Page 7 of 7 FirstFirst ... 34567
Results 601 to 689 of 689
  1. #601
    Robtre
    Reputation: robtre's Avatar
    I have not tried the Crampon pedals, but they look good! Crazy expensive though.
    -rides bikes for fun.
  2. #602
    Reputation: waveslayer's Avatar
    Nov 2014
    Quote Originally Posted by robtre View Post
    but are sick. pricy yes, but nice pedals
  3. #603
    Reputation: ChvleSS956c's Avatar
    When does the next set of frames come in, I need a large, any changes for 2016?
  4. #604
    Professional Crastinator
    Reputation: Fleas's Avatar
    Quote Originally Posted by Fleas View Post
    Anyone get any sort of creak from their rear thru-axle? I am getting a noise that I can't figure out. All the bolts are tight. Cassette is tight. Hub bearings are tight. Crank bearings are tight.
    It creaks one way when I pedal hard, then creaks back when I brake hard. Something is moving a tiny bit but I can't isolate it.
    Thanks,
    -F
    Quote Originally Posted by flymybike View Post
    The trick I do to find a creak is place your finger on both parts and try to recreate the creak. Touch every part connection and wiggle it back and forth until you feel a "tick". Common creaks are seats, BB's, headsets, pedals and anything left slightly loose. It helps to figure out if it happens when standing or seated, coasting or pedaling or braking. Good luck.
    Turns out the thru-axle was loosening up. Not sure how. It was pretty tight.
    -F
  5. #605
    Reputation: kragu's Avatar
    I've been in the market for a HT 29er for a while now, having given up my long travel AM 29er for an AM 27.5 bike. I'm looking for this bike to be a bit of an XC rig, with some AM blood. The N9 seems to tick those boxes for me... efficient but somewhat compliant, yet at home under someone who ultimately prefers descents.
    To that end, what do you guys *not* like about the N9? Why wouldn't this be the bike for me?
    I know I'll have to take some answers with a grain of salt, but there's no better place to find people who have ridden this bike.
    Jan 2011
    I love my Nimble 9; it definitely exemplifies all the characteristics you seek. I only have one complaint, but I've never seen it voiced here, so I'm assuming it's just me and my duck-footed riding style. That is, I have some problems with heel strike on the chainstays, which are pretty wide.
  7. #607
    Reputation: Erock503's Avatar
    Oct 2014
    Quote Originally Posted by pedalmore View Post
    Interesting. It's the first I've heard about this particular bike, but it seems like a consistent theme for some people. With the new crop of wide rear/boost type rear ends, it seems like a race to accommodate the widest tires, shortest cs, and the straightest chainline. At some point, the width is not going to work for some people.
  8. #608
    A few people had that issue with my previous AM bike (Lenz Lunchbox) and its 16.7" chainstays, but it wasn't an issue for me, either on flats or clipless. Definitely appreciate the feedback, though!
    I've seen at least one person call into question the quality of steel used. Can anyone (KVT included?) speak to that?
  9. #609
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    No fatigue issues here and haven't seen any posts in the almost 3 yrs v2 has been out. I would absolutely never get rid of this bike unless I became a paraplegic. From what you are saying you're looking for, this bike is it.
  10. #610
    Robtre
    Quote Originally Posted by fishwrinkle View Post
    I would still keep it, set in tin the corner to admire.
  11. #611
    Thanks guys. Now for an update on availability....
  12. #612
    weekdays..
    Dec 2009
    Yes please...2016 Nimble 9..has it been done in raw yet??
    video=youtube;][/video]...
  13. #613
    22F, clear, and dry this morning.
    Damn is that thing shiny!
    -F
    It's never easier - you just go faster.
  14. #614
    Canfield Brothers
    Reputation: flymybike's Avatar
    Quote Originally Posted by Deerhill View Post
    No, raw. A steel frame would rust right away with no coating. We either chrome the frame or ED black and then powder coat the frames.
    http://www.canfieldbrothers.com/frames
    Building bikes that make you smile!
    www.mtbparks.com
    All Bike Park, All the time.
