Results 1 to 43 of 43
    Mar 2016
    New question here. Canfield Riot SIZING - please post your frame size and height (and inseam)!
    I've sifted through the 125+ pages of the Riot thread and thought that this will probably merit a separate thread:
    If you have a Canfield Riot 29er, please post your frame size and your height (and inseam if available)
    I'm on the fence about purchasing a Riot (coming from a Yeti SB95), but I think I might be in between sizes, and I'm sure that others may have this question as well
    Mar 2014
    6ft, 32"seam, large G1 with the 20" seat tube. 125mm reverb is perfect with like 3mm of extra post showing. Trust the Bros.
    I'd like the shorter 19 seat tube....but it doesn't really matter. Love my Riot, fits great and makes me a better rider.
    Reputation: jon23's Avatar
    Jul 2015
    Send them an email with your size and they will give you their suggestion. I went with an XL on their suggestion, 6'3", 37" cycling inseam (34" pants inseam).
    He who forms the mountains...the LORD God Almighty is his name. Amos 4:13
    2016 CB Riot
    2015 Trek Superfly
    Reputation: slider_phil's Avatar
    Aug 2014
    5'9" with a 32.5" cycling inseam on a medium. Have a 125mm reverb but could run a 150mm. Fits perfectly running a 50mm stem
    Pic for seatpost reference
    Reputation: bigcrs's Avatar
    6'2", 32" inseam, large frame. I went from a 40mm stem to a 50mm, much better fit now.
    A lot of people had a hard time getting their heads around the numbers. And if you let it get to you you'll have the same problem. A headache that can be avoided. You already know what mostly works for you, take what you know and talk with the Bros.
    Reputation: mayha's Avatar
    Mar 2012
    Not sure what my inseam is exactly but I'm 6 ft on a large with a 35mm stem and it is perfection.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    6'1" on large and 50mm stem.
    6'1"- Large Riot w/ 35mm stem.
    6'1" large 1st gen. riot - 50mm stem - 125mm dropper post - I wear 34" length pants haha. Fits like a glove.
    Reputation: Joules's Avatar
    6'4, 38" cycling inseam. XL gen1 frame, 50mm stem, 150mm LEV with about 30-35mm room below the collar. I think the gen2 frame would let me run the 200mm 9.8 if that ever ships. Still real happy with the fit.
    I'm hanging out for the 175mm 9point8. I've would have roughly the same available space, maybe a bit more, if I was running a 150mm dropper.
    Canfield Brothers
    Reputation: flymybike's Avatar
    6.0, 32" inseam. 50mm stem, 125 dropper post. Large size, I could go 40mm stem but 50 is better for the longer rides.
    Kaylon, whats your height and inseam? We have lots of sizing info to get you the right size.
    http://www.canfieldbrothers.com/frames
    Building bikes that make you smile!
    www.mtbparks.com
    All Bike Park, All the time.
    Reputation: Colin+M's Avatar
    5'11 with a 34.5 inch cycling inseam. 78 cm saddle top height measured from center of BB.
    Gen2 size Large with 19 inch seat tube. Running a 150mm Turbine dropper with plenty of room for a 175mm.
    40mm stem, could easily do a 30mm or 50mm depending on position desires.
    The Riot is head and shoulders above the SB95. I had both the alloy and carbon SB95, so I speak from saddle experience. Just do it, you won't regret it
    Attached Thumbnails Attached Thumbnails Canfield Riot SIZING - please post your frame size and height (and inseam)!-p2120860.jpg
    Feb 2005
    Did you swap out your Gen1 frame?
    Quote Originally Posted by jaks View Post
    My shock alignment was outside of Canfields tolerances and they exchanged it once the new batch came in. Best customer service in the business!
    Sent from my D6708 using Tapatalk
    Mar 2016
    New question here.
    Quote Originally Posted by Colin+M View Post
    How does the Riot climb vs the SB95?
    What fork offset did you have on your SB95 and what size was your SB95? How much do you weigh out of curiosity?
    Also were you able to swap your build kit over?
