Page 59 of 61 FirstFirst ... 94955565758596061 LastLast
Results 5,801 to 5,900 of 6035
  1. #5801
    Quote Originally Posted by kmj831 View Post
    I've been on the phone with the guys at CB's a few times now, and one of the items discussed was increasing the travel of the fork. What they told me has been covered here across numerous posts, but I'll bullet point the answer that I got from them;
    - Small company, who stands behind their product, so if something happens and it's their bad, a product flaw, or an issue that results from hard riding, but within the range of intended use (i.e. don't throw your bike off the chair lift and then call us) they will always make it right. That said, they aren't big enough to absorb the cost of a bunch of warranty claims that result from guys testing and playing, so if you choose to do it, it's on you. They'd like to keep their doors open, keep building cool bikes and keep food on the table.
    - All that said, off the record, they believe it to be highly unlikely that running a longer fork will ever cause any issues, and they indicated to me that they wouldn't personally be afraid to run a 150 or 160mm fork.
    - They have run both of those, and felt that the geo suffered too much at 160mm to justify and that the extra travel wasn't worth it. They did suggest running it with a zero stack to try and keep geo similar.
    - They designed the bike around 140mm and prefer it, largely due to torsional rigidity of a 140mm on a 29er, and felt that the flex at 160mm was not worth the extra travel.
    - They have raced the Riot in Enduro and ride the Riot regularly and hard, and haven't felt the need for more than 140mm on this type of 29er. Certainly not at the cost of additional fork flex due to increasing travel.
    What I came away with was basically, run a longer fork if you want, it will void the warranty, but honestly we don't think you'll have a problem, we've done with no issues ourselves. It will handle better at 140mm or with a zero stack, but handling is preference to some degree anyways. You will get more fork flex, and we find the 140mm to be the best compromise between travel and rigidity.
    I don't know if that's helpful, but that is what I was told on the phone. Super nice guys down there. Spent a lot of time on phone with me.
    Very helpful indeed!
    Did they mention anything about using an angleset?
  2. #5802
    Apr 2014
    Quote Originally Posted by DirtDiggler View Post
    Nope, I didn't ask and it didn't come up.
    I know they are a small shop, and it took me a couple of tries before someone answered, but once they did, man they were willing to shoot the sh$t. We talked about the Riot and Balance, set up, and a bunch of technical details, then drifted into favorite riding areas, dirt bikes, company ethos, where the industry is going, trail advocacy and so on.
    Chill, knowledgeable dudes for sure.
    "Slow is smooth, and smooth is fast."
    Real Estate Professionals llc.
    realestate-professionals.com
  3. #5803
    Reputation: Dr Gigi's Avatar
    Nov 2016
    That's definitely been my experience with them as well. I'm going to go ahead and run the fork at 160 with a zero stack lower. That puts me at +4mm compared to a stock setup. I'm not too concerned with fork flex since the Fox 36 does not lack in the stiffness department. I'll let you guys know how it pans out if my Chinese wheelset ever gets here.
  4. #5804
    Reputation: cpolism's Avatar
    +4mm shouldn't be an issue, but wouldn't anything more than 140 (not including the zero stack) result in a higher bottom bracket?
  5. #5805
    Nov 2016
    Quote Originally Posted by cpolism View Post
    The idea is that the zero stack offsets the increased axle to crown length of running a longer fork. So my bb will be slightly higher due to the 4mm increase in stack height, but I don't think it will be noticeable.
  6. #5806
    Nov 2008
    Quote Originally Posted by Tonggi View Post
    Not sure how you guys are doing plus without hitting the chainstays.
    LB 31.8 mm internal Diameter rims
    High Roller II 27.5x2.80
    Large Frame
    I had to redish wheel so it fit perfectly center but still pretty tight.
    I'm running 2.8 Dhf in front and 2.8 Reckon in back on 35id rims no problems with clearance.
  7. #5807
    Oct 2016
    That is good to know. I am pretty tight on maxxis minions dhf 2.5wt. on spank oozy 345s. I will actually get a little rubbing if I am really pounding on the bike pedaling.
