Results 1 to 2 of 2
    Aug 2010
    Jedi rear cable/hose routing.
    Just had to install my third set of warrantied Saint brakes due to leaking (frustrated side note) on my Jedi and decided to run the hose through the frame in the little holes above the shock. When running it through I noticed that it was scraping the hose while feeding it through so I tried to smooth out those areas a bit.
    Just wanted to know if anyone has any long term riding with their brake hose routed through that hole and if there were any issues like cutting of the hose.
    That is a Canfield accepted and widely used way to route the cables. The newer frames have little cable mounts on the sides now so you don't have you bleed your brake to remove it though. They actually made those holes bigger on the '12 so people could do that. I routed through there on my 11 Jedi with very small holes and had no cable issues to speak of.
    Good luck!
  1. 10/11 Yeti 575 rear cable routing
    By benoksanen in forum Yeti
    Last Post: 03-26-2013, 06:50 AM
  2. cable routing on XX rear derailleur
    By 3fast3furious in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-02-2012, 12:26 PM
  3. RDO build - rear brake cable routing
    By Ronunu in forum Niner Bikes
    Last Post: 11-12-2011, 11:14 PM
  4. EG: alternate rear derailleur cable routing
    By Chris9702l in forum Titus
    Last Post: 11-04-2011, 07:08 AM
  5. Rear Brake Cable Routing Question
    By -chs- in forum Beginner's Corner
    Last Post: 01-03-2011, 04:40 PM
