Page 24 of 24 FirstFirst ... 142021222324
Results 2,301 to 2,316 of 2316
  1. #2301
    As it turns out the Paulís klamper is too big to run 180 so 160 it is. Thank you to all that responded
  2. #2302
    New whip
    The new ride
  3. #2303
    New ride
    The new ride
  4. #2304
    Quote Originally Posted by hugo03 View Post
    Anyone have problems running 180mm rotor in the rear? My lbs is building up my epo with Paulís klampers and apparently itís not fitting
    Quote Originally Posted by BlueDragonX View Post
    Yeah, I couldn't fit a 180mm and had to stick with 160mm.
    Mostly the same here--although I could fit it, it was nearly impossible to adjust and get an Allen key into the bolts to tighten it down. I just put it back to a 160mm as well. FYI, I put on XT brakes and Shimano adaptor. I did run it for a day but couldn't get it adjusted quite right.
  5. #2305
    Reputation: Nubster's Avatar
    I'm going back and reading past posts...maybe I'll see some answers to my questions...
    Who's running their EPO as 27.5+? Are you able to get a 2.8 tire in there?
    And...anyone put more than 140mm travel fork on their EPO? I have a 150mm Pike that I'd like to use if I got this frame...I know I can reduce the travel but if I don't have to that's a few bucks saved and a little extra travel to boot.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Norco Torrent HT 7.1
  6. #2306
    Reputation: jkidd_39's Avatar
    Sep 2012
    Canfield Brothers EPO Carbon 29er
    Quote Originally Posted by Nubster View Post
    I'm running 2.8s easy. Lots of room. Never tried a 3.0 tire as they are so draggy.
  7. #2307
    Yeah...I'd probably go 2.8 max anyways. Maybe 2.6 rear and 2.8 front. I'm so close to pulling the trigger. I have all the parts (if I strip my Release 3) to build except I'd need a non-boost crank and I guess a new wheelset since what I have now is boost. That's really what's holding me back...that's another $400-$600 on top of the frame and crank.
    Kona Big Unit SS
  8. #2308
    Sep 2012
    I'm told you can run a boost wheel in this frame....YMMV
  9. #2309
    I read that but I'd be a little sketched out doing that. I guess it would work until I got another proper wheelset.
    Kona Big Unit SS
  10. #2310
    Jul 2013
    Max width mine can 'clear' is nobby nic 2,8 in rear, but the tyre rubs when you ride hard in corners, so i made aluminium cs guards which work perfect... would reccomend to anyone running a big tire in the back...
  11. #2311
    Reputation: mcb99's Avatar
    Morning ride
    Envoyť de mon E6633 en utilisant Tapatalk
  12. #2312
    Nov 2017
    I tried 180mm and decided it wasn't worth the hassle; kept scratching the clear coat when trying to position the caliper. 160mm works just fine for everything here in VA.
  13. #2313
    Nov 2017
    FWIW, and I know this was mentioned earlier in the thread, but I just swapped out the Maxle for an Ibis Hexle, which seems a lot less finicky. I broke the Maxle and it was hanging on for dear life.
  14. #2314
    Quote Originally Posted by stec06 View Post
    Which Hexle would I purchase if I'm running i9 Torch hubs and Shimano XT drivetrain on my EPO?
    I would guess the Shimano 142 version. The note about thread pitch is something I'm not familiar with and confusing.
    Sent from my SM-G955U using Tapatalk
  15. #2315
    Reputation: BurkeVT's Avatar
    Jul 2003
    Quote Originally Posted by caldog View Post
    Yup. Shimano 142.
    The Hexle is great. Cheap, light, effective.
    -Chris
  16. #2316
    Nov 2017
    Quote Originally Posted by BurkeVT View Post
    Yup. Shimano 142.
    SRAM Hexle is the one you want. It's the right length/thread pitch for the EPO dropouts.
  1. 2015 Canfield Brothers Riot 29er FS
    By KillingtonVT in forum Canfield
    Last Post: 1 Week Ago, 08:04 AM
  2. Some more Canfield Brothers DJ love....
    By rsullivan in forum Canfield
    Last Post: 11-04-2014, 10:53 AM
  3. New Canfield Brothers Softgoods
    Last Post: 10-09-2012, 08:32 PM
  4. Canfield Brothers are off to Rampage!
    By KillingtonVT in forum Downhill - Freeride
    Last Post: 10-01-2012, 08:50 PM
  5. Canfield Brothers Canada
    By atlanticrider in forum Canfield
    Last Post: 05-26-2011, 08:10 AM
Members who have read this thread: 281