  8. #5808
    Sep 2015
    Thanks all for sharing your perspectives. Especially, a big shoutout to kmj831 for sharing super useful info!
  9. #5809
    I noticed my raw '16 frame was starting to have weird stains all over it that a simple wash couldn't get out. Almost like dark water stains that felt rough to the touch. Did some research and reached out to Sean and found out that Steel Wool 0000 solves the problem. Weather turned to garbage this week so I figured it would be a perfect opportunity. Toss on some Netflix to bingewatch, and polished her up. Completely turned the bike around. It's insane how different it looks. I'm probably half way between the original raw and chrome.
    If anyone else is experiencing the same thing, I 100% recommend doing this. I'll find out this weekend if it made the bike any faster haha.
  10. #5810
    let's see it!
  11. #5811
    May 2013
    Quote Originally Posted by jsalas2 View Post
    Ok thanks. It works well now. Just slight slight rubbing on high speed turns but won't experience that much on trails. I'll use these plus tires until I wear out the rear then switch to 29.
    Unless someone wants to buy 3c dhf high roller and dhf 2.80 with 14 miles.
    Sent from my XT1254 using Tapatalk
  12. #5812
    Reputation: titusquasi's Avatar
    That answer is guaranteed to be a "yes"!
  13. #5813
    If you've already shined it up with steel wool you can now wipe it down with Mothers polish It will turn it to a chrome finish. Did this on an Iron Horse 6 point back in the day. People thought my bike was actually chromed. The cool part is Mothers seals the aluminum pores so it resists oxidizing.
  14. #5814
    Reputation: OwenM's Avatar
    Oct 2012
    Couldn't resist trying my Riot singlespeed. It'll be slow when the trail opens up, but I tried it on my local loop trail that's tight and twisty with constant ups and downs, and it's actually very well suited to it. Love not thinking about gears...
    Midday sun made for crappy pics:
  15. #5815
    May 2013
    Did you ever get around to trying an angleset?
    Sent from my SM-G930V using Tapatalk
  16. #5816
    I have been running a 1.5 degree angleset on mine. 65hta with a 345mm bb. It is alright. Different, i am going to take it off and go to 150mm to try that out. 65 HTA at speed is awesome and obviously makes it harder to get the front end to lift under steep climbing.
  17. #5817
    Wow! Nice, never even thought about a riot SS. I've seen am epic and tallboy ss but never anything like this!
  18. #5818
    Reputation: cSquared's Avatar
    I bet that SS is a rocket!
    [URL="http://www.facebook.com/pages/Canfield-Brothers-Downhill-BikesC2-Components/163956136971393"]
  19. #5819
    May 2013
    Deleted.
  20. #5820
    Oct 2012
    Quote Originally Posted by cSquared View Post
    It just needs a bigger motor!
    Workin' on it, but got my "climbing gear" on there. Gotta be able to go up to come back down...
  21. #5821
    Apr 2013
    I'm thinking about polishing my riot with 0000 steel wool and some mothers aluminum polish. do the Bros sell replacement decals? I really don't want my riot to say tior either but this may not be an option.
  22. #5822
    Oct 2015
    Quote Originally Posted by A_street View Post
    Stickrd (if im spelling it right) sells the decal kit. Almost any color you want.
  23. #5823
    Apr 2013
    Did anyone find a successful way to polish with a more automated tool?
  24. #5824
    Reputation: Raleighguy29's Avatar
    Jan 2014
    A small buffer or a mothers polishing ball for wheels would probably work pretty good. Iím getting ready to do this on my riot and balance
  25. #5825
    On the fence in ordering a Riot. Anyone had an experience coming from a Process 111 and would care to chime in their thoughts?
