Results 1 to 5 of 5
    May 2010
    Nimble 9 build advice needed
    Just got my 2013 sparkle orange N9 frame.
    I'm thinking about some build options
    here are the stuff i already have-
    1) fork- RS revelation 120. it is black with white\orange labels.
    the same fork that is OEM on 2013 honzo:
    http://1.bp.blogspot.com/-AJ-lxmmKL0...2147C65465.JPG
    2) wheel-set- can be one of this two:
    http://www.bicyclebuysell.com/images...1372905962.jpg
    or :
    MacMahone | 99
    (the same set-different colors)
    i can't get any other wheel-set nor fork, so assuming that-
    1) what wheel color should i get?
    2) handlebar- i thought putting my RF orange atlas combined with black stem- any other ideas? (i thought going with some blue- but i can't change the wheel colors)
    3) saddle colors- black? white? orange?
    Reputation: coleam's Avatar
    My personal choice (purely aesthetic) would be the black wheels with white stem, orange bars, white saddle. White saddles get dirty really fast though, so you may want to go black here. That keeps your main color scheme as black and orange, with some flashes of white accent.
    May 2010
    If i will go with the white stem and the orange bar, should the grips be black or white?
    Reputation: rsullivan's Avatar
    I did mine with black and blue accents...like how it turned out
    Chris Bling
    Reputation: dustyduke22's Avatar
    Just throwing this out there...Most white spokes are painted, so they are much heavier than the standard spoke. If that doesn't matter to you, then no worries. If weight is a consideration, I would look for different wheels without white spokes.
    Also, by the look of the wheels you posted, they don't look like they will work with your RS Revelation unless they have through-axle options. Hope that helps.
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  1. Advice Needed: Weyless XP, Budget build.
    By gryffinwings in forum All Mountain
    Last Post: 06-10-2017, 05:05 PM
  2. Advice needed on a Carbon IP-057 build
    By El34 in forum 29er Bikes
    Last Post: 10-08-2013, 09:03 AM
  3. Nimble 9 build Advice
    By VertKurt in forum Canfield
    Last Post: 01-25-2013, 06:23 PM
  4. Legend Build - Advice needed...
    By MalcolmX in forum Banshee Bikes
    Last Post: 04-03-2011, 10:58 AM
  5. Light weight wheel build advice needed
    By rc51kid in forum Weight Weenies
    Last Post: 03-21-2011, 07:01 PM
