Page 4 of 5 FirstFirst 12345 LastLast
Results 151 to 200 of 234
  1. #151
    Reputation: rob1035's Avatar
    I agree, a balance would be too much for my riding...
  2. #152
    Reputation: Gouda Cheez's Avatar
    Feb 2013
    The Canfield Rumor Mill
    Quote Originally Posted by savo View Post
    This.
    Whith 29 inch wheels of course.
    A full squish Yelli-type would be amazing.
  3. #153
    Full squish yelli 29'er!Short stays and wheelbase and 130-150mm travel with clearance for the upcoming 27/2.8-3.2 tires would be awesome!
  4. #154
    Quote Originally Posted by mxer View Post
    That'll be tough to manage in the rear without some sort of drivetrain goofyness (wider BB, etc), and probably no option for a front del. (not an issue to me, but might be to some)
  5. #155
    West Chester, PA
    Any updates on the carbon hardtail ? Wife just got a promotion and I'm itchin to spend her money.
  6. #156
    or the yelli squishy?
  7. #157
    Yeah the waiting game is killing me. I'd be happy with either one though I'd probably prefer a carbon yelli screamy.
    Wish list:
    142x12
    Post style rear brake mounts inside the rear triangle
    16.25" chainstays
    Internal cable routing, stealth dropper routing.
    BSA bottom bracket
    Plenty of clearance for 1x drivetrains and a 2.4" tire
    Clearance for one full size water bottle
    I love my wasabi green Yelli but she's due for an update! I pretty much want a the current nimble nine but don't want the 2+lbs weight gain and don't need the SS dropouts.
  8. #158
    May 2012
    I'd much rather see them weld out a Ti N9 frame than carbon or any FS bike.
  9. #159
    Reputation: slo_rider's Avatar
    agree with the last couple of posts--as long as the N9's fun factor carries thru the bloodline, i'd welcome either a carbon yelli or yelli squishy (regardless of frame material).
    in the interim, i picked up a process 111 to compliment my 1st gen N9, and would love to see the bros bring to market a FS 29 that retains the same geo of the N9/YS but with a suspension design that is a bit more active than the 111's.
    i'd actually love it if/when someone builds a short to mid travel bike with a high pivot and idler pulley system (like an AM/trail jedi): rearward axle path could conceivably keep the CS/rear center short (17" or less) since designers aren't as restricted by rear tire/seatstays/yokes hitting the seat tube as they are with rear axles having a vertical or slightly forward axle path, idler pulley reduces many of the chaingrowth and unwanted drivetrain-rear suspension interactions, and exclusive use of 1x drivetrains eliminates the funkiness that plagued idler pulley/front derailer combinations from other builders in the past.
    hmmm... given the crazy high prices of production bikes today, maybe it's time to talk to a custom builder to see if it's feasible to build a FS N9/YS with rearward axle path/idler pulley rear suspension.
  10. #160
    I also have a Process 111 and a Canfield (Yelli Screamy). I'd love to see the same thing. Those two bike compliment each other well. Seems like there is a lot of money to be made in the short travel, agressive geo fs category. I could pretty much guarantee that they would sell every frame on pre-order if they made a 120mm 29er with Yelli/N9 geo.
    I picked up the Process because it was the closest thing to a Yelli FS I could find. The bike is great but has its flaws. First of all it is a hefty beast. My size large frame weighed over 8lbs. I have a pretty tricked out lightweight X01 build and it's still about 31lbs.
    You should try out a DB inline shock on yours. I just put one on my Process and it's a drastic improvement to the suspension.
  11. #161
    Quote Originally Posted by rusty904 View Post
    I also have a Process 111 and a Canfield (Yelli Screamy). I'd love to see the same thing. Those two bike compliment each other well. Seems like there is a lot of money to be made in the short travel, agressive geo fs category. I could pretty much guarantee that they would sell every frame on pre-order if they made a 120mm 29er with Yelli/N9 geo...
    I agree. Maybe the bros should trademark "short-aggro" before the big S claims they invented the concept in a few years and sues the pants off everyone else for trademark infringement ;^)
  12. #162
    Reputation: Pau11y's Avatar
    You know what I'd like to see...