  15. #615
    weekdays..
    Dec 2009
    Those of you that have been riding xl or large N9, would you be against 80mm bottom bracket? Been looking for this and haven't found much.. Tires ~170mm b2b are really nice on steel HT frames like this, 80mm bb seems like a solid way to gain a couple mm for these rubbers in short cs w/ 29"
  16. #616
    weekdays..
    Dec 2009
    Black and chrome are nice
    I should have said clear. Had a couple steel ht w/ raw look (clear so you can see the steel finish).
  17. #617
    clear satin PC on a steelie would be sweet.
  18. #618
    weekdays..
    Dec 2009
    Want to see the new dropouts...what kind of rear axle on the 2016?
  19. #619
    Aug 2010
    Site says 12X142 TA
  20. #620
    guessing its still the 142 spacing with a 135 axle
  21. #621
    Canfield Brothers
    The rear hub spacing is still a 142 x 12 hub. The rear axle comes with the frame however if you replace it, it is a 135x12 axle because the dropouts are narrower than the Maxle spec. We didn't think 16mm thick dropouts were helping with anything other than adding weight.
    www.mtbparks.com
  22. #622
    weekdays..
    Dec 2009
    Quote Originally Posted by racefit View Post
    Site says 12X142 TA
    It doesn't say which kind of axle for 2016 though, think it used to be a 12x135mm TA.
    Maxle, shimano, or maybe it's a Canfield one??
  23. #623
    weekdays..
    Dec 2009
    Will this axle work?
    Hadley Thru-Bolt 12mm X 165mm (135mm Spacing) ? Balle Racing Mountain Bike Parts & Tools
  24. #624
    The 2016 N9, uses our own axle that threads into the drive side dropout, then has a pinch clamp on the NDS dropout that locks the axle into place. We use this same set up on our Jedi, Riot, 2016 Balance, the 2015 N9 and the 2011-2013 The One. It is the lightest, most effective axle set up we have used. We also stock replacements for anyone in need of one of these axles.
    The Hadley, nor any other full bolt on thru axle won't work as it would require different dropouts to work.
  25. #625
    Attachment 1005615Attachment 1005616
    Attachment 1006460
    2014 XL CHROME N9
    RS PIKE 140
    Industry 9 Turquoise
    Chris King HS PURPLE
    XT Brakes
    Purple Blackspire flats (best flat pedals i have ever owned)
    Turquoise Salsa Seatpost Clamp
    Thomson Stem 50mm Silver
    Thomson setback seatpost Silver
    MAXXIS IKONS
    Why Purple and Turquoise ? Charlotte Hornets Colors. Love this bike so damn much!
    Nice build! How tall are you? I'm 6'2" and was on the fence between the XL and Large. Went with the XL. Seems like the bikes run short, but I have no real world experience.
  26. #626
    Robtre
    By design its made to be snappy, therefore it is compact. I am 6'4", and the XL still feels a bit cramped compared to my older, more XC oriented bike fits. Bottom line is, this IS the best hardtail frame I have EVER ridden!!!
  27. #627
    i'm 6'2", 34" inseam on an xl, 18/25 reach/stack, spot on fit for me. running a 50mm stem, 30"- 2"rise bars, straight post. i've been riding the gen2 v1 frame since the day they came out and i'm still impressed every day i ride it. i'm itching now to get a '16 balance and make it a snappy lil slalom 26er.
    i like the fact that the '16 n9's are now getting a round tt and stealth routing. thought about selling my '13 chrome and getting one of the new metal flakes
  28. #628
    Thanks for the reply. Perfect.
  29. #629
    just saw pics of the green flake frame on the CB site and man that thing is tits. should i sell 13 chrome frame for this, maybe?
