Results 1 to 2 of 2
    Reputation: Calhoun's Avatar
    Nov 2008
    Crampon rebuild info?
    Maybe it is out there and I am unable to find it, but I would love to see a tutorial or even a brief description of how to rebuild my Crampons. What tools, recommended grease and maybe even bearing part numbers.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    To start, remove the outer allen cap, then using a small wall 9mm socket, remove the lock nut holding on to the spindle. You must use a 8mm allen key to hold one end of the spindle. Slide the spindle out of the pedal body, clean, re-grease, re-assemble and ride ! This takes 10 mins. tops. Use some kind of bicycle specific grease. Park poly lube holds up pretty well. Phil wood and dumonde tech do also.
  1. canfield crampon pedals?
    By NicoleB in forum Apparel and Protection
    Last Post: 05-12-2012, 12:21 PM
  2. Canfield Brothers Crampon Pedals - Now with more Photos
    By atomicAdam in forum Downhill - Freeride
    Last Post: 04-14-2011, 07:22 PM
  3. Paid Spam: Canfield Crampon Pedals
    By Jeff in Bend in forum Downhill - Freeride
    Last Post: 02-17-2011, 01:09 PM
  4. Fox DHX air 5.0 rebuild info
    By FrankieBB in forum Shocks and Suspension
    Last Post: 02-01-2010, 11:05 PM
  5. SID rebuild info
    By liteandfast in forum Arizona
    Last Post: 08-14-2008, 09:47 AM
