Results 1 to 11 of 11
Thread: B+ on a Riot
    Aug 2010
    B+ on a Riot
    I put my 35mm Arc with 2.8 Rocket Ron in the back of my Riot and it fits, but barely. Maybe 1-2mm on DS. No room for error.
    I saw on old threads many said they were running 35mm id with 2.8 no problem. And I know Canfield says this combo will fit.
    Iím wondering if anybody can recommend a ďskinnyĒ 2.8 that would give me more space?
    Jun 2018
    Maxxis 2.8 tires fit better than Schwalbe in the Riot (and Balance) rear triangle, but it's still tight with a 35mm rim. The Rekon is probably a decent replacement for a Rocket Ron. Even with Maxxis' narrower tires, I ultimately switched to a 30mm internal width rim to get some space for peace of mind.
    Reputation: cpolism's Avatar
    Quote Originally Posted by Turbojet Megafred View Post
    Yep, Rekon is what I used on my Riot before ultimately going back to 29er. I had a Rekon in the back and a DHF up front.
    I ran a WTB breakout on a 35mm internal width rim. Was a very large 2.5 tire, but one of the most frustrating to mount on the rims. My thumbs hurt just thinking about it.
    But, it is a very durable tire and will give you a bit more clearance.
    If I was doing it again though, I'd probably mount a Rekon or Ikon on the rear unless I need more durable sidewalls.
    Nov 2008
    I have a 35id rim and have used 2.8 Rekon and a 2.5 wtb Breakout. The Rekon measured out to 2.66 and the Breakout measured out to a true 2.5. Most of the maxxis 2.8 measure out in this range 2.6-2.69. I also run a Maxxis dhf 2.8 in front and that one also measures out to 2.66 on a 35 inner diameter rim.
    Nov 2008
    The new 2.6 tires that actually measure out to 2.6 will also work the only one I'm sure of right now it's a 2.6 Nobby Nic measures out to right at 2.6 on a 35 inner diameter rim
    Aug 2010
    Quote Originally Posted by jsalas2 View Post
    What about sidewall/overall height?
    Iím concerned 2.6 tires will be too low in overall height since theyíre not true plus tires.
    Aug 2010
    Just an observation after putting my B+ wheelset from my N9 to measure B.B. drop.
    2.35 Nobby Nic / Stanís Mk3 Flow
    BB height from floor = 320mm
    2.8 Rocket Ron / Arc 35
    BB height from floor = 310mm
    Only a 10mm drop
    Nov 2008
    The diameter with the Maxxis was 28.25. I am also using Canfield's shorter cranks, so no pedal strikes with the plus. I'm using 155mm, but anything shorter than what you have would work, if it's a concern
    Aug 2010
    My 2.8 Rocket Ron on Arc 35 is measuring to 71mm/2.795in, or basically 2.8 from out side the knobs.
    It would be great if I can get a slightly thinner tire such as the Rekon 2.8
    Aug 2010
    B+ on a Riot
    Iím using 170mm Canfield cranks.
    Iíve never had a problem with pedal strikes after B+ing my N9 with 175mm cranks. I donít have all the numbers but I think (hope) based on my experience Iíd be ok as far as pedal strikes.
  1. Red River Riot 4/19 (Texas Gravel Grinder)
    By Spinistry in forum Gravel Bikes
    Last Post: 02-05-2014, 09:28 AM
  2. Red River Riot 3/30 (TX Gravel Grinder)
    Last Post: 03-31-2013, 02:32 PM
  3. Red River Riot (TX Gravel Grinder) 4/7/12
    Last Post: 04-09-2012, 08:33 AM
  4. 661 Riot Shin Guards
    By Spykr in forum Apparel and Protection
    Last Post: 12-09-2011, 12:01 AM
  5. 661 Riot
    By xx Hedgehog xx in forum Apparel and Protection
    Last Post: 10-31-2011, 11:39 AM
Members who have read this thread: 51