  30. #630
    Reputation: DoubleHelix's Avatar
    Oct 2010
    Converted my N9 from ridid SS to 6sp 140mm hardtail.
    First ride of this season:
  31. #631
    weekdays..
    Dec 2009
    Agreed on the finish...fyi dbl ✔ geometry...ST, reach, sizing shift from previous MY to 2016
  32. #632
    Unit 91
    Reputation: TheProphet's Avatar
    May 2005
    Built the N9 back up with B+ to compliment the Riot. This is just a loaner wheelset (which the Scraper rim is a tad too wide), but these wheels change the way this bike rides. Sooo much fun!
    Attached Thumbnails Attached Thumbnails The NEW Canfield Brothers Nimble 9-image.jpg
    Bikes
  33. #633
    Awesome. I'll be on that train soon. Just laced up my wheels last night. Next up, tension... Kind of therapeutic, this wheel building thing. The NEW Canfield Brothers Nimble 9-imageuploadedbytapatalk1458865485.190663.jpg
  34. #634
    Reputation: Adim_X's Avatar
    Nevermind
  35. #635
    Robtre
    Best Hardtail Ever!
    Unadulterated FANBOI RANT ON:
    After a full year on my Nimble 9, ~1500 miles on a wide variety of terrain, the N9 is the best hardtail, and bike at that I have ever ridden! For the record I have had 11 different hardtails, and 2 FS bikes and my N9 is my baby! I have ridden PISGAH GNAR up, and downhill with huge smile on my face, I have ridden super-flowy flow trails, even dropped the seatpost and ridden pump tracks/ dirt jumps with it. I love this bike, I cannot imagine anything better! The NEW Canfield Brothers Nimble 9-fullsizerender.jpg
  36. #636
    A word of caution, I've recently had to retire my Gen 1 N9 because of a crack at the weld of the head tube to the down tube-head tube gusset. I loved the frame when rode it for 2 years (it was hanging in my garage for the last 2 years til I built it up for a friend to try), but I'm a little disappointed the frame failed like this. I'm a 50 year old XC rider, had the frame built with a 100mm fork. I bunny-hop stuff but never do big drops or anything remotely radical. Canfield did ok and offered me a new frame for $500 (the new frame is sweet but a bit porky), but I'm still a bit uneasy with the idea of a $600 frame that's only expected to last 2 years, (less I imagine if you're free-riding the bike like it's designed for).
  37. #637
    the fat don't bother me and it is made to handle things a lot differently than the 1st gen. once you get used to it bad memories will fade away, guaranteed. gen 1 was notorious for ht/dt failure. canfield did good on gen 2
  38. #638
    May 2010
    I'm looking to sell my 2016 Nimble 9 Frame Large Green in the next few weeks. Some use marks on the frame though no dings or dents. Price is $500.00
    I have it listed with more information on the Classifieds page
  39. #639
    Nimble Nine Boost Black Med. for sale with Sour Green Chris king head set.
    Quote Originally Posted by FatChanceTisale View Post
    PM me if you want it, as new!! Frame only with head set.
  40. #640
    Aug 2005
    If anyone one here has a large 2016 frame they want to sell, please let me know. Impossible to find right now.
  41. #641
    Reputation: Raleighguy29's Avatar
    Jan 2014
    Quote Originally Posted by dgw7000 View Post
    I have a large 2016 frame up for sale
  42. #642
    Aug 2005
    Quote Originally Posted by Raleighguy29 View Post
    The power of the internet! Thanks for responding. Can't wait to introduce this frame to Pisgah, assuming you haven't already done so.
  43. #643
    Reputation: ROFF's Avatar
    Jul 2015
    Here is my N9.