  26. #5826
    Quote Originally Posted by Raleighguy29 View Post
    I used a conical polisher on a battery powered drill and Gord's aluminum polish. It is almost chrome with custom chrome decals from stikrd. I was doing this on lunch breaks so if you took the time to really go at it i'm sure you could have it look like a P-51 or B-17.
    https://www.vitalmtb.com/community/u...9?mobile=false
  27. #5827
    Apr 2013
    Quote Originally Posted by pajak View Post
    I probably will get the conical polisher to use with the polish. The part that is the most labor intensive for me is using the steel wool. I let my top tube get pretty nasty. Also, getting off all of the sticker residue is a pain in the ass.
  28. #5828
    Not yet! I have some offset bushings that I will try out first.
  29. #5829
    Quote Originally Posted by Dr Gigi View Post
    What headset are you using? I am not aware of a ZS44 headset that will allow for the use of a tappered fork.
  30. #5830
    Jun 2012
    FSA Orbit E 1.5in Internal Bicycle Headset 141-2038
    https://www.amazon.com/dp/B017YYSXF8...=3VSSX1FP1CUTA
    This headset is designed to allow a 1.5 straight fork to fit into a 49mm straight head tube.
    Use one of the cups, one of the bearings and the lower race for the lower on your tapered fork. Then use an upper assembly of a standard 44 zs headset for the upper.
    The bearings on this headset are tiny. They are standard old school ball bearings in a thin flimsy cage and they are not sealed. I have one season on mine and they are getting beat. I inspect and re-grease them regularly. Dirt and spirited riding are taking their toll. But you get two sets so there's that.
    2017 Canfield Riot
  31. #5831
    Nov 2016
    That's the one I got. Someone else mentioned they fashioned a protective sleeve to fit over the race to keep out the dirt and grime..
  32. #5832
    Quote Originally Posted by StumpyandhisBike View Post
    Oh god those bearings must be tiny.
  33. #5833
    Quote Originally Posted by mikkosan View Post
    Do it! I loved my process 111 since it handled so well. I wanted something that would go a bit quicker through rocks and chunk without losing the playful feel. I did not expect to be quicker on my toir on more mellow trails but I was. Still super playful and pedals really well with the seattube angle where it is. I wish the bb was maybe a tad lower but handling is quick with the short cs. I know some people have commented on instabilty at bike park speeds but it's a still a 140mm bike. I never had trouble with it. It's just a super fun bike that likes to pop, pump, and manual
  34. #5834
    Feb 2010
    Quote Originally Posted by danniel1332 View Post
    I am also coming from a Process that was a frame replacement for a Satori. While I loved how responsive the handling was and amazed that a short travel bike never felt overmatched by anything that I can ride, I missed the extra travel on long rides or smashing through rock gardens. I am still sorting out the setup on my Riot, but I can confirm that the handling is similar to Process and find that it really shines on tight technical climbs. If you are looking for more travel the Riot is a good alternative.
    Sent from my SM-G920V using Tapatalk
  35. #5835
    Oct 2015
    Other than the short stays, the higher BB makes changing direction easier.
  36. #5836
    So Iím ordering all my parts for my build and need help on my brake adapters. I will be running Shimano zee front and rear with 180mm rotors. Can anyone give me a link to the adapters I will need for the brakes. Iím running a DVO diamond boost fork. Thanks Iím advance.
  37. #5837
    Jun 2012
    They sure are.
    I wont be running them anymore.
    2017 Canfield Riot
  38. #5838
    Mar 2011
    I have a cool offer on brakes, but the front hose is 76 sm.
    Will it be enough?
    Unfortunately, my frame and fork on the way. I have not opportunely to measure by myself. I am going use 140 mm RS Yari (AtoC 551 mm )
    Oct 2015
    I have a yari. My hose is about 89cm. But hoses aren't too much money if it a good deal
  40. #5840
    Reputation: noosa2's Avatar
    I've seen a few threads where folks have been successful running boost hubs in non boost frames and wondered if anyone has run a 148mm hub on their riot/toir?
