Page 3 of 4 FirstFirst 1234 LastLast
Results 101 to 150 of 151
  1. #101
    Reputation: rsullivan's Avatar
    Gouda...sick looking build. Good job on your first venture in the building of bikes... only criticism would be lower the nose your saddle. Starting level would be the best way to go then adjust up or down as preferred.
    The Bike Doc LLC
    Official Midwest Canfield Brothers Demo Center
    www.mrpbikes.com
    www.dvosuspension.com
    www.atomikcarbon.com
    www.mtbparks.com
    www.canfieldbrothers.com
  2. #102
    Reputation: Gouda Cheez's Avatar
    Feb 2013
    My First-ever Build: Yelli Screamy
    Quote Originally Posted by rsullivan View Post
    Thanks. I am really glad you provided that feedback because I have no idea what the 'proper setting' is for a saddle.
    I wish I would've done a bit more myself (had to take to LBS for the headset and the brake hose shortening), but am glad it turned out well. I can't WAIT to get it out on the trail.
    Any feedback around setting sag and rebound? Currently have LSC and rebound set right in the middle and the sag set at about 18-20%.
  3. #103
    That's alright about taking it to the LBS... sometimes if you press the cups in wrong you will damage the inside of the head tube or create stress which could snap the cup on a hard impact. .. As for the brakes. .. unless you have done them before. It will become a nightmare if you get air in the system. .... for the fork settings. ... go on the Sram site and pull up your fork and there will be setup info for the fork vs body weight and settings.... beyond that it will be dependent on trail conditions that you ride
    The Bike Doc LLC
    www.mrpbikes.com
    www.mtbparks.com
  4. #104
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    It looks great. The Pike makes it look mean. Been following this thread for awhile now. Quick question; are the KOM rim stickers able to be peeled off? Not a suggestion but I am wanting to know before I buy one for my front wheel.
  5. #105
    Feb 2013
    As far as I can tell, the KOM stickers can be peeled off.
    THANK YOU for the feedback.
  6. #106
    Feb 2013
    Forgot to add... The LBS weighed the bike and it came in at 27lbs. Not sure if that's good or not but it's a hell of a lot lighter than my Surly.
  7. #107
    Mar 2011
    You know we are going to need either action pics or at least in the wild once you get it out.
    Post up how the Pike rides, too.
  8. #108
    Feb 2013
    If I am lucky I'll get it out this week after work. If not, next weekend. Can't wait.
  9. #109
    Chris Bling
    Reputation: dustyduke22's Avatar
    Quote Originally Posted by spyghost View Post
    Yes and yes.
    Those washers are discussed in the install manual.
    Assuming your wheels are correctly installed, it could be your calipers arent aligned with your rotors and/or rotors are lightly warped. Both can be easily fixed.
    1 loosen your caliper mounts so they are free to move sideways.
    2 spin your wheel and tighten the bolts bit by bit
    3 where you hear rubbing spot, slightly bend the rotor on that area with an adjustable wrench - flat jaws and lots of leverage
    Cheers
    This vid from Hope is the best way IMO to adjust the Shimano brakes. No spinning the wheel and tightening at the same time voodoo. Watch the vid. It makes me wish I had know this years ago. This is how I adjust all of my customers brakes as well and its great.
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  10. #110
    Chris Bling
    Quote Originally Posted by Gouda Cheez View Post
    Can't wait to hear the ride report. Wheels look nice on there
  11. #111
    Feb 2013
    Thanks, Dusty. Hopefully this weekend.
  12. #112
    Feb 2013
    Rode it this morning... And it was amazing...
  13. #113
    Sep 2013
    Nice! Can't wait to get mine now!
    How did you find it... How far did you ride? Comfortable for XC stuff as well as the fun stuff?
  14. #114
    Chris Bling
    Looks great Chris!
  15. #115
    Feb 2013
    The local loop I do is about 13 miles. That includes a little bit of pavement time to get to the trailhead. Most of the riding is rocky tech stuff. Climbing was pretty similar in feel to most other bikes I've ridden. The downhill is where I was absolutely blown away.