    Made it a rigid SS with B+ to be completely opposite my Balance
    I have it for sale, but I dont really think Ill sell it. The NEW Canfield Brothers Nimble 9-img_4325.jpgThe NEW Canfield Brothers Nimble 9-img_4324.jpg
  44. #644
    Robertson
    Reputation: rpearce1475's Avatar
    Jan 2015
    Piecing together the last few parts to build up a new Nimble Nine, could use some advice on two things. First, what fork travel do most of you run? It will be a fox 34, I was going to go with 120 to give it some good separation from my other bike (Evil Wreckoning), but maybe 130? Also, is anyone running a 150mm dropper with success? Seattube short enough?
  45. #645
    i ran 120 and 140. it depends on how you want and where you ride your bike. i like 140 cuz i like the geo and have places that have decent jumps and drops. i also am running a 150 dropper on an xl
  46. #646
    Gigantic Hawk
    Reputation: dubthang's Avatar
    Medium frame, 150mm DVO Diamond, 150mm 9point8 dropper.
    I think the frame rides better with more travel/slacker angles.
  47. #647
    Jan 2013
    Hey guys, I am comparing the geo on this to my Honzo ST and seeing that the M Honzo is pretty equivalent to the L N9... Does that mean I should buy a L? I am 5'8" with 30" inseam. Any help would be good. Looking at possibly buying a 2018 or possibly a 2017 if there are any left on markdown when the 2018s come up.
    "What Made Milwaukee Famous Has Made a Loser Out of Me"
  48. #648
    Jan 2014
    Quote Originally Posted by machoburrito View Post
    I'm 5'8 and ride a large riot balance and epo and have ridden large nimble9 and love the fit
  49. #649
    Gigantic Hawk
    I am 5' 8.5" with about a 29-30" inseam too. My '17 N9 is a medium. A large would be too big for me. The added reach on the '17 helps stretch the frame out while maintaining a lower standover.
  50. #650
    Jan 2013
    Thanks guys, looks like a medium should suffice. That's what I was thinking as I rarely fit on a large. It was just the geo charts threw me off
  51. #651
    Gigantic Hawk
    Now the hard part... what color?
  52. #652
    Jan 2013
    Quote Originally Posted by dubthang View Post
    I've seen some colors I like, brown, green, purple and orange were my favorites... And chrome from the first edition. We will see what colors come up this year. Do you guys know if they are still offering 142x12 kits?
  53. #653
    Aug 2005
    Maiden voyage tonight. Damn, this is a fun hardtail!
  54. #654
    Reputation: coolhand80's Avatar
    Oct 2011
    Just build this up for my brother. First ride is tomorrow. The chrome looks so awesomely fantastic The NEW Canfield Brothers Nimble 9-img_4417.jpgThe NEW Canfield Brothers Nimble 9-img_4418.jpgThe NEW Canfield Brothers Nimble 9-img_4419.jpgThe NEW Canfield Brothers Nimble 9-img_4420.jpgThe NEW Canfield Brothers Nimble 9-img_4421.jpg
  55. #655
    Jan 2014
    Quote Originally Posted by coolhand80 View Post
    Just build this up for my brother. First ride is tomorrow. The chrome looks so awesomely fantastic Click image for larger version.
ID:	1156992Click image for larger version.
ID:	1156993Click image for larger version.
ID:	1156994Click image for larger version.
ID:	1156995Click image for larger version.
    Damn that's pretty damn sexy. Now I need one in chrome
  56. #656
    nice build! i would never sell my chrome, but the ocd in me wants to come at your hoses with a hedge trimmer. HEY BROS LET'S DO BLACK CHROME!!!!!!!
  57. #657
    Oct 2011
    Haha. That made me laugh. The cables definitely need fixed up. Need to get an olive and pin to trim the brake hose. We moved these parts over from another bike.
    The Bros always keep it fresh with these rad colors for the N9
  58. #658
    Jan 2014
    Well they made it in chrome again so I had to have one
  59. #659
    Reputation: cSquared's Avatar
    I prototyped one- It was horrible. Looked so bad in no time.
    [URL="http://www.facebook.com/pages/Canfield-Brothers-Downhill-BikesC2-Components/163956136971393"]
  60. #660
    R Sully- post up a shot of that thing...
