Results 1 to 13 of 13
    Largest tire on Riot?
    Anyone running anything larger on a Riot than the typical 2.35? Seems to be room. Interested in running one of the new Maxxis tires at 2.8 on a 28mm internal width industry nine wheel set.
    Thanks all!!
    Reputation: Raleighguy29's Avatar
    Jan 2014
    I've ran a 2.4 dhr2 on the back mounted to a blunt 35. And had plenty of clearance and no rubbing
    Reputation: savo's Avatar
    Quote Originally Posted by judd1980 View Post
    Thanks all!!
    You have room for a 29x2.5 dhf on i35 rim and some to spare. What are the 2.8s you're talking about? 27.5?
    Sorry, meant either 3.0 or 2.5... in 29er. Guessing there's not enough toom for a 3.0?? Will likely run a 3.0 on the front and a 2.5 on the rear.
    Mar 2014
    2.5 all day, with mud a some wobble in the wheel. 3, no. I tried a knards just for fun, no good.
    Thanks all! Much appreciated. 2.5 it is. Love this bike....
    no way a 3" can fit. maybe a 2.6 NN would, I'd be positive. But 2.5 DHF is a great tire.
    Reputation: noosa2's Avatar
    Quote Originally Posted by savo View Post
    I'm more interested if the soon to be released Rekon 29 X 2.6. will fit in the Riot but am curious if the NN 29 X 2.6 fits too.
    Reputation: TurboWolf 29er's Avatar
    Sep 2015
    Riot with i35 rims an Dhf 2.5
    Do you have any pics of the Clearance on thinking about doing this
    Quote Originally Posted by TurboWolf 29er View Post
    I do not have the Riot any more, but used to ride a 29x2.5 dhf on i35 rim in the rear with no clearance issue at all.
    Sep 2015
    Thanks for the reply. 
    Looking back Hindsight is 20/20 was the ride Quality better on i35 versus i30 are mybe something not as wide would work better? I know the sidewalls stick out a bit and the rims are little vulnerable to rocks. I thinking if I'm going to get new rim laced up i might as well go all in the dive in deep end.
    Oaktown Honkey on Strava
    Any updates to Riot rear tire fit? 2.6 or 2.8? What have people had success with, and which inner width of rim did you use?
    No Dice. I did mine with 2.6 on a KOM i29 rim. It fits, but flexs under moderate cornering. That being said. it measures 2.55" . Maxxis SHorty 2.5 WT measured a true 2.5 and it was fine. same rim.
  1. largest tire possible on a ogre
    By 05kas05 in forum Surly
    Last Post: 02-08-2018, 10:24 AM
  2. Largest Tire for ROS 9?
    By coke in forum Niner Bikes
    Last Post: 02-10-2017, 06:44 AM
  3. Largest tire on a Pug?
    By StuntmanMike in forum Fat bikes
    Last Post: 01-07-2016, 07:10 AM
  4. 1x1, largest 29er tire?
    By leeboh in forum Surly
    Last Post: 11-22-2015, 04:34 PM
  5. What is the largest tire I can use?
    By p08757 in forum Wheels and Tires
    Last Post: 11-15-2013, 06:29 AM
Members who have read this thread: 42