  16. #116
    Feb 2013
    Only mistake so far is that I didn't wrap my chainstay and it got dinged up rather nicely.
    Good news is I caught it now so I can cover it up with some mastic tape.
  17. #117
    Chris Bling
    Lets see some vanity shots
  18. #118
    Feb 2013
    Whatcha looking for?
  19. #119
    Reputation: spyghost's Avatar
    Oct 2012
    Close up perhaps
    Canfield Yelli Screamy
  20. #120
    Chris Bling
    I would love to see some Wheel shots! haha really anything to showcase the build.
  21. #121
    Feb 2013
    I'll work on snaping some pics over the next few days!
  22. #122
    Based on my ride around the block, this bike is amazing. Finished it up this morning and burned the brakes in. Working on setting up my Pike too.
    Which Pike do you have? I am considering adding a Pike 120-150 dual position to my Yelli. Curious about the ride in the longer travel position? Also, does anyone know if the longer travel Pike is not recommended for the Yelli or voids frame warranty?
  23. #123
    Feb 2013
    I have the 140 Solo Air. 51mm offset. I dig it so far.
  24. #124
    Chris Bling
    Chris, you have had a whole week to ride this beast. Now we expect some pictures
  25. #125
    Feb 2013
    Yeah I suck. Lemme get some better shots tonight when I'm bored.
  26. #126
    Feb 2013
    Btw, how's your Yelli build coming?
  27. #127
    Oct 2013
    Gouda...did you end up having to use any spacers with the crank to get the chain-ring to clear? I'm unsure because my GXP BB doesn't have the ablility to add spacers like the shimano cranks do. I still haven't ordered my chainring, but wondering if i should play it safe and go 28t.....
    Follow my MTB blog...
    http://cdmountain.blogspot.com
  28. #128
    Feb 2013
    Right now I am not running a spacer and my 30T 1x10 setup clears... barely...
  29. #129
    Oct 2012
    How's it like going up hell in a 1x?
  30. #130
    Feb 2013
    Up hell or up a hill?
    Either way I am used to it. My previous bike was 1x so I've been on this type of setup for awhile. I would never go back to anything else.
  31. #131
    Oct 2012
    I call it 'uphell' lol. Still contemplating on 2x for the sake of versatility since I bike both on pavement and trail (ie I don't bring my bike in a rack/car). Im currently running in 3x8 BTW.
  32. #132
    Feb 2013
    I would AT LEAST go 2x10. What kind of trails do you ride? I would consider stuff I ride to be at least a little bit technical and steepish and there aren't many times (maybe 1x a ride) where I wish I had lower gearing.
  33. #133
    Oct 2012
    Pity though shimano only has 2x11 for xtr...
  34. #134
    Feb 2013
    You could always try out a 1x setup by using the middle ring on your current setup.
  35. #135
    Oct 2012
    Yes, did it but tiring.
    I might try 39-26 SRAM with a 42t from oneup or wolftooth.
    Still waiting for a medium ano green YS...
  36. #136
    Jan 2014
    has anyone tried the Shimano 12/36 9 speed cassette on their Yelli?
  37. #137
    Feb 2013
    Here are the long awaited 'vanity' shots. Sorry for the wait.... we've had some wildfires VERY close to home and it hasn't been my top priority to snap pics of the bike.
    Fire smoke for proof:
    Rear wheel, hub, brakes, etc:
    Cassette, derailleur, etc:
    30T Wolftooth and a little bling:
    Front wheel, hub, Pike, and frame shot:
    And a similar shot from the top:
    And proof that I ride it
  38. #138
    Love the blue/black combo! More ride reports please.
  39. #139
    Feb 2013
    I'm heading out again tomorrow to do my typical 13 mile loop. I've put about 40 miles on this thing so far and I absolutely love it. It climbs just as well as my less slack 29er and just BOMBS hills and eats up the chunk like it's no ones business.
  40. #140
    Oct 2012
    Do you ride this on pavement? Whats the feel in a 30x11?