    Quote Originally Posted by flymybike View Post
    I'm on a SB95 L and I think I am supposed to get a Riot in L, but I've got two bikes and its also an internal debate about which one to replace/update first
    Would you happen to have a sizing chart? Specifically what are the sizing ranges?
    Quote Originally Posted by slider_phil View Post
    Thanks for all the replies so far everyone! But please keep them coming! Also so that this thread is useful for everyone looking to buy one of these, is there anyone on any of the smaller sizes?
    K
    Reputation: rsullivan's Avatar
    6,1 with 32 inseam... riding a gen 2 large with a 150 dropper and 50mm stem... feels right... owned a first generation also but that went to a buddy when my custom one arrived...
    Quote Originally Posted by Kaylon View Post
    K
    Size large SB95.
    The Yeti felt like a firm XC bike to me, wanted to love it but never did.
    The Riot climbs nicely as does the SB95, but the Riot climbs in the tech stuff much more easily and has minimal pedal kickback compared to the Yeti.
    Size large SB95.
    I love the Riot. But, I spent 4 years solid on the alloy SB95 on all types of terrain. In my opinion, the most impressive aspect of the 95 was its climbing efficiency. That bike climbs like a total beast, with very little-to-no pedal bob and excellent tech climbing abilities. I'll humbly disagree with Colin on this.
    I think the Riot is a very good climbing bike for 140mm rear travel, but I definitely notice that it is not as efficient as the 95 (only ~125mm rear travel).
    But, of course, it's a hell of a lot more fun descending, and has much, much more modern/aggressive/progressive geometry than the 95 (head angle, chainstay length, reach, etc).
    If you're looking for a more aggressive bike than the 95, the Riot fits the bill. If you want something in the exact same class, maybe look elsewhere (probably one of the shorter travel 29ers out these days, Transition Smuggler or Kona Process111, for example).
    PS - I'm a Large on both frames, no question. If youre a Large on the Yeti, probably a Large on the Riot too).
    No need to disagree. I'd say the Yeti is more efficient/firm in the suspension department undoubtedly.
    Reputation: jbsocal's Avatar
    5'7" with a 27-28" inseam riding a gen 1 small Riot 50 mm stem and a 150 mm KS Lev TI.
    I would like to try a medium with a short stem to feel the difference...
    18 Marin Wolf Ridge Pro
    '17 Specialized E29 S-Works
    '17 Canfield Brothers Riot
    '13 Banshee Prime (29+)
    Dec 2015
    5.11 ft with 31 inseem. GEN1 Large frame with 1 inch taken off the seat stem. 75mm giant dropper seatpost all the way down. 35mm stem with 780mm bar
    Wonder if its too large for me.
    Reputation: acfsportsfan's Avatar
    6'-0, 34" inseam. Large Riot with 50mm stem with 20mm of spacers & 800mm Enve DH bars. 170mm RF crank arms with Canfield Mountain pedals & 150mm RF dropper seat post. Feels great to me.
    I'm 5'11" with a 32" pants inseam, will a first Gen large be too big?
    Reputation: wooly88's Avatar
    5'10". Riding a v2 large with a 40mm stem and 780mm wide bars.
    5'6". Small and 35mm stem, 780mm bars. I'm a little bit tight on the climbs, (50mm would fix this), but I really like the way the bike handles with the 35mm.
    Canfield Riot SIZING - please post your frame size and height (and inseam)!-vin-riot.jpg
    Oct 2015
    Double post
    Oct 2015
    Quote Originally Posted by KillingtonVT View Post
    I'm the same height. What is your inseam? Crank and dropper length?
    Quote Originally Posted by Cerberus75 View Post
    28" inseam, 125mm dropper, cranks - I'm changing out all the time. I have 170mm Next SL's in the image above, currently on our cranks/165mm's that I'm much happier with.
    Oct 2015
    Thanks, if you said you weight 195 we could be twins, lol
    Seeing what I can transfer over from my bike to this frame over the winter. Using 165mm cranks (yes better on knees and droping weight quicker in turns) with a 125mm dropper. This helps a lot!