    A true AM rated stoutiness, 160mm travel, carbon, 29er, w/ a low-ish leverage ratio, ~13.7" BB height w/ a set of 2.5/2.3 DHF/DHR2s, that uses the same suspension design as the Balance.
    I like to trail ride too, I like wagon wheels, and I like squish. Oh, and not so short on the rear stays so the thing can be a techy climbing beast!
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
    ╭∩╮( º.º )╭∩╮
  13. #163
    NWS
    NWS is offline
    Jun 2010
    I want a 180mm AM bike (26 or 27.5, no care) with as much rearward wheel travel as can be accommodated with a 1x drivetrain and a long-cage rear derailleur. Call it the Jedi Lite. Aim for 30lbs with air fork / air shock and a nice build 35lbs with air and a mid-range build.
    Actually.... On a completely unrelated note, consider dropping the "Jedi" name before George Lucas' lawyers find out.
  14. #164
    Reputation: jhill's Avatar
    Quote Originally Posted by NWS View Post
    Isn't that essentially The One?
  15. #165
    Reputation: kameraguy's Avatar
    The Balance is awesome. If there can be a Balance Carbon, that would be awesomer Same bike, just in carbon. Maybe builds that can hit around 25-26lbs without much effort?
  16. #166
    NWS
    NWS is offline
    Jun 2010
    I dunno, how much rearward wheel travel did The One have?
    I never saw one up close but from looking at the design it seemed like the travel arc was not much different from a typical single-pivot setup.
  17. #167
    Reputation: savo's Avatar
    Come on Canfield guys...
    tell us something about the FS 29er!
  18. #168
    NWS, you're correct--axle path for the one was more or less vertical , as discussed on post #18 of this thread.
    It's hard to eyeball multilink/virtual pivot designs (whether w short linkages like Canfield/DW/VPP/Maestro or longer linkages like FSR/Horst) and guestimate axle path. But for single pivot designs, then as long as the pivot is above the rear axle, the axle path will be rearward as the rear axle moves thru it's arc, until the axle reaches the same height as the pivot.
  19. #169
    120mm Yelli, 7.5 lbs WITH shock, sub 16.7 stays, 68 HA. Lenz Behemoth pretty much has this bike with a little more travel. I had a Lunchbox and cant say enough about that bike, I beat the hell out of that thing. I love Canfield these days so i'm hoping for the Squishy!
  20. #170
    150mm rear dropouts would be great for the Yelli Squishy.
  21. #171
    J:
    J: is offline
    Fun with dirt
    Reputation: J:'s Avatar
    Dec 2009
    [QUOTE=savo;11506279]Come on Canfield guys...
    ^^this x ∞
    Aluminum...w/ extra sauce
    turkey mash gravy pie = yes please
    Last edited by J:; 10-14-2014 at 10:11 AM. Reason: + s'extra sauce to my order pls!
  22. #172
    Quote Originally Posted by confused View Post
    Perfect. Exactly what I'd want. A more refined Kona Process 111 with a tad more travel.
  23. #173
    Reputation: jkidd_39's Avatar
    Sep 2012
    How about a cyclocross nimble 9 frame? Mines hefty @ 26# for running barriers.
  24. #174
    Reputation: Stopbreakindown's Avatar
    Is it time?
  25. #175
    Quote Originally Posted by Stopbreakindown View Post
    ...to let the cat out o' the bag? hell ya, it's time!
  26. #176
    Quote Originally Posted by slo_rider View Post
    yep, definitely!
  27. #177
    Reputation: bigcrs's Avatar
    I'm probably wrong, but when the bros are this quiet about something it usually means that they'll have something to announce in couple of months or so.
  28. #178
    Reputation: Swissam's Avatar
    Carbon Balance!!
  29. #179
    Quote Originally Posted by jkidd_39 View Post
    You have no idea how many times I've asked for a Canfield cross bike. I'd even sell my carbon Crux. Think of how sexy ano aluminum frames with an Enve fork would be.
  30. #180
    Sep 2012
    Quote Originally Posted by Vertr View Post
    I just ordered a Transition Rapture so that's about as close as I can get. I'm so ready to build it up.
  31. #181
    Nov 2007
    Quote Originally Posted by Swissam View Post
    Carbon Balance!!
    +1!