  41. #141
    Feb 2013
    The only time I ride it on the pavement is to the trail, which is uphill so I am in a relatively low gear. I've never ridden in the 11T... ever.
  42. #142
    Chris Bling
    Looks great Chris!
    I love how the hubs just pop!! I will get some pics of my new Yelli up to you can see it
  43. #143
    Feb 2013
    Thanks. I love the black n blue combo. I was pleasantly surprised that different companies 'blue' colors matched.
    How are you liking your YS?
  44. #144
    Sep 2014
    I'm trying to decided whether or not to build a Yelli Screamy. It will be my first build and I'm trying to figure out what the total cost would be. If I purchased the the component package below (see url), does anyone see any compatibility issues with the Yelli frame? Does $400 seem like a good value for the components I'd be getting?
    Full Warranty Complete RaceFace Ride SRAM x9 Type 2 1x10 Conversion Kit MTB | eBay
    Thanks.
  45. #145
    Have you shopped around? I haven't priced all this stuff since I built my Yelli 2 years ago but thought that better deals may be available?
    The issue with the crankset below is whether the 36T will clear the stay, don't know.
    Two links below are like $170 total. I have seen jenson have ridiculous deals on shifters and dearileuers. Maybe $400 is what it all costs, it all starts adding up quickly...
    Shimano ZEE FC-M645 Crankset | Backcountry.com
    Shimano HG81 SLX 10 Speed Cassette > Components > Drivetrain > Cassettes | Jenson USA
  46. #146
    The 36t may take 2 (2mm?) spacers for a 36t to clear depending on what crank you use. It will probably work though. My Slx did with 2 spacers. I would just stay diligent and watch for deals. I'm not sure if that package you mentioned is a great deal or not. The cost adds up quickly. What is your total budget?
  47. #147
    jensonusa has some nice prices on OE cranksets. u can get an OE slx of $100. if OE is okay for you then check their site for OE shifters and mechs. when I buit up my Yelli I think I got the OE shifter for $20 or less and very low prices on the deraileur.
    Shimano Deore M610 Crankset OE > Components > Drivetrain > Cranksets | Jenson USA
  48. #148
    Nov 2012
    Quote Originally Posted by pmd_jr View Post
    Thanks.
    hopefully you've long since built your bike but those prices suck. Chain reaction cycles has Shimano XT level 1x kits that work out to be about 215 bucks for the shifter, RD, Cassette, chain and NW ring. Jenson has Deore crank for $65 and slx and xt can usually be had for 100 and 150 respectively so the answer is, would those components work for your bike, yes. Are they a good value. No, not at all.
  49. #149
    Sep 2014
    Quote Originally Posted by cpfitness View Post
    I dragged my feet for awhile so I only got the frame about a week ago. I priced it out and realized there were better deals to be had on those components than the offering I found. Thanks for the info.
  50. #150
    Hey guys,
    Looking for a bit of build help on my YS. I'm finally ordering parts after waiting for months. On wheels-- Flows or Arch? Tires-- Ardent 2.4/2.4, 2.25/2.4, or something else? My fork is 130mm, but may move it down to 120mm depending on how it feels. I ride XC/Trail and live in San Antonio, so no serious gravity anywhere around, but lots of rocks, roots, and slow technical stuff. It's pretty dry here. Thanks for the help!
  1. The Help me Build a Yelli Screamy thread
    By SundayRiverRider in forum Canfield
    Last Post: 06-06-2015, 05:49 AM
  2. Yelli Screamy Build Thread: My Wifes First "Real" 29er
    By strangedejavu506 in forum 29er Bikes
    Last Post: 01-16-2014, 05:38 AM
  3. Canfield Bros 'Yelli Screamy' build
    By FatTireGoose in forum 29er Bikes
    Last Post: 08-09-2013, 04:30 AM
  4. Good Donor Bike for Yelli Screamy Build-up?
    By MadMalibu in forum Canfield
    Last Post: 12-28-2012, 07:11 AM
  5. Yelli Screamy for xc?
    By Clink in forum 29er Bikes
    Last Post: 01-06-2012, 10:47 AM
