Results 1 to 33 of 33
    BOLU Bearings? Bummer.
    I was under the impression that these bikes came spec'ed with Enduro Max bearings, but I went through the rear suspension this afternoon and found all BOLU (chinese) bearings.
    2017 model with about 600 miles and a few of the seals have already let dirt in... And grease out. The balls are loose and appear to be lubed with some white lithium or similar. Really cheap.
    Just a little disappointing. I would have been happy to pay an extra few bucks for the frame to get some quality bearings in there.
    They're all 6902's (x8) so there are plenty of quality options available.
    My bearings seem to have held up ok for two seasons, but I'm thinking it is time to replace them. Any recommendations for what to use? Is there something better than Enduro Max? ... I like to hose my bike down on the regular
    Is there a good guide on how to do it? Is it worth the time to do it yourself and not just pay the lbs?
    I don't know if they've gotten better, but I've had some quality issues with Enduro before. There aren't a whole lot of other choices. I'm a bit of an SKF fanboy, but they're about $10/each versus $6 each for the Enduro Max.
    There's a kit on RWC: CANFIELD Suspension Pivot Bearing Kits from RWC
    Probably need a bearing puller/press too.
    Reputation: twd953's Avatar
    Quote Originally Posted by madamfunk View Post
    Depends on whether you have a good LBS that you trust vs. your mechanical skills. I haven't seen a guide specifically on the Canfield frames (haven't looked either).
    The low tech DIY method if you don't have a bearing press is to tap out the old bearings evenly with a punch, then use the back side of an appropriately sized socket and a rubber/plastic mallet to gently/evenly tap the new bearings in.
    But, if you aren't patient and try to force things you can damage the new bearings or if you're really ham fisted even mess up a frame or suspension link.
    Quote Originally Posted by Porch View Post
    I was doing some research about Enduro Max alternatives last night. It doesn't seem like SKF makes anything that is rated for high loads like the Enduro Max. Am I missing something?
    Interesting, the older frames used to use Enduro Maxx. At least my '13 the One did. Has me interested in pulling my '17 balance apart to check on the bearings.
    I don't remember ever running across cartridge bearings with loose balls without a retainer. Sounds sketchy. If the bearings aren't running too rough I'll usually pry the seals, flush the grit with solvent, blow clean with the air compressor, and repack with thicker waterproof grease.
    Not sure I wan't to mess with that if I pry the seals and loose ball bearings start falling out, or worse yet blasting with an air compressor and launching the bearings across my garage floor.
    Quote Originally Posted by twd953 View Post
    The bearings are still held in there with a groove in both races, so they can't just fall out. But they are free to rub up on each other, unlike a bearing with a separator between the balls.
    These are 6902VRS bearings. I did some quick searching on the VRS, and it doesn't even seem like a good fit for the application. The "V" series seals are not very good at keeping out dirt and water, so they're usually used in higher-speed applications where less friction is important.
    I took mine apart intending to just inspect and re-grease, but honestly with the seals they have, i'm just going to end up having to do it again every year. I just ordered some Enduro Maxx bearings so I don't have to take them apart again next year. Just disappointed that I am doing this on a nearly-new bike!
    Apr 2015
    My 2016 Balance has Enduro Max bearings. Odd the new models dont have them.
    Quote Originally Posted by ScottieM8 View Post
    Can you take a picture of them on your frame? I think there is an angle you can take a photo of the ones by the linkage. I'm curious if mine are the same.
    My frame is currently in pieces, but here's what I've got and next to it is the new Enduro Max with the black oxide treatment.
    Thanks dude - looks like what I have :/ Do you have a legit bearing press to do this?
    Apr 2015
    I do an annual tear down at spring and that's when I noticed mine had Enduro bearings. Sorry don't have pics as I don't feel like tearing apart until next spring. I do have one of the earlier 2016 models.
    As far as removing bearings, I use a punch or an extender from my socket kit and hammer out slowly. To install, i have a long bolt, couple on nuts and appropriate sized washers and there's your press. It will cost a couple of bucks from Lowes. Heard people use the old bearings in place of the washers to guide in the new one. You can use a vise for that method.
    I bought a Wheels Manufacturing 6902 bearing extractor for $20 (see image below), but normally I've used a punch and a hammer. I'll just use a vice and the old bearings for re-assembly. You can also buy a "cheap" threaded bearing press for another $35 or so.
    Finally got my bearings replaced. What a pain in the ass.
    The bearing replacement is easy, but getting the lower link into the rear swing arm is a major pain. It has two little washers on each side that easily deform, and the whole thing is a press fit.
    I froze the link and warmed the swing arm but it still wasn't easy. You have to align 7 pieces pretty well to get the bolt through. Not fun at all. The washers should probably be replaced by a bearing with a 1.5mm wider inner race... But I could only find bearings with a 2.5mm wider inner race.
    Overall, thumbs down for these cheap $hit Chinese bearings.
    damn... that's unfortunate. Haven't checked mine, but they are due for full rebuild soon.
    Thanks for all the info.
