Page 9 of 9 FirstFirst ... 56789
Results 801 to 872 of 872
  1. #801
    mjw
    mjw is offline
    Feb 2007
    Is there any consensus on DVO Topaz shock setup? I.e. volume reducer bands and such? What are people running? Is there a good place to start the tune?
    • 2015 Kona Explosif Ti
    • 2015 Kona Process 111
    • 2018 Canfield Riot
  2. #802
    Chris Bling
    Reputation: dustyduke22's Avatar
    Quote Originally Posted by mjw View Post
    Call up DVO and ask. They are more than willing to help and give you some pointers.
    Sent from my SPH-L720T using Tapatalk
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  3. #803
    Reputation: noosa2's Avatar
    Quote Originally Posted by yogidave View Post
    Dumb (?) question, but how did you fit a boost rear wheel in a non boost frame? Brute force?
    Slides right in like it was spaced for a boost hub. Dropped in my standard 142mm hub and there was lots of slop.
  4. #804
    Reputation: mayha's Avatar
    Mar 2012
    Does it feel 12% stiffer?
  5. #805
    Quote Originally Posted by mayha View Post
    That's what the "experts" say but the only reason I went with a boost hub on the Riot is because that is the wheel I have that is not currently on something else.
  6. #806
    Reputation: yogidave's Avatar
    And just like that... I'm a Canfield Riot rider (or will be as soon as trails are not muddy)
    Frame: Canfield Brothers Riot, size L (2017) Raw finish with anodized orange links
    RockShox Monarch Plus RC3
    Invisi-taped,
    Weight 8.8lbs (frame, shock, headset, axle, seat binder)
    Fork: Fox 34 Factory 140 CTD (from previous bike), new orange stickers
    Wheels: Nextie NXT29AM36 Carbon rims (29mm ID)
    Sapim Race spokes 32 3x f/r, blk alloy nipples
    DT Swiss 240 Hubs with 36t star ratchet
    Maxxis DHFII 2.5WT front (1015gr)
    Maxxis Aggressor 2.5WT rear (980gr)
    650B+ on the horizonÖÖÖÖ..
    Brakes: SLX w 180/180 IceTech rotors, fin pads
    Drivetrain: XT 1x11 w/ 11/46
    XTR crank with 32t raceface NW ring
    Cockpit: RaceFace Atlas 35OD x 40 Stem
    RaceFace SixC Bars cut to 775mm
    Diety Knuckleduster grips
    KS Lev Integra 150mm dropper
    Specialized Henge 143mm saddle
    XT Trail pedals Pedals
    Total weight: 32.42lbs with pedals (like, cuz you canít ride without them)
    Attached Thumbnails Attached Thumbnails Canfield Riot Photo Thread-20180125_141712.jpg
  7. #807
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I run that same tire combo and really like it.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
  8. #808
    Reputation: Raleighguy29's Avatar
    Jan 2014
    Frame:Canfield Brothers Riot, size L (2017) Raw finish with anodized orange links
    Invisi-taped,
    Fork:Fox 34 Factory 140 CTD (from previous bike), new orange stickers
    Wheels:Nextie NXT29AM36 Carbon rims (29mm ID)
    Brakes:SLX w 180/180 IceTech rotors, fin pads
    Drivetrain:XT 1x11 w/ 11/46
    Cockpit:RaceFace Atlas 35OD x 40 Stem
    Total weight:32.42lbs with pedals (like, cuz you canít ride without them)
    Nice build man.
    Love the raw.
  9. #809
    I'm loving the new ride.
    Sent from my XT1060 using Tapatalk
  10. #810
    Hiking is good for you.
    Canfield Riot Photo Thread-mtbr-test-riot.jpgCanfield Riot Photo Thread-mtbr-test-riot.jpg My build from the Canfield Bros. frame sale.
