Results 1 to 13 of 13
    Mar 2011
    Fox 34 140 on Yelli
    Who's all running it? Just sold my 100 and ordered a Fox 34 140. Hoping I made the right decision. I know climbing will be a bit tougher but I am hoping I will be more confident on the downhill rough parts.
    2014 Santa Cruz Tallboy LTc
    Trek Farley 8
    iDream Images
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Re: Fox 34 140 on Yelli
    Lotsa people running 140mm forks on Yellis. I don't have any problems climbing on it with a low rise bar & no spacers under the stem.
    It will make the bottom bracket height pretty high, though. If you need the extra ground clearance, great! If not you'll probably notice the higher center of gravity in the corners. I changed mine to 650b wheels to lower the overall height of the bike & love it.
    No moss...
    Mar 2011
    Well with the 100mm I was always having pedal strikes and rubbing rocks. Was getting annoying.
    Trek Farley 8
    iDream Images
    No Clue Crew
    Apr 2005
    Run both 120 and 140. I liked both for different reasons. At 140, the YS is like an enormous BMX bike that encourages you to ride far outside hardtail territory. Bike seemed like a more efficient "all-around" when set at 120.
    The White Jeff W
    Sounds about right
    No moss...
    Jan 2013
    I run a pike 150 on my n9 and love it. I have no complaints about any aspect of the way it rides.
    Sent from my SPH-L720 using Tapatalk
    I run a Fox F34 140mm on my Yelli and it handles like a dream at 140mm. That said, I am selling my Fox to put in a 140mm RockShox. I just like the way RS feels more...
    Ford vs. Chevy... lol
    MTBR Member
    Reputation: ncfisherman's Avatar
    140 is solid and you can always space it down. I'm running a Rev dual-position 140/120, which is quite a good fork to have for the yelli -- the 20mm drop makes a huge difference for climbs on it. A Pike dual-position would be even better.
    I tried the 120, 140 & 150 (Pike),
    The bike handle best on 120 but was also very good on 140, with the 150 I felt that the front was a bit too high.
    Now I have a 130, I think it's OK.
    Mar 2011
    Well bought a fox 34 140 on ebay. Well was told it was 140 but found out it's specd at 130. Didn't realize it till I compared it to my other 140. Anyone ride it at 130?
    Trek Farley 8
    iDream Images
    Keep in mind those F34's use ALL the travel available on the stanchion. My wife has a 120mm Fox F32, and my 140mm F34 only had 10mm more stanchion...
    Mar 2011
    Called fox and gave them the sn and come to find out it's a 34 120!! Never knew they even made a 34 120... Sent it into them to convert to 140 and upgrade to 14 internals
    Trek Farley 8
    iDream Images
    Reputation: eurospek's Avatar
    Quote Originally Posted by Jonesy22 View Post
    It's probably off a Yeti SB95. Those came stock with a 34 120mm.
    konahonzo
  1. Better combo - Two N9s or one N9 and one Yelli?
    By pointerDixie214 in forum Canfield
    Last Post: 10-11-2013, 11:11 AM
  2. The One & the Yelli the Video
    By Scott forty G. in forum Canfield
    Last Post: 01-26-2013, 06:04 PM
  3. Standover and BB on A Yelli?
    By jiggerjake in forum Canfield
    Last Post: 12-16-2012, 09:46 PM
  4. New Yelli
    By briandwyer in forum Canfield
    Last Post: 09-30-2012, 07:01 AM
  5. Yelli 100 or 120?
    By gulljammer in forum Canfield
    Last Post: 06-02-2012, 08:46 AM