    I think that what I should have done is buy a cheap 15mm thru axle, then cut it to the exact width of the bearings + shims. That way I could keep all the bearings/shims in line while I tapped the link into the rear swingarm with a rubber mallet. Once it's all lined up, pull the cut-up thru axle out and put the bolt through. Hindsight!
    I was able to do the bearing replacement with a screw driver, hammer, socket and bench vise during my lunch break. This is a pretty easy frame to work on. the little washers in the rear lower link are always the most PITA thing to reinstall.
    My originals were enduro max and the front lower link started to get play last week. I replaced all and she's as tight as a drum now.
    Looks like a great tool - will buy. What did you use to put new 6902s in? I'm wondering if there are any awkward angles a table vise couldn't get to.
    I just used a vice, nothing fancy!
    Nov 2017
    2016 Canfield Balance installing the lower link to rear triangle
    My 2016 Balance also had the Bolu bearings, i was just doing a bit of spring maitenance and found that a couple of them had already started to get crunchy and dodgy. Easy job to remove and install them but im now stuck trying to put the lower link into the rear triangle.
    Anyone got any tips on this?
    i can get the spacers in and close but feel like i will do damage if i force it more.
    Any advice appreciated.
    Cheers
    That was a huge PITA for me on my balance, but on my riot they all just slid right in. Be careful because those spacers are soft and will deform if you force them.
    I would find a bolt that is the right size and cut it down to the length of the dog bone + the spacers so you can push them all in at once. Then stick the dog bone in the freezer overnight to shrink it a little before the big push. Good luck!
    Quote Originally Posted by Bobbywag View Post
    Cheers
    The one tip that really helped me is to install the rear axle before you try and get the lower link back in the rear triangle. I helps to flex the link side of the triangle open a bit.
    But mostly itís a huge pain in the ass.
    Nov 2017
    Quote Originally Posted by jminus View Post
    Thanks for the tip, finally got everything lined up. It took a lot of swearing, hair pulling and required several calming ales to recover.
    But bike is running smooth !
    I will speak to a friend who can machine me a cylinder thats exactly the width of the dogbone link plus spacers, and put it all in together for next year.
    If you end up doing that and it isn't expensive, I might be interested in one too. I was planning to pick up a bolt and just cut/grind it, but finding a 15mm bolt might be a little hard in my area.
    Glad you got it!
    Apr 2015
    If your friend can make a few of those cylinders, I'll be interested also. Maybe you can sell them on Pinkbike or eBay. Pretty sure you'll have a few sales.
    I checked again on ebay and found this guy: https://www.ebay.com/itm/SLEEVE-15MM...53.m2749.l2649
    I ended up just buying one, it's going to be hard to find a machinist to make something similar for less than $10. It will need to be cut to length, but hopefully will be helpful next time I need to do bearings...which is soon, on my Riot.
    For getting the lower link back together, I ended up just sanding down the washers from 1.5mm to 1.4mm, being careful to keep them square. That way the assembly still had a bit of an interference fit, but with much less wedging and prying and swearing.
    mjw
    mjw is offline
    Feb 2007
    About 10 rides on my bikes and it's creaking. Taken pivots apart to discover bolu bearings. Most feel gritty/crunchy already.
    Enduro max on order.
    • 2015 Kona Explosif Ti
    • 2015 Kona Process 111
    • 2018 Canfield Riot
    Jun 2018
    Quote Originally Posted by mjw View Post
    Yeah same here.. pretty bummed about it. I'd have like to get close to a year before having to pull everything and replace. Cost cutting when things got tough? Anyone have any insights there?
    Just ordered a set of Enduro's.
    Quote Originally Posted by Fancy View Post
    I bought my bike in early June 2016 and it had Bolu bearings, so I don't think it was a matter of getting through the tough times.
    FWIW, my bolu bearings lasted two years (2000 miles) of serious abuse and lots of hosing down the bike all winter long.
    mjw
    mjw is offline
    Feb 2007
    Lucky you. Mine lasted maybe 10 rides before feeling rough, and leading to creak. And I am pretty discriminate about how I washing and cleaning my bike.
    Links to Enduro Maxx bearing kits for the Riot and the Balance?
    The previous link/url in this thread is giving some kind of error.
    I'd like to order a couple sets in advance before I really need them.
  1. Bummer......lost my handle.
    By Ska in forum Passion
    Last Post: 09-30-2011, 08:29 AM
  2. The Five Stages of a Bummer Summer.
    By shirk in forum Eastern Canada
    Last Post: 07-23-2011, 02:21 PM
  3. Bad power-to-weight ratio = BUMMER.
    By SWriverstone in forum Clydesdales/Tall Riders
    Last Post: 04-13-2011, 07:04 AM
  4. little jump, other bummer
    By pippinr in forum Clydesdales/Tall Riders
    Last Post: 04-01-2011, 10:23 AM
  5. No 2011 Slayer frames available, bummer!
    By cornfish in forum Rocky Mountain
    Last Post: 03-28-2011, 07:37 AM
Members who have read this thread: 88