    Parts Brand Model Additional info
    Frame Canfield Brothers 2017 Riot Blue links 140mm
    Rear Shock DVO Jade 450 lb. spring
    Fork DVO Diamond 140mm
    Headset Cane Creek round
    Handlebar Chromag BZA 35mm carbon
    Stem Chromag HIFI Stem 35
    Grips ODI Rogue Lock-On
    Brakes Shimano XT
    Brake Levers Shimano XT
    Shifters Shimano XTR
    Rear Derailleur Shimano XT 11 speed
    Chainguide MRP AMg V2
    Cranks SRAM X1 1400
    Chainrings / Sprocket Blackspire oval
    Bottom Bracket Other RWC
    Cassette / Rear Cog Shimano XT M8000 11-46
    Pedals Other ORIGIN8 ULTIM8
    Front Rim Other Spank Oozy 29"
    Rear Rim Other Spank Oozy 29"
    Hubs Hope Pro4 Black
    Spokes DT Swiss
    Front Tire Maxxis DHF
    Rear Tire Maxxis DFR
    Saddle Other Ragley
    Seatpost X-Fusion Manic 125mm
    Seatpost Clamp Nukeproof
    General Info
    Model Year 2017
    Riding Type Trail / All-Mountain
    Weight 33 lb 0 oz (14969 g)
    Was stoked to get Bike of the Day on VitalMTB
    Hiking is good for you, especially with a bike.
  11. #811
    Saw yours on the bike of the day, looks great!
  12. #812
    Office was closed on Friday for construction, so after a grueling 1/2 day of working from home, I took my emotional support animal for a ride.
    Riot in backgrou
  13. #813
    Recon2.6 with i32mm rim.
    Teravail with this rim is no go again, due to touch to non-drive side chainstay.
  14. #814
    is that a 29 2.6? Im running the 27.5 2.6 recon with no issues on mine and really like the tire, I would like to build up a set of 29's in the spring..
  15. #815
    Quote Originally Posted by dbnickles View Post
    Yes, it is 29 one. Itís OK without any contact.
    I believe ďthe bigger(diameter), the betterĒ.
    minimalized chainstay, maximized tire size, what a perfect bike!
  16. #816
    Apr 2014
  17. #817
    Mar 2012
    Quote Originally Posted by tsurun View Post
    So, the "Teravail" is a no go but the "Rekon" is good to go on that same rim? I was considering something like this for the Nimble 9...Probably need carbon rims to avoid the flex/rub.
    I put my old Pike on the Nimble and bought the 2018 Pike and a roll of orange vinyl for some custom decals. Yeah, a bit over the top...Supposedly less need for tokens and a slightly better small bump with the new Charger 2 cartridge.
    Attached Thumbnails Attached Thumbnails Canfield Riot Photo Thread-31226.jpg
  18. #818
    mjw
    mjw is offline
    Feb 2007
    Mine!
    Medium Riot
    DVO Diamond/Topaz
    Turbine cranks and stem, absoluteblack oval ring
    SixC Bar
    Hope E4 brakes
    Privateer Wheels house brand rims on 240s hubs, d-light spokes
    Maxxis Forkaster 2.35 f&r
    9.8 dropper, SGS seat
    XTR shifter/derraileur
    Cromag grips
    Cane creek 40 carbon headset
  19. #819
    Reputation: Dr Gigi's Avatar
    Nov 2016
    Between a broken collar bone and a newborn at home, it's taken me 3 months to finally build this beast up. After her maiden ride, all I can say is wow!
    Canfield Riot Photo Thread-20180225_110033_resized.jpgCanfield Riot Photo Thread-20180225_110118_resized.jpg
  20. #820
    This is the terrain I ride in on the Big Island of Hawaii. Young island geologically so we hardly have any dirt. A lot of rooty, technical lava.
    How does the Riot ride?
    Dang! Best bike I've ridden in this type of terrain so far.
    Rear stays planted at speed, bike doesn't do anything funky like wander off line, climbs great so far.
    Combined with the 29 wheels rolling over everything like a Monster truck.
    Attached Thumbnails Attached Thumbnails Canfield Riot Photo Thread-g0033398.jpg
  21. #821
    Yes it is, and NN2.6 also fit as here knows. I felt if TeraVail has perfectly straight(no twist) quality, it may possibly...
    I carefully tried bead-up twice with soap but slightly twisted when rolling the wheel.
