I feel I did either.
    6'5" 230lbs
    Jun 2010
    Also, clearly there are people posting in this very thread that are clueless on the subject. Will it not benefit them too?
    6'5" 230lbs
    Reputation: charging_rhinos's Avatar
    The problem appears solved, although permanent damage done to the post.
    nope. You could easily get your seatpost re-anodized. It's a pretty simple process. Anodizong shops do flat black ano all the time, and you can throw it in with a batch for very cheap if the shop worker is nice. Takes a few hrs max. Ano/coating shops are all over the place too. I live in Salt Lake, and there are at least 4-5 shops that I can think of off-hand. I would personally just take a sharpie to it and ride the thing, but you do have options if it bothered you enough that you posted what began as a bit of a bashy-rant (it was, although your tone did calm down as the thread progressed which is good).
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    West Chester, PA
    How did the post AND the frame end up with the same scratch marks if this was supposedly the fault of the frame ?
    Aug 2010
    Had the same problem with my '12 Jedi. My seatpost went from black to raw aluminum. I hadn't had the issue with any other bike I owned so was not aware of that being a problem. It chewed up a few seat posts of mineso I went to work sanding and filing it with a bit of resolve. Its a bummer for sure but not the worst that could happen. On the other hand the bike simply rips so I got over it, just glad I went with a $20 ebay post.
    Professional Crastinator
    Reputation: Fleas's Avatar
    This is usually standard procedure for all bike builds.
    Although I did file a small burr from the slot of the seat tube, flex honed it, and I still got a scratch on my post from my Nimble 9 frame. So then I honed the crap out of it.
    Ideally, you gently clamp the frame upside down in the stand so when you hone it - using oil on the hone - the oil drains out. After that, you clean it like a shotgun and get all the stinky oil and grit out of the seat tube.
    Most shops will have a couple different sized hones depending on the diameter of the seat tube, or how much material you want to remove - which amounts to thousandths of an inch. It's not like you will wear a hole through the side of the seat tube or something.
    -F
    It's never easier - you just go faster.
    Someone like me for example, thanks for posting this. I didn't view it as a rant at all. I have a similar problem with my Yelli that I bought last September. But I am a real novice to bike building, this was my first frame purchase, and I just ignored all the scratches on my brand new Thompson seat post. My fault for ignoring it, but one of the things with internet transactions, is it brings in novices like me, although probably a very low percentage who don't really know what they are doing. I just felt the seat post and the scratches seemed cosmetic, so I haven't bothered with it, and the scratches are all below the insert point for me. I didn't think to visually inspect the inside of the seat tube for scratches, I just felt in there for a rock or dirt and didn't feel anything. At least now I know what can be done to prevent it from getting worse. I don't have any ill feelings towards Canfield, it's still a great bike that I love riding and this seems like a totally fixable problem. For all the newbie novices out there, just have your tube checked or use a really cheap seat post at first to see whether you have this issue.
    Reputation: kingdom's Avatar
    Exact same thing happened on my Yelli Screamy. Luckily it was a £10 post whilst I waited for a reverb otherwise I would have been more upset.
    7MGTE
    Quote Originally Posted by cjsb View Post
    I did, starting with the title of the thread. After that took it as a rant. Looks like this thread was posted without even calling Canfield Brothers. Day after this happened jtnord finally calls Canfield Bros, they help him right away. jtnord does not update folks in his thread? WTF? When the owner called the mfg, the owner was helped immediately, but yet jtnord does not update the masses on mtbr?
    On Thursday I finally ask jtnord, "did you even call CB's?". Then jtnord let's us know the issue was addressed on MONDAY already.
    So to me if this was all about "info" why not post something like "FYI check your seat post tube just in case".
    Then post pics. If you have not even called the mfg for help mention that. After you call mfg let others know how it went so that they may learn.
    He talks nothing about the bike as well it seemed more as to flame the mfg.
    Keep in mind you can always call the mfg for help with your frame.
    This is not a problem of any particular bike. It can and will happen with any bike from any brand. The problem arises more often on these kinds of bikes because they are sold as frames directly to consumers. These consumers are typically not well versed in best practices in regards to building a bike.
    Honing the seat tube is right there with facing the headset, facing and/or chasing the bottom bracket. Bikes that are built in a bike shop always have these things done and most people aren't aware of it.
  1. Ride Happy, Happy Ride March 2013
    By ImaKlyde in forum Oregon
    Last Post: 03-27-2013, 07:09 AM
  2. I'm happy :)
    By David C in forum Passion
    Last Post: 05-05-2012, 03:58 PM
  3. Happy with LBS.
    By Cycle64 in forum Arizona
    Last Post: 12-23-2011, 01:31 PM
  4. I can now die a happy man...
    By Demodude in forum Downhill - Freeride
    Last Post: 04-11-2011, 01:32 AM