  61. #661
    There is another N9 Proto out there-
    Headtube is gorgeous on it. But was 150g heavier than the 44mm.
  62. #662
    Oct 2011
    This bike is too much fun. New bike day for me The NEW Canfield Brothers Nimble 9-img_4512.jpgThe NEW Canfield Brothers Nimble 9-img_4505.jpgThe NEW Canfield Brothers Nimble 9-img_4506.jpgThe NEW Canfield Brothers Nimble 9-img_4503.jpgThe NEW Canfield Brothers Nimble 9-img_4509.jpgThe NEW Canfield Brothers Nimble 9-img_4510.jpgThe NEW Canfield Brothers Nimble 9-img_4511.jpgThe NEW Canfield Brothers Nimble 9-img_4514.jpgThe NEW Canfield Brothers Nimble 9-img_4515.jpg
  63. #663
    Quote Originally Posted by cSquared View Post
    chris, that's not what i want to hear. i do want to know if i'll ever be able to buy holographic decals? every time i see those decals change color it reminds me of the good ol 80's and my schwinn predator. now i'm thinking of gi joe's and thunder cats, damn you c2.
    news flash, black chrome or titanium or what ever you want to call it. do it in a bead blast, like my diety handlebars. i'd call it sinister bling. sure it might hold on to dirt a touch more, but cb buyers are obsessive (ocd) anyhow, they will be washing it all the time.
  64. #664
    nice whip and hella burm
  65. #665
    Oct 2011
    Thanks meng. Glad you approve of my cable routing this time.
  66. #666
    fishwrinkle approved
  67. #667
    Reputation: rsullivan's Avatar
    Here you go Chris!!!!
    Fishwrinkle... hard to see in the pics but the black chrome has a funky look in areas and some areas always look dirty.. other than that it is bad azz with a 15.25" rear end!!!
  68. #668
    Gigantic Hawk
    Photobucket doesn't allow linking anymore.
  69. #669
    what's weird is, i saw rsullivan's pics for a brief time displayed in his post. i now see how big a pita it would be to keep clean. 15.25" stays seems a little too short, but that's based on just one dimension.
  70. #670
    Yeah this was a proto to see how short they could take it and still achieve the desired goal... Made for a rough ride...LOL Never less.. Being the badass that Chris C is... he bombed this frame all the way down the King Kong trail!!!!
    It is amazing though.. I had a 2.4 Maxxis Ardent 29er tire in there slammed all the way forward at 15.25"
    If you click on the "pics" it takes you to them.. not sure why all of a sudden they dont show..
  71. #671
    The stays on that thing- are 16.25-15.25 so I could test the 15.75" length with an SS.
  72. #672
    king kong on a ht is INSANE! yeah i realized it was a proto, but 15.25 is crazy. hey chris could i get the artwork for the n9 so i can replicate them in hologram (personal use)?
  73. #673
    Email us- about the artwork. NP.
    15.25 wasn't the goal. Just that sliders use a 1" length for pulling the SS tight.
    I was looking to test how short can we can go and still feel good.
    Notice that everyone has down to about 16.25" as the shortest. hmmmmmm
    Although, 15.75" that week was awesome on flying Monkey and KK. But maybe only there.
  74. #674
    Mar 2011
    anyone comment on the current frames run in 27.5+ config? What's the bb height with that setup, and how wide of a tire really fits?
  75. #675
    For the gen 2 N9 riders, thoughts on 180mm crank arms? Too long? Or if you do use them, are they ok with both 29 and B+ setups?
    My usual terrain isn't super gnarly. Generally not a lot of extended rock gardens or anything rough that need to be consistently pedaled through so I wouldn't say pedal strikes are a top concern on my list.