  22. #822
    Apr 2014
    Historic view #Acropolis #Athens #MTBonly
    20180226_212133 by Darksoul, on Flickr
  23. #823
    Oct 2016
    Sunset ride
  24. #824
    Winter in the Rocky MTNS?
  25. #825
    Easter ride
  26. #826
    Reputation: OwenM's Avatar
    Oct 2012
    Love this thing more and more as time goes by, and have no desire for anything else.
    People probably think of fast trails with jumps and drops when the Riot comes up, but I think it's handling makes it great for rough, tight and twisty trails with no flats, too.
  27. #827
    Mar 2012
    I agree... best bike I've owned
    https://youtu.be/16YMZz3Ta6c
    Amazingly versatile
  28. #828
    Aug 2010
    Quote Originally Posted by OwenM View Post
    How do you like it SS?
    Is that a Rohloff tensioner?
  29. #829
    Apr 2014
    amazing bike for sure!
    check it
  30. #830
    Mar 2012
    Very sweet vid Darksoul! Ripping Greece
  31. #831
    Apr 2014
    thanks mate!!
  32. #832
    Oct 2015
    Those are the type of trails I ride. And it's a great bike with its quick handling.
  33. #833
    Oct 2012
    Quote Originally Posted by racefit View Post
    It's the Rohloff XC/SS tensioner.
    As far as the suspension goes, I don't notice any bob, if that's what you're asking. The trail I ride most is so bumpy, the increased traction and impacts being soaked up by the rear suspension would far outweigh it, even if I did. Got some injuries that have turned the FS vs HT debate into riding vs not riding, so it's a moot point for me.
  34. #834
    Aug 2010
    Do you feel you need the chain guide as well?
    Iím in the early stages of researching FSSS , but some have mentioned getting the DH version of the Rohloff is better for chain tension.
    Yes I meant in terms of pedal bob.... I donít have any physical issues at the moment, but am thinking ahead that FS may extend my riding days. Being an SS lover Iíve always feared that going FS would be the end of SS, but this gives me hope.
  35. #835
    Love this bike!
  36. #836
    Oct 2012
    Need, no, but I'm ok with anything that minimizes chain slap and maximizes chain wrap. I've used that thing with both clutched and non-clutched derailleurs when running gears, too, so it's a habit.
  37. #837
    Jun 2012
    Are the Rekon 29x2.6 still working out for you? I just built up some i32 29" wheels and I'm looking at running the same tire. On the chainstays it looks like it is about the same as my 2.8 27.5's but in your pics it sure looks tight up to the front of the swingarm. Any issues?
    2017 Canfield Riot
  38. #838
    Quote Originally Posted by StumpyandhisBike View Post
    No, nothing. It works fine.
  39. #839
    Jun 2012
    Beautiful pic! Thanks for the help!
    2017 Canfield Riot
  40. #840
    Jan 2017
    So, I'm not even really in the market for a new bike right now, but the Riot frame with the DVO Topaz for $999 is hard for me to pass up, especially since I'll be able to move over just about everything from my recent hardtail build over to it. I'm mainly unsure if I'll fit on a medium, which is the largest size left according to the website. I'm 5-10, around a 32 inch inseam. The hardtail I'm on has a slacker seat angle (74), but similar reach (438 on the Riot versus 435 on my hardtail), and the stack is 12mm higher on my hardtail. I'm not sure if the steeper seat angle will make the similar reach feel smaller? Anyone similar size to me on a medium?
    Patrick
  41. #841
    Jan 2014
    Quote Originally Posted by pjames12 View Post
    Iím 5í8 on a large riot with a 35 mm stem and fits perfect. A buddy of mine has a medium and I feel cramped as hell on it
  42. #842
    Reputation: cpolism's Avatar
    Quote Originally Posted by Raleighguy29 View Post
    Yeah, 100% do NOT get the medium. Iím 5í8Ē as well and got the medium, and really wish I had the Large. Donít get me wrong, killer bike and love it quite a bit...but the longer wheelbase would have been ideal. I have a 50mm stem on my bike now which helps, but a Large with 35mm would now be better.
  43. #843
    Jan 2017
    Right on, thanks guys. Kind of thought so, I'm a bit cramped on my hardtail with the medium, so I figured the steeper seat angle would make that similar reach feel really cramped on the medium.