  41. #5841
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Yes. They fit. You will need a wider axle.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
  42. #5842
    Quote Originally Posted by hitechredneck View Post
    Itís a great move. I had a Process 111 and moved directly to the Riot. I moved all my parts over with the exception of the Dropper. It was a night and day difference. The Process was very playful but the Riot kicks it up to eleven. The Riot climbs better with a coil with no lockout than the Process did with the lockout. There is so much more chushin for the pushin when the trail gets chunky. Honestly there is no downside. Just pull the trigger.
  44. #5844
    Oct 2015
    Ok, what's the best bash guard that fits the Riot?
  45. #5845
    Any brand work better with the Riot? My bikes have either had RS maxles or whatever the manufactures (Transition and Surly) include with the frame so I'm not to familiar with any of the other 148 x 12mm aftermarket thru axles.
  46. #5846
    1.75 thread pitch and 170-174 length with 2cm of threaded end on the axle is what you are looking for. I posted links to axles off of Universal cycles earlier in this thread if you search for it.
  47. #5847
    Quote Originally Posted by aenema View Post
    Great info - thanks aenema.
  48. #5848
    Mar 2011
    For it is not clear. Is it enough room for rear boost hub? With out any problems with rear brake and additional stresses on the chainline?
  49. #5849
    Quote Originally Posted by q232 View Post
    For it is not clear. Is it enough room for rear boost hub? YES-
    No problems at all. There is no additional stresses on the frame. Go for it.
  50. #5850
    Feb 2016
    Any need to run Shimano Boost specific cranks with the boost rear wheel?
  51. #5851
    I changed nothing but the axle on my setup. Brakes didn't even need adjustment.
  52. #5852
    Feb 2010
    Quote Originally Posted by Cerberus75 View Post
    I like the one I bought from 77designz. Cheap and minimalist. The URL is earlier in this thread from when I asked the same question. Don't forget that you need the old iscg03 version.
  53. #5853
    Getting this technical, anyone have the shock mounting bolt specs?
  54. #5854
    Oct 2015
    Quote Originally Posted by Stu Pidassle View Post
    Thanks, looks perfect.
  55. #5855
    Feb 2016
    Wondering if anyone has tried 27.5 wheels with 2.6 tires on the Riot. Thoughts on the pros and cons?
  56. #5856
    Jun 2012
    Another option that I came across today.
    https://www.universalcycles.com/shop...0&category=361
    Though it weighs twice as much and doesnít look as sleek as the 77. At least you donít have to ship it from Germany.
    2017 Canfield Riot
  57. #5857
    Oct 2015
    I'm with stupid
    Quote Originally Posted by Neck Romancer View Post
    Yes. Did it this fall. Pros lower bottom bracket, cons lower bottom bracket. Was quite the snappy little bike. I liked it quite a bit little trail rocket. Went back to 29er because already have a balance and wanted to put my wheels back on it. If I had a 150mm or 160mm 27.5 fork laying around I would have kept it like that so I don't have to adapt to wheel size change each time I switched bikes.
  59. #5859
    Feb 2016
    what length cranks are you running? Would pedal strikes be really bad running it all the time? I could bump the Diamond up to 150mm and there would finally be clearance for the tire! Fork offset might be an issue though...
  60. #5860
    I'm with stupid
    I was running 170mm cranks and have a 46mm offset pike
  61. #5861
    Oct 2015
    I put the wheels that are on my wife's Process 134 2.4, 2.4 tires, on the Riot, I have a Yari with 51 offset. The BB was just under 13". I took it to a flow trail with a few G outs and jumps. It was a lot of fun, not really any more nervous. I definitely would want the BB higher though.
  62. #5862
    Feb 2016
    Thatís what I was afraid of... Thanks for posting a measurement of the BB! Seems like a 2.6 tire on a wide rim would raise it up but not sure if it would be enough. Thanks!
  63. #5863
    Mar 2015
    Finally found enough time to build it up! Taking it out for a short test spin this afternoon and hopefully will somehow manage to find time later in the week to give it a real ride.
  64. #5864
    Quote Originally Posted by HotDishman View Post
    Dayummmmmmmmm that thing is awesome. Well done.
