Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 101 to 125 of 151
  1. #101
    Reputation: rsullivan's Avatar
    Gouda...sick looking build. Good job on your first venture in the building of bikes... only criticism would be lower the nose your saddle. Starting level would be the best way to go then adjust up or down as preferred.
    Proud owner of the best bikes in the industry!!!!
    www.canfieldbrothers.com
  2. #102
    Reputation: Gouda Cheez's Avatar
    Feb 2013
    My First-ever Build: Yelli Screamy
    Quote Originally Posted by rsullivan View Post
    Thanks. I am really glad you provided that feedback because I have no idea what the 'proper setting' is for a saddle.
    I wish I would've done a bit more myself (had to take to LBS for the headset and the brake hose shortening), but am glad it turned out well. I can't WAIT to get it out on the trail.
    Any feedback around setting sag and rebound? Currently have LSC and rebound set right in the middle and the sag set at about 18-20%.
  3. #103
    That's alright about taking it to the LBS... sometimes if you press the cups in wrong you will damage the inside of the head tube or create stress which could snap the cup on a hard impact. .. As for the brakes. .. unless you have done them before. It will become a nightmare if you get air in the system. .... for the fork settings. ... go on the Sram site and pull up your fork and there will be setup info for the fork vs body weight and settings.... beyond that it will be dependent on trail conditions that you ride
  4. #104
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    It looks great. The Pike makes it look mean. Been following this thread for awhile now. Quick question; are the KOM rim stickers able to be peeled off? Not a suggestion but I am wanting to know before I buy one for my front wheel.
  5. #105
    Feb 2013
    As far as I can tell, the KOM stickers can be peeled off.
    THANK YOU for the feedback.
  6. #106
    Feb 2013
    Forgot to add... The LBS weighed the bike and it came in at 27lbs. Not sure if that's good or not but it's a hell of a lot lighter than my Surly.
  7. #107
    Mar 2011
    You know we are going to need either action pics or at least in the wild once you get it out.
    Post up how the Pike rides, too.
  8. #108
    Feb 2013
    If I am lucky I'll get it out this week after work. If not, next weekend. Can't wait.
  9. #109
    Chris Bling
    Reputation: dustyduke22's Avatar
    Quote Originally Posted by spyghost View Post
    Yes and yes.
    Those washers are discussed in the install manual.
    Assuming your wheels are correctly installed, it could be your calipers arent aligned with your rotors and/or rotors are lightly warped. Both can be easily fixed.
    1 loosen your caliper mounts so they are free to move sideways.
    2 spin your wheel and tighten the bolts bit by bit
    3 where you hear rubbing spot, slightly bend the rotor on that area with an adjustable wrench - flat jaws and lots of leverage
    Cheers
    This vid from Hope is the best way IMO to adjust the Shimano brakes. No spinning the wheel and tightening at the same time voodoo. Watch the vid. It makes me wish I had know this years ago. This is how I adjust all of my customers brakes as well and its great.
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  10. #110
    Chris Bling
    Quote Originally Posted by Gouda Cheez View Post
    Can't wait to hear the ride report. Wheels look nice on there
  11. #111
    Feb 2013
    Thanks, Dusty. Hopefully this weekend.
  12. #112
    Feb 2013
    Rode it this morning... And it was amazing...
  13. #113
    Sep 2013
    Nice! Can't wait to get mine now!
    How did you find it... How far did you ride? Comfortable for XC stuff as well as the fun stuff?
  14. #114
    Chris Bling
    Looks great Chris!
  15. #115
    Feb 2013
    The local loop I do is about 13 miles. That includes a little bit of pavement time to get to the trailhead. Most of the riding is rocky tech stuff. Climbing was pretty similar in feel to most other bikes I've ridden. The downhill is where I was absolutely blown away.
  16. #116
    Feb 2013
    Only mistake so far is that I didn't wrap my chainstay and it got dinged up rather nicely.
    Good news is I caught it now so I can cover it up with some mastic tape.
  17. #117
    Chris Bling
    Lets see some vanity shots
  18. #118
    Feb 2013
    Whatcha looking for?
  19. #119
    Reputation: spyghost's Avatar
    Oct 2012
    Close up perhaps
    Canfield Yelli Screamy
  20. #120
    Chris Bling
    I would love to see some Wheel shots! haha really anything to showcase the build.
  21. #121
    Feb 2013
    I'll work on snaping some pics over the next few days!
  22. #122
    Based on my ride around the block, this bike is amazing. Finished it up this morning and burned the brakes in. Working on setting up my Pike too.
    Which Pike do you have? I am considering adding a Pike 120-150 dual position to my Yelli. Curious about the ride in the longer travel position? Also, does anyone know if the longer travel Pike is not recommended for the Yelli or voids frame warranty?
  23. #123
    Feb 2013
    I have the 140 Solo Air. 51mm offset. I dig it so far.
  24. #124
    Chris Bling
    Chris, you have had a whole week to ride this beast. Now we expect some pictures
  25. #125
    Feb 2013
    Yeah I suck. Lemme get some better shots tonight when I'm bored.
  1. The Help me Build a Yelli Screamy thread
    By SundayRiverRider in forum Canfield
    Last Post: 06-06-2015, 05:49 AM
  2. Yelli Screamy Build Thread: My Wifes First "Real" 29er
    By strangedejavu506 in forum 29er Bikes
    Last Post: 01-16-2014, 05:38 AM
  3. Canfield Bros 'Yelli Screamy' build
    By FatTireGoose in forum 29er Bikes
    Last Post: 08-09-2013, 04:30 AM
  4. Good Donor Bike for Yelli Screamy Build-up?
    By MadMalibu in forum Canfield
    Last Post: 12-28-2012, 07:11 AM
  5. Yelli Screamy for xc?
    By Clink in forum 29er Bikes
    Last Post: 01-06-2012, 10:47 AM