    Patrick
  44. #844
    May 2018
    Riot
    The steed in all its gloryCanfield Riot Photo Thread-image2.jpgCanfield Riot Photo Thread-image1.jpg
  45. #845
    Oct 2015
    I'm 5'6" and ride the small with a 45stem and set back post. If my terrain wasn't so peddly that a slacker STA works better in, I'd ride the medium.
  46. #846
    Reputation: skyval's Avatar
    My measurements are the same as yours. Iím riding a medium with a 50mm stem. Iím super comfortable on it. Fits better then my med wreckoning. I could ride a large though.
  47. #847
    Feb 2005
    5'10", short inseam on a medium and it fits great with a 40mm stem and wide bars. I have the saddle slightly slid back so it's more like a 76deg effective seat angle rather than 77. You could size up, but then you lose some of the nimbleness and the ability to run a long dropper. This bike was made for fun, not for being as stable as possible.
  48. #848
    I felt so when compared with my friendís one. everybody says itís shorter...
  49. #849
    Jan 2017
    Quote Originally Posted by jaks View Post
    Yeah, I'm not looking for extra stability or anything like that. I just want to make sure the cockpit is roomy enough for me on a medium. Seems like its pretty split in here on sizing. Perhaps I should give them a call and see what they think.
    Patrick
  50. #850
    2 wheel drifter
    Reputation: blackbart's Avatar
    I'm exactly the same height on a medium with a 50mm step and 780mm bars. The fit is spot on for a trail bike. Not sure about my inseam, but the seatpost collar to saddle rails is 285mm and I'm running 175 cranks.
  51. #851
    Jun 2012
    Just completed all my (planned) mods. I sold my size small Ď16 raw Riot for an early Ď17 medium black Riot. Just built my first wheelset. Nextie i32 29Ē rims on DT 350ís and Sapim Laser spokes. Got them wrapped with Maxxis 29x2.6 Rekon tires. The fork started life as a 160mm 27.5 Fox 36 Performance. I swapped out the lowers for a set of 29 Factory lowers. I had a couple rides in with the 27 fork and B+ tires and Iím very happy that I sized up. Now I cannot wait to try out these stiff wagons and big tires!
    2017 Canfield Riot
  52. #852
    Reputation: maciejas's Avatar
    Dec 2013
    Very nice!
    I've been considering Rekon 2.6 at the rear either. How does it fit?
  53. #853
    Jun 2012
    Quote Originally Posted by maciejas View Post
    Very nice!
    Pretty well. It fit better than I thought it would. More chainstay clearance than my 27.5x2.8ís. The fit is tight to the swingarm as I suspected but itís not bad. Pretty wet in some spots on todayís ride and the mud wasnít a problem.
    Carbon rims are awesome. I also forgot how much I liked the Rekon as a front tire.
    2017 Canfield Riot
  54. #854
    New Goodyear 2.6" Escape tires on i29 rims are a fit. Probably not advisable if you are shooting a lot of mud through. 3mm on each side with about 2 between tire and frame.
  55. #855
    Dec 2013
    Thanks guys!
    I really like Rekon (plus) on another bike, but I generally dislike when tyre rubs the stays, even occasionally. Do you get any rubbing from Rekon?
    I reckon Goodyear might rub under power, no?
  56. #856
    Jun 2012
    I have only one quick 6 mile ride with the 29x2.6 Rekon and didnít have any tire to frame contact. Thereís about 3.5mm of space all around the tire. I had some mud build up but it sheds well. Never had any trouble with the plus Rekon either.
    Itís tight and I was surprised that there was no rub
    2017 Canfield Riot
  57. #857
    Mar 2014
    Damn..I get plenty of rub with 2.5 minions on the Canfield wheels, old school 26mm wide, I think... I'm on a 2.3 minion out back now just to avoid the rub, and I'm missing the bigger tire traction and cush for sure.
  58. #858
    Oct 2015
    Mine!
    Medium Riot
    DVO Diamond/Topaz
    SixC Bar
    Hope E4 brakes
    Cromag grips
    Nice build, I like the forkasters as well, it doesn't pack up and works well early and late season when its wet or leafy. A DHR2 pairs well on the front with it.
