Page 23 of 23 FirstFirst ... 131920212223
Results 2,201 to 2,235 of 2235
  1. #2201
    Sep 2017
    Quote Originally Posted by Raleighguy29 View Post
    Yes very similar epo might be a tick longer
    Sounds like I should go large then. Thanks
    Sent from my Nexus 6P using Tapatalk
  2. #2202
    Reputation: Stopbreakindown's Avatar
    Quote Originally Posted by Stopbreakindown View Post
    I put a 29x2.6 Schwalbe NN in the back of the Epo on a WTB Asymi35 rim
    It fits, but I wouldn't run it, maybe in the desert but not where I live.
    Thinking the Rekon 29x2.6 might do the trick w/ the smaller knobs.
    Fitted the 29x2.6 Maxxis Rekon tires today, they clear, should be good to go unless they stretch a bunch. Might have slight rubbing on the CS in hard corners due to frame flex but won't be able to ride/verify till May.
    Edit: mounted on i33 nextie rims
  3. #2203
    Is a boost EPO on the way for 18?
  4. #2204
    Reputation: Klainmeister's Avatar
    I just wanted to update and say that this is now my favorite bike in my stable. Holy cow is it fun! But even so, on a rocky ride yesterday that i am well familiar with I managed 17 PRs (everything but one crux move). Still learning the limits pushing through rock gardens descending, but overall, I cannot believe how much fun and how fast i can ride on a hardtail! Shot from yesterdays ride:
  5. #2205
    WOW - i've ridden that "crater" near Santa Fe - in the spring - no snow dusting as it appears in your pic - but its an inspiring and unique view every time you look a different direction or from the bottom looking up before coming out of it!!
    looks kinda like what you'd expect from the moon or Mars!! HA - if the current sale EPO was boost i'd own it already - but have a plus ready and capable 27.5 boost wheel set and only would need a 29 to have both option... Hence why im sooooooo freekin close to a chrome n9 boost...
  6. #2206
    Reputation: jkidd_39's Avatar
    Sep 2012
    Quote Originally Posted by kamper11 View Post
    There are a few folks running boost wheels on the epo. Fyi...
  7. #2207
    is that right??? i guess i need to do some more in depth searching unless anyone wants to jump in with the quick and dirty about this -
  8. #2208
    Reputation: VeloRyan's Avatar
    I have read that they have test fit boost wheels in to most (all?) of their frames and they work just fine. The only thing required is a thru axle that is 6mm longer than the stock one.
    -VeloRyan-
  9. #2209
    Jul 2013
    Quote Originally Posted by VeloRyan View Post
    Be curious to hear from anyone with firsthand experience trying this.
  10. #2210
    Damnit, I have succomb to self induced forum pressure by re-re-re reading this thread.
    Thanks to the Bros and all you enablers here, I have a frame enroute.
    Let the game begin!
  11. #2211
    Apr 2013
    Has anyone else been surprised at the maximum depth of seat post insertion?? I'm just about to start building up my Medium frame (I'm about 5'11" - 6'0" and got a BikeYoke Revive 185mm dropper. When I received the dropper yesterday and slid it into the frame, it stopped about 1.5 - 2.0 inches before I had expected and well before it reached the front derailleur mount. No other hardware or bends are present in the seat tube and I hadn't verified the depth with another post before I bough the dropper. I was surprised, given it's a straight seat tube with internal routing, that you couldn't insert the post all the way down to the where the cable exits the frame. It's likely that the saddle will be too high and I'll have to exchange for the 160mm version. Just seems a little surprising given the type of bike and that I'm at the high end of the height scale for a Medium already that a longer dropper wouldn't fit. 160mm would still be a huge upgrade for me, but it's a bummer that I potentially miscalculated.
  12. #2212
    Reputation: mestapho's Avatar
    Might just be some excess material in there. Have you taken a look to see what is actually causing the obstruction?
  13. #2213
    Reputation: Raleighguy29's Avatar
    Jan 2014
    Quote Originally Posted by Dirty4130 View Post
    At your size why did you go with a medium. Iím 5í8 on a large and I could easily fit a 150 dropper slammed.
  14. #2214
    Jan 2018
    Hi all
    New to bike building and putting together an EPO and hope someone can help. Have a sram GXP team English threaded BB and sram gxp 1400 crankset with 32t chainring. When i install the chainring contacts the frame chainstay. Sram indicates to not use spacers (and even trying with couple spacers) seems to contact chainstay. Any help/advice on where I have gone wrong!
    Dixon
  15. #2215
    Jan 2014
    Whatís the offset on your chain ring. I had the same problem with mine. Solved it with a less offset chain ring
  16. #2216
    Jan 2018
    Hi Sorry, not sure on this, it is this crankset:
    Wiggle | SRAM GX 1400 1x GXP Chainset (with 32T Chainring) | Chainsets
    Do you mean how much the chainring is set back from being in line with the contact point between the BB and the back of the crank?
    Cheers
  17. #2217
    Oct 2013
    Quote Originally Posted by Dixon_303 View Post
    Cheers
    Look at the Canfield site for build specs (found on the EPO page). It will tell you what offset your chainring should be. Chainrings come in a variety of offsets to accommodate a variety of B.B. and chainstay widths. Your offset is probably not correct.
