Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 76 to 100 of 118
  1. #76
    Quote Originally Posted by dfinn View Post
    Also, can anyone recommend a headset. I'm a bit confused with all the different options.
    Cane Creek 40. EC49 for the lower, I forget the upper but I'm sure someone will chime in.
  2. #77
    Reputation: riiz's Avatar
  3. #78
    thanks guys. looks like these 49mm lowers come in different crown race sizes (30.0 & 39.7), anyone know which is normal? going to be using it with a x fusion trace with the unicrown, I checked their site and couldn't find a spec for the race size.
  4. #79
    Canfield Brothers
    Reputation: KillingtonVT's Avatar
    Quote Originally Posted by racerjerm View Post
    Did all pre-orders go out today?
    Sean was packing orders most of the day yesterday. Looks like we have about 20 more that will go out today!
    Thank you all for your patience!
    Cheers
  5. #80
    Canfield Brothers
    The crown race size will be determined by your forks steerer. Straight or tapered.
  6. #81
    tapered so i'm guessing the larger of the two sizes, 39.7?
  7. #82
    YRG
    YRG is offline
    Feb 2012
    dfinn,
    I am undecided about 120 vs 140. I'm gonna start at 120 I think. The forks come in different settings so I didn't have to pay the 10 or 15 to move it. And they are also in the process of producing a tool so it will be easier for us to adjust travel.
  8. #83
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    I spy something beginning with 2013 Yelli Screamy...
    For tapered, you want the 40mm race. Like this one:
    http://www.universalcycles.com/shopp...s.php?id=39954
  9. #84
    Mar 2012
    My little bit of searching shows that with Cane Creek you can use a:
    Tapered Steer= Zero Stack 1 1/8" top section and an External Cup 1.5" bottom section
    Straight Steer= Zero Stack 1 1/8" top section and either an External or Zero Stack 1.5" to 1 1/8" conversion bottom section.
    OR, that an angle set will work with either and that all you do is change a crown race that will facilitate the difference.
    AND that 10 < 40 < 110
    But I don't really understand what all that means.
  10. #85
    Yup, that confirms what I have found as well. I was hoping to use a zero stack headset to run a little more travel in the fork but keep the front end at roughly the same height but I guess there's not enough room in the frame for an ZS headset on a tapered fork. Oh well, no biggie.
  11. #86
    Canfield Brothers
    Ok, let me try to break this down for you. We will be posting this on our site under build specs as well.
    Yelli headtube - Tapered 44mm upper/49.6mm lower
    You will need to decide if you are running a straight or tapered steerer. If you are running a straight, you will need the 30mm crown race. If you are running a tapered, you will need the 40mm crown race.
    The easiest thing do to is to order the upper and lower cups separately. (Cane Creek calls this their headset solutions options.)
    Cane Creek 110 from BTI-USA.com:
    Upper:
    DC-1602 ZS44/28.6 upper 8mm black 53g
    DC-1603 ZS44/28.6 upper 15mm black 60g (The second option has a taller stack height)
    External Stack Lower, this will slightly slacken your headangle and raise your BB:
    DC-1618 EC49/30 lower 12mm black 83g (Straight steerer)
    DC-1619 EC49/40 lower 12mm black 76g (Tapered steerer)
    Zero Stack Lower:
    DC-1612 ZS49/30 lower 4mm black 51g (Straight steerer)
  12. #87
    Mar 2012
    This kind of straight talking customer service is kick ass.
    P.S. Was I right about the Angleset? I was under the impression it was a master of versatility in addition to letting you get all wonky with slackitude.
  13. #88
    Alaskan in exile.
    Reputation: nanook93's Avatar
    Heck, YES! My Y-S frame arrived today, thanks C-Bros.! Thanks also for the headset info, that was the next component I planning to order...
    nanook93
    Ride what you like, like what you ride.
  14. #89
    AOK
    AOK is offline
    Quote Originally Posted by nanook93 View Post
    Pics!
  15. #90
    Alaskan in exile.
    Crazy day yesterday, didn't even get to take it out of the shipping box yet! Couldn't resist a peek though; the anodized blue looks even better in person!
    nanook93
  16. #91
    YRG
    YRG is offline
    Feb 2012
    Quote Originally Posted by jm2e View Post
    Nothing like a company that rides the way you want to and takes care of you the way they would want to be taken care of!
  17. #92
    My L black chrome showed up today. I was a little hesitant with the color choice originally but after seeing it in person I definitely made the right choice. Such a nice looking frame.
  18. #93
    beater
    Reputation: evasive's Avatar
    Feb 2005
    It looks fantastic in the pictures I've seen. Really a slick looking finish.
    "Back off, man. I'm a scientist." - Dr. Peter Venkman
    Riding in Helena? Everything you need to know, right here.
  19. #94
    Add a little fuel to the fire.
    Black Chrome
    Went out on the trails for the first time with this beast.
    I am just coming off a full winter of fatbiking, so this thing is a little rocket right now.
    005 by jonshonda187, on Flickr
    Overcast weather = b&w
    009 by jonshonda187, on Flickr
    011 by jonshonda187, on Flickr
  20. #95
    One More Day.......
  21. #96
    At the front door!
  22. #97
    AOK
    AOK is offline
    I spy something beginning with 2013 Yelli Screamy...-imageuploadedbytapatalk1367365013.817759.jpg
  23. #98
    There was a mix-up with the color. I had originally ordered Wasabi Green, but switched to Blue when I learned Wasabi was no longer offered. I was still shipped a green frame. It's growing on me. I can't wait to hit the trails!!!
    I spy something beginning with 2013 Yelli Screamy...-001.jpgI spy something beginning with 2013 Yelli Screamy...-002.jpgI spy something beginning with 2013 Yelli Screamy...-003.jpg
  24. #99
    Mar 2012
    Raceface Atlas AM Handlebar in PURPLE up on bicyclemob today.
    BicycleMob.com - Today's deal
    Anybody know how well the Raceface purple matches the Yelli Screamy purple?
    Anxiously waiting to pull the trigger..........
    edit- oh yea, they have GREEN too. Looks like it could match the new green, which I ain't got but kinda wish I did because despite all the comments, I think looks pretty dope.
  25. #100
    beater
    Feb 2005
    Chromag purple matches perfectly.
    I spy something beginning with 2013 Yelli Screamy...-imageuploadedbytapatalk1367508921.001976.jpg