  59. #859
    May 2018
    Riot
    Cant get enough of this badboy
    Attached Thumbnails Attached Thumbnails Canfield Riot Photo Thread-riot1.jpg
  60. #860
    So what are your thoughts on the MRP Coil? Iím really trying to decide between the MRP, 11.6 and the DBCoil IL. What type of riding do you do?
  61. #861
    Jun 2012
    Quote Originally Posted by cpolism View Post
    I like the MRP a lot. I wrote a lengthy post either here or in the other Riot thread about my shock experiences on this bike. I had a DB Coil IL also and it was also a very good shock. I just thought I was able to tune the Raze in better. I ride technical east coast tight fast woods with lots of roots and rocks some drops. Mix in a few park days a year too. For me MRP Raze handles everything from mild XC to DH quite well. I have no experience with the 11-6. If youíre thinking MRP their new Hazzard looks very interesting. Iím hoping their progressive spring will fit the Raze.
    2017 Canfield Riot
  62. #862
    Oct 2015
    I agree with Stumpy the Riot doesn't need a climb switch so no need to pay extra for it. Avalanche tunes the MRP if you want a custom tune. You want a shock that blows off HSC easily. The CC shocks tend to have an issue with that, needing service more often.
  63. #863
    Got an 11.6 for sale still. PM me if interested, but it's listed on the site. Have it setup with a flow setting and a DH setting. Climbs technical stuff best in the DH setting.
  64. #864
    Jun 2012
    This bike is so much fun! My skills and what I can do continue to improve every time I ride it. Iím so happy with everything about my setup. Todayí ride was an absolute blast!
    Then when you get home and your wife says that you need to wash your bike so the we can apply the custom fork graphics that she made for you, well you oblige of course!
    Attached Thumbnails Attached Thumbnails Canfield Riot Photo Thread-abeaffff-3064-4e97-91a1-c1216a532c3b.jpg
    2017 Canfield Riot
  65. #865
    Couple days ago in the front range near Boulder CO
  66. #866
    Oct 2012
    Had to give up on SS, 'cause I want to go fast.
    Not so much difference on my local trail...
    ...big difference on some others.
  67. #867
    Reputation: chestont's Avatar
    Weekend riding at Snow Summit Bike Park. The Riot with a 150mm Fox 36 and DBinline Coil was fantastic!
    Sent from my Pixel XL using Tapatalk
  68. #868
    Feb 2010
    Quote Originally Posted by carbine_275 View Post
    Tires: Maxxis DHF 2.8 (F), Maxxis Rekon 2.8 (R)
    Rims: Velosa Carbon MAS2702 - 34mm internal width
    Did you get the MAS2702 AM or DH versions, and how have they held up over this past year?
  69. #869
    Rider/Builder/Hacker
    Nov 2015
    Quote Originally Posted by kurtz433 View Post
    AM layup- no issues to date. I don't ride in a lot of rocky terrain and don't get any big air, so you might want to consider the DH layup depending on where and how you ride.
  70. #870
    Mar 2006
    Some scree carving from one of the best hike a bikes known to man
    Attached Thumbnails Attached Thumbnails Canfield Riot Photo Thread-img_0394.jpg
  71. #871
    Oct 2016
    Sunday funday
  72. #872
    I'm with stupid
    still love my riot
  1. 2015 Canfield Brothers Riot 29er FS
    By KillingtonVT in forum Canfield
    Last Post: 1 Day Ago, 06:50 AM
  2. Evil The Following or Canfield Riot and Nimble 9???
    By AaronJobe in forum 29er Bikes
    Last Post: 03-28-2017, 07:18 AM
  3. Canfield Brothers Riot 29er FS
    By KillingtonVT in forum 29er Bikes
    Last Post: 04-24-2015, 06:24 AM
  4. 2012 Canfield The One Sizing Thread
    By Heretic Skeptic in forum Canfield
    Last Post: 12-05-2012, 12:23 PM
  5. Bullit photo thread (Merged thread)
    By Pete in forum Santa Cruz
    Last Post: 05-18-2012, 11:49 AM
Members who have read this thread: 168