  65. #5865
    Jan 2013
    Nice build!! Cpolism👍
  66. #5866
    Jun 2016
    Sweet build!
    On a separate note. Is there a difference between the MRP AMG V1 and V2 chain guides? I found a NIB V1 for $50 cad and am thinking I should pick it up. I think the cheapest V2 I've found is at least twice that price. Thoughts?
  67. #5867
    I have 29 x 2.6" Nobby nic tires in the mail and should have them mounted up later this week. Will post up the clearances and bb heights. KOM i29 rims. I'll be curious to see if with the lower pressures you can run, how different the bb height will be once all sagged in. 170mm cranks
  68. #5868
    Oct 2015
    There are a ton of bikes with 330(13")mm BB heigh. You'll be close to that probably.... too low for my taste. 340 (13.4") is about as low as I'd go and how I ride.
  69. #5869
    I'm with stupid
    I rode a 13" bottom bracket bike for years in colorado and utah and loved it! Best all around trail bike I owned.
  70. #5870
    Quote Originally Posted by saskskier View Post
    Sweet build!
    Yeah, the V1 has a much larger guide and it's at a different angle. The V1 didn't fit on my Balance, but I don't know about the Riot.
  71. #5871
    Feb 2005
    I run mine with a 160mm 27.5 fork and 27.5 wheels - 2.5F, 2.4R. Works great in CA. When I rode in Sedona, I liked using the standard 29er setup.
  72. #5872
    Quote Originally Posted by noosa2 View Post
    At $1k I'm definitely tempted and the only item on your list that really matters to me is "flexible". Have folks been having problems with frame flex on the toir?
    I wasn't quick enough to get a new large frame for $1k before they sold out but I was able to pick a demo frame with a new DVO shock. Cannot wait to get it together.
  73. #5873
    Oct 2015
    Quote Originally Posted by jaks View Post
    What's the BB height with your set up?
  74. #5874
    Feb 2005
    It's right at 13", with HA at 66.5deg.
  75. #5875
    Schwalbe 2.6" . 3mm non-drive clearance. 5mm drive. 5+ between front and tire.
    Attached Thumbnails Attached Thumbnails 2015 Canfield Brothers Riot 29er FS-img_3577.jpg
  76. #5876
    Would you give us a little more info about your setup. What rims are you using? Did you go up to a boost rear axle?
  77. #5877
    Dec 2017
    Quote Originally Posted by Crankmiester View Post
    This info is also something I would be very interested in. NN 29x2.6 may be my preferred weapon back and front, so any ride impression would also be much appreciated.
    Do you ride with the same front tyre? If so, what fork and clearance?
  78. #5878
    Apr 2014
    Here is my lady medium frame in 15.2kg
    donator my previous yelliscreamy!
    I hope to get dvo diamond soon
    and change my brakes to zee or saint maybe I will go with 50mm stem and 760mm handlebar now I have 60mm stem and 750 handlebar!
    Dvo topaz makes me happy in every ride...
    Im waiting rear tyre with lower weight and I will go under 15 kilos...
    Im using michelin rockr2 2.35 1.200gr each tyre...
    GOPR0466_1516118209851_high by Darksoul, on Flickr
  79. #5879
    I did mine with 2.6 on a KOM i29 rim. It fits, but flexs under moderate cornering. That being said. it measures 2.55" . Maxxis SHorty 2.5 WT measured a true 2.5 and it was fine. same rim.
  80. #5880
    before you say it, the wheel might be a mm bias to the non-drive, but i am getting rub on both sides under cornering.
  81. #5881
    KOM i29 to P321 hubs. 142x12 stock setup. no axle changes.
  82. #5882
    Fork clearance is fine on the new pike. I have daylight all around. 2.6 on front, find a 2.5 for the back even 2.4. not enough clearance for mud too.
  83. #5883
    Apr 2014
    is there something like a manual with torque specifications for the links I cant find anything!