  18. #2218
    Reputation: coolhand80's Avatar
    Oct 2011
    Hi all
    Dixon
    Make sure your dust covers are on the bearings. Did you try spindle spacers? If so try a spacer under the BB shell it wonít interfere with the chainring. You most likely have a 6 mm offset chainring. You could get a 3mm offset ring which is normally only needed for boost rear ends but will Work either way.
  19. #2219
    Quote Originally Posted by callmesb View Post
    The Bros. claim 32 is the largest but IMO a 30 is the biggest that will work. I put a 32 on and barely cleared the CS. Not enough room for flexing IMO. I run a 30 with no probs.
  20. #2220
    Jan 2014
    Either 3mm offset or 0 offset bb30 ring will be fine.
  21. #2221
    Oct 2013
    Quote Originally Posted by mestapho View Post
    Iím running a GX 32 with no issues.
  22. #2222
    Jan 2018
    Hi all
    Thanks for the replies and advice. LBS said may be due to chain ring being too large. Sean at Canfield bro also got back to me to say need direct mount chainring. The crank I have with chainring currently uses spider to attach chainring. So gonna look at getting DM chainring with maybe 30t and hopefully will be good to go. All these different options and standards sure are confusing!
    Anyone have any good recommendation for crankset fitting gxp BB already with DM let me know, or recommendation for good DM chainring that won't break the bank?
    Cheers
  23. #2223
    Hi all
    Cheers
    XO1, XX1 can be found reasonably used. I prefer SRAM rings, I have not had great luck w/Race Face rings. RF anything to be honest.
  24. #2224
    Jan 2018
    So is that go crank same as the one I have? Or is it direct mounted chain ring? Cheers
  25. #2225
    Oct 2013
    Canfield Brothers EPO Carbon 29er-hxyi3ajrskiznoy3w2nnmg.jpgCanfield Brothers EPO Carbon 29er-ahztutq0sooyuqvfbukfbw.jpg
  26. #2226
    Jan 2018
ID:	1177171Click image for larger version.
    So yes this is essentially exactly what I have except I have the gx 1400 cranks but don't see that making a difference. Exact same chainring and bb but my chainring cuts into the chainstay. How do you upload photos and will provide?
  27. #2227
    Oct 2013
    Mine is a 2016 pre-boost model so that may make a difference. Also, SRAM makes a variety of chainring offsets for that chainring. Yours may be a different offset than mine.
  28. #2228
    Oct 2011
    Download the Tapatalk App for you phone and get on MTBR through the App
  29. #2229
    Jan 2018
    Mine 2017 but still pre boost. On that thought do you think using a boost crankset would solve it?
    Otherwise is there a way to tell from the chainring it's offset? I was not given any option or information on offset when ordered it.
    Cheers
  30. #2230
    Oct 2013
    Cheers
    https://www.oneupcomponents.com/page...-and-non-boost
  31. #2231
    Jan 2018
    Cheers, good info! Have ordered a chromag direct mount 30t so hopefully being both less teeth and also DM should have it sorted! The kind fellas at Canfield are also gonna fire across a 32t DM they know works too to try but will be a while before gets across the pond.
  32. #2232
    Feb 2013
    New EPO Build
    Here's my EPO, Thanks to Sean at CB. My luggage scale shows 25.9 lbs as built, including the protection tape.
    Build:
    Frame: CB 2017 EPO Medium
    Fort: DVO Diamond 140mm
    Handlbar: RaceFace SixC 775mm
    Stem: Syncro 50mm
    Brakes: Shimano XT
    Shifter: Shimano XT
    RD: Shimno XT 11spd
    Rear Cassette: Shimano XT 11-46
    Cracksets: CB 170mm with CB chaining 32T
    Hedset: Canecreek
    Grip: Ergon GE1 Slim
    Pedal: CB Crampon Mountain
    Seatpost: Brand-X Ascend (Cheap but functional)
    Saddle: Ergon SME3 Comp
    Wheelset: Stan Arch EX
    Tires: F - Specialized Buther 2.3 / R - Schwalbe NobbyNic 2.2
    Attached Thumbnails Attached Thumbnails Canfield Brothers EPO Carbon 29er-0110181837reduced.jpg
  33. #2233
    Oct 2013
    Quote Originally Posted by mtbpark View Post
    Looks like you're close to me...I'm in Duvall.
  34. #2234
    Feb 2013
    I guess someday we will see at Cherry Valley.
  35. #2235
    Oct 2013
    I was there on Saturday.
  1. 2015 Canfield Brothers Riot 29er FS
    By KillingtonVT in forum Canfield
    Last Post: 5 Hours Ago, 09:39 AM
  2. Some more Canfield Brothers DJ love....
    By rsullivan in forum Canfield
    Last Post: 11-04-2014, 10:53 AM
  3. New Canfield Brothers Softgoods
    Last Post: 10-09-2012, 08:32 PM
  4. Canfield Brothers are off to Rampage!
    By KillingtonVT in forum Downhill - Freeride
    Last Post: 10-01-2012, 08:50 PM
  5. Canfield Brothers Canada
    By atlanticrider in forum Canfield
    Last Post: 05-26-2011, 08:10 AM
Members who have read this thread: 328
