Results 1 to 5 of 5
    King or Cane Creek For My YS Headset?
    I'm in the home stretch for my parts list for my YS build. A few more pieces to go. I'm looking at headsets now, and the 2 mentioned in the title are my choices. I have a King on my Niner Jet 9, so I'm a little partial. What model of these two should I be looking at that will match well with the YS using a tapered steer tube?
    *2018 Pivot Mach 5.5 Custom Build*
    *2018 Orange Alpine 6 Custom Build*
    *2017 Knolly Warden Custom Build*
    Reputation: riiz's Avatar
    I used the crane creek zs (zero stack) 40, for the top and the crane creek XX 1.5 bottom. I bought both pieces a la carte from pricepoint.com.
    Quote Originally Posted by riiz View Post
    Thanks riiz,
    Just to be clear, are these the items you referred to?
    Cane Creek 40 Zero Stack Top at Price Point
    Cane Creek Lower Headset Assembly at Price Point.......XXc ZSII
    Cane Creek 1.5-Inch Starnut at Price Point
    Quote Originally Posted by kevinboyer View Post
    You are correct on the top half, I went with the tall btw. But the bottom half I went with the normal or non-ZS bottom, which I dont see available. The bottom half of this kit, which I was able to find on JensonUSA, Cane Creek S3/XXII Tapered Headset > Components > Headsets and Spacers > Headsets | Jenson USA
    And you will not need the 1.5 star-nut, the top-half of a tapered steerer uses the 1 1/8" nut that is supplied with the top headset kit.
    Much thanks again riiz. I went ahead and purchased it from Jenson along with another item, and saved money in the process that I can use on something else.