    Jan 2015
    5' 10" with 32 inseam pants running a v2 large frame with 35mm stem and 780 bars. 150mm dropper post.
    May 2013
    5'10" 32.5" cycling inseam
    I ride a large G2 Riot with a 150mm KS LEV, 35mm stem, 785mm bars.
    The LEV is slammed in the seat tube and it's the exact height I need.
    Feb 2015
    6'1" with 35 inseam on an XL. 165mm cranks, 32mm stem, 800 bar and 150mm fall line dropper. Feels perfect to me standing and seated. I might be able to squeeze in a 175 dropper also.
    Jan 2015
    going off sizing if anyone wants to go to a 150mm dropper let me know :
    If anyone is looking for a 150mm dropper let me know. With the help of canfield i got hold of a rep and got my raceface dropper post warrantied. Long story short due to the lot number they sent me a whole new post vs rebuilding it.
    You will get a new dropper post just without the cable or housing as they told me to leave it on the bike.
    After a week without the bike wait time i purchased another one and figured i would just sell the new one when i got it back to prevent down time.
    PM if you want it ($250 plus shipping, so $270)
    Rider/Builder/Hacker
    Nov 2015
    Calling all 5'10" or so Riot owners on a large...
    Any regrets on going with a large over a medium?
    I don't have any major downhill terrain to contend with in my area, and the trails tend to be more twisty, with shorter rooted climbs. My main concern is not being able to properly weight the front wheel on aggressive turns.
    Any feedback would be appreciated.
    I'm 5'10" and had a large. Couldn't imagine having a medium.
    Reputation: mint355's Avatar
    Mar 2012
    Large 5'11" and 35"
    Sent from my SM-G925I using Tapatalk
    Reputation: titusquasi's Avatar
    XL w/ 60mm stem
    6'3"
    Uhhh...inseam around 35"
    Wish the stack height was taller. Other than that, fit is great.
    Gen 2 size Large
    5'9" with a inseam of 32"
    Seat slammed forward with a 35mm stem. 125 dropper length. Could have gone medium but happy with large frame with adjustments made
    Jun 2013
    Does anyone else have experience with a 175mm dropper in the gen 2 Large frame? I'm 5'11" with a 32inch inseam and trying to measure if I can get a 170mm Reverb or 175mm RF or 9point8.
    Reputation: yogidave's Avatar
    Kaylon... same here... I just broke the rear end of my size L yeti SB95 carbon and it's very expensive to replace and the bike is 3.5 years old, so....
    Looking at Canfield riot, banshee prime, etc.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Reputation: JimmyC's Avatar
    Dec 2005
    I am 5', 11" with a 32-inch inseam. I ride a size large with a short 31 mm stem. I like a more upright position but the reach on the large frame feels great for me.
    Oaktown Honkey on Strava
    5' 6.5" Inseam is 31.5 inches. I ride a Medium.
    I bought a 50mm stem for this build 2 months ago, should have bought a 60mm for a tad more room. I am loving 160mm Bikeyoke dropper post, but bypassed seat tube hole, and run cable out the bottom. Try THAT carbon fanboys. Ha. Canfield Riot SIZING - please post your frame size and height (and inseam)!-img_2904.jpg
  1. Canfield Riot
    By Blatant in forum Arizona
    Last Post: 02-18-2016, 05:10 PM
  2. 6' with 29.5" inseam size frame ?
    By Richard_Brown in forum Specialized
    Last Post: 01-24-2016, 05:27 PM
  3. New Canfield Riot 29
    By dustyduke22 in forum 29er Bikes
    Last Post: 11-08-2015, 07:46 PM
  4. Height, inseam, bike model, bike size, wheel size
    By laine in forum Women's Lounge
    Last Post: 09-08-2015, 07:37 AM
  5. 5ft 8in; 30in inseam; bike frame size? Please help!
    By bsfswisher in forum Beginner's Corner
    Last Post: 04-24-2012, 08:27 PM
Members who have read this thread: 55