  76. #676
    Gigantic Hawk
    Quote Originally Posted by goalieman24 View Post
    I had 175's on mine with both a Niner carbon fork and a 150mm DVO Diamond. I would strike a lot. The problem I had was due to running it ss, and running out of speed in tech areas so I would need to pedal. I run 165's now, and love them. Honestly, I have never seen the draw to 180's.
  77. #677
    Anyone in B+ mode running 2.6 tires? Seems like the general consensus is 2.8, but I came across a deal on some 2.6's that would be great.
    They'd be on 35mm IW rims.
    Is that still enough tire to keep the BB from dropping too much?
  78. #678
    Jan 2011
    SS build crank arm length?
    I'm building up a new N9 Boost as a single speed. I will be switching most of the parts from my Riot onto the N9. Does anyone have experience with the Problem Solvers XD Conversion? Thoughts?
    Also, what crank length are people running on their SS builds? I had 165mm cranks on my Riot, which I will run on the N9 (when geared). I am wondering if they will be too short for SS use or should I run 170s?
  79. #679
    Gigantic Hawk
    Quote Originally Posted by rocketsurgeon View Post
    I'm running CB 165's without issue.
  80. #680
    Jan 2011
    Thanks.
  81. #681
    Gigantic Hawk
    Thanks.
    I actually like 165's better than 175's. There is more ground clearance, and they spin better. I can't tell the difference in torque from different lengths and I'd be impressed with anybody that can. The only negative is that every once and awhile, my forward foot will roll over the pedal spindle due to the shorter length when the pedals are level. The more I ride the shorter cranks though, the less this happens as my body adapts to the closer foot positioning.
  82. #682
    Reputation: vikb's Avatar
    Some N9 action. Not my bike. I was just there witnessing the shred.
    Safe riding,
    Vik
    www.vikapproved.com
  83. #683
    Anyone with a gen2 riding 1x10 with an expander cog in the back? Just added a 40t. Seems to me like there's a lot of angle in the chainline when it's on that cog and was getting some noise up front. Thoughts? I'm running one spacer on the drive side of the BB. Thought about removing that to help a bit but I'm not sure that the chainring would clear.
    Also, what would be causing the chain to jump around on only one cog of the cassette? The 40t rides fine, however the 36t jumps around and seems like it wants to shift. Pedaling in the stand is fine but when I took it for a test spin I noticed it when it was under load. All other cogs are smooth.
    The NEW Canfield Brothers Nimble 9-img_2070.jpgThe NEW Canfield Brothers Nimble 9-img_2069.jpg
  84. #684
    Gigantic Hawk
    All new parts? Or a new chain and 40T with an old cassette? It could be a wear issue. It could also be that the rear derailleur isn't adjusted right. Check your B screw settings.
  85. #685
    Reputation: coleam's Avatar
    Super short chainstays definitely exaggerate chain line issues. And it's rare that the expander cogs shift well, even if everything is new. 10-speed stuff isn't made to handle such a wide range. If you're using an old cassette and/or chain, it'll be even worse.
    Sent from my SM-G950U using Tapatalk
  86. #686
    New chain and derailleur. Cassette is "used", but very low mileage. When it was being used in just 11-36 configuration, the 36 cog was perfectly fine. The derailleur seemed pretty dialed in with hi/low limits and tension shifting through the gears. I thought the B screw was to be adjusted on the biggest cog (which I did)?
    Quote Originally Posted by coleam View Post
    I understand the expander cogs aren't ideal. However, I'm not sure I want to place too much blame on it considering it actually spins great and the derailleur shifts through the entire range very well.
  87. #687
    Gigantic Hawk
    The jump from 36t to 40t will sometimes need B screw tweaking because the upper pulley will not be close enough to the 36 to have enough chain wrap.
    Can you rotate the 40t in relation to the rest of the cassette? Perhaps a different orientation of the teeth will help the chain sit down onto the 36t during shifting.
  88. #688
    Aug 2010
    Is that the 17 matte orange color?!?! Trying to verify the color, thx
  89. #689
    Looking for a MD boost frame to build up.