  32. #182
    i agree--a cross bike from the bros would be very cool and i'd love to see a stealthy frameset decorated with nothing more than their headbadge on the head tube. the only frameset that i still regret selling was my indy fab steel planet x--it may have been the best do-it-all bike i've ever owned for the combo of street, fire roads, and mellow single track. but despite their versatility and growing popularity, it's probably still too much of a niche market for them to jump into.
  33. #183
    Reputation: rsullivan's Avatar
    Oh man.... Just what I need.....another bike!!! Com'on Bros.. I need another bike to build up for the Demo-Stable!!! Personally I'd like to see a 4-5" travel single pivot Slope style bike similar to their Kids DH bike. I love the DJ but could use the travel...lol
    The Bike Doc LLC
    Official Midwest Canfield Brothers Demo Center
    www.mrpbikes.com
    www.dvosuspension.com
    www.atomikcarbon.com
    www.mtbparks.com
    www.canfieldbrothers.com
  34. #184
    God damn it, where's the 29er version of the Balance!
  35. #185
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Re: The Canfield Rumor Mill
    Quote Originally Posted by bigcrs View Post
    Ya what he said! I want a full suspension nimble or yelli
  36. #186
    The silence is defining, it's driving me nuts. Time for some info brothers & co!
  37. #187
    Fully version of the yelli/nimble.How about some teaser pics?
  38. #188
    West Chester, PA
    Carbon hardtail dammit !!!
  39. #189
  40. #190
    Quote Originally Posted by 92gli View Post
    Yes, this. I would IMMEDIATELY order a carbon Yelli/Nimble9.
  41. #191
    +1 don't think they'd have trouble selling out immediately.
  42. #192
    J:
    J: is offline
    Fun with dirt
    Dec 2009
    What's up with this new rig? Cross bike ? Full suspension 29r? tell me more...
    HAPPY THANKSGIVING!
  43. #193
    a 5 inch full suspended 29er with rear clearance for a 650b+ tire... please :-)
  44. #194
    a year ago, Vin posted this tidbit:
    Quote Originally Posted by KillingtonVT View Post
    ...Our 29” FS is also in the works with the hopes of a fall/winter 2014 release.
    Thank you all for your patience... Vin
    some big "ifs", but...
    • if its geometry is as close to N9 or Yelli as possible,
    • if it can fit a 27.5+ tire,
    • and if it's available in spring 2015
    then take my money please, so i can pre-order a frameset now
  45. #195
    I'd be ready to place a pre-order too...
  46. #196
    Sep 2012
    I just spent some time on a salsa bucksaw and I was rather impressed. Fitting a 27.5+ would be frickin amazing after what I saw this weekend.
  47. #197
    This please!
    Gonna sell the yelli to make room for the new fs 29'er.
  48. #198
    I just put my name on my list for a custom By:Stickel steel hardtail. It will basically be an N9 with a sub 5lb frame weight, stealth dropper routing, and a 142x12mm axle handmade in WNC. Got a bit of a wait ahead of me but I had to brag about it somewhere!
    So here's hoping for a full suspension Yelli/N9! I will be slightly pissed if a carbon yelli comes out in a couple weeks.
  49. #199
    rusty: Steve's frames are so sick, I am super jealous!
  50. #200
    Quote Originally Posted by rob1035 View Post
    Yeah I've admired his work for a while and sent him a speculative email a couple weeks ago. He totally sold me with his pleasant response including an invite to come out and ride and tour his shop (hopefully this weekend!) so he can get a feel for my riding style and what I might want in the frame.
    Needless to say, I'm pretty stoked to have one of his ride-able works of art made in my backyard!
  1. 650b rumor mill
    By Kirk Pacenti in forum 27.5
    Last Post: 01-19-2012, 03:32 PM
  2. Santa Cruz Rumor Mill
    By brainbckt in forum Santa Cruz
    Last Post: 10-31-2011, 07:54 PM
  3. So no Ray's MTB rumor mill here yet?
    By k1creeker in forum New York - New Jersey
    Last Post: 07-20-2011, 02:55 PM
  4. Yeti Rumor Mill
    By brandonj1979 in forum Yeti
    Last Post: 06-07-2011, 04:35 PM
  5. Replies: 39
    Last Post: 02-26-2011, 07:16 AM