  84. #5884
    Reputation: maciejas's Avatar
    Dec 2013
    I think there were no specific numbers, however somebody said (down this thread) that due to bearings construction you should not be able to over-tight them. Just go reasonably tight.
    Some riders also reported - and I have experienced that on mine either - that the bolts got loose on the rides. Therefore it's good to make sure they are tighten up before hitting the dirt
  85. #5885
    Apr 2014
    when I took it in my local bike shop said to mechanic to check it and its ok
    but if I want to regrease them I should tighen the link with torque I domt know how much!
    I will send message to Sean...
  86. #5886
    Nov 2016
    Quote Originally Posted by Darksoul View Post
    I too am building a Riot, and according to Canfield, there are no torque specs for any bolts on that frame. "Just hand tighten". Seems like a recipe for disaster. Weird.
  87. #5887
    Oct 2015
    If you clean and grease the threads, everything fits very tightly without worry.
  88. #5888
    The reason you can torque them down is that there are aluminum sleeves between the bearings that the inner race will press together on. Have any of you ever had a moto? Replaced the front bearings on the wheel? There is a sleeve that the axle goes through and that sleeve essentially connects the two bearings together. It is the same with the Riot.
    You simply cannot really over tighten as you will not load the bearings inappropriately (technically you could but not by hand with our normal allen wrenches).
  89. #5889
    Apr 2013
    Just reiterating the advice to make sure they are tight before and after your first few rides. Also, make sure the axle and is fully inserted and pinch bolt is tight.
  90. #5890
    Reputation: Skeeter97's Avatar
    Feb 2012
    So close to pulling the trigger on a closeout Riot frame but I canít shake the feeling Iíd be better off with an EPO. Just moved to the Denver area and havenít had a chance to ride yet so not sure what to expect trail wise. Owned an EPO before and loved it. Will do a few lift assist days over the summer which the Riot would be better for but other than that an EPO would fit my riding style better (I think) Iím more into the fast and flowy stuff than I am the chunky gnar type stuff. But it seems like most people out here are on 130-160 travel full suspension bikes. And to throw a total wrench into things Iíve also got my eye on a Guerilla Gravity trail pistol. Hmmmm
  91. #5891
    I'm with stupid
    I love down in Colorado Springs and have done the hard tail thing for a bit (nimble 9) and have been on a riot for the last 2 years. The riot is worth it. The all of a sudden square edge hits that come at high speed out here get very tiresome and wheel killing as time goes on. Well worth the small price you pay in efficiencie to have some travel in the back. If I was having a hard time deciding between the two I would get a riot and put a shorter stroke shock on it and have a mix of both with around a 125mm poppy rear end riot.
  92. #5892
    Feb 2012
    Where do you like to ride down there? From what Iíve read it sounds like places like Centennial Cone, North table mountain, buffalo creek, etc are more my type of rides. Falcon at the academy sounds cool too. I should also mention I was a bit worried about size. Iím just over 5í10Ē with a 31Ē inch inseam. A medium Riot ďshouldĒ be ok but Iím a bit worried as I typically ride a large
  93. #5893
    I tried mounting Travail Cumberland 29x2.6 but touched driveside chainstay. itís No go.
  94. #5894
    Reputation: jkidd_39's Avatar
    Sep 2012
    Quote Originally Posted by tsurun View Post
    How wide are your rims?
  95. #5895
    Quote Originally Posted by jkidd_39 View Post
    Itís i45mm, Iím going to try narrower rim another day.
  96. #5896
    Sep 2012
    Ok. I just mounted up the Cumberland but had put it on the bike. I'm on a 29mm rim. I believe the Canfield guys recommend a 30-35mm external width rim for plus tires.
  97. #5897
    Good information, thanks.
  98. #5898
    I'm with stupid
    Quote Originally Posted by Skeeter97 View Post
    I ride all over, one of the best kept "secret" of the springs is I have hundreds of miles of trails I ca ride from my door step. From the riding you say you like to do the falcon trail on the academy is a fun one. Also look into cheyenne mountain state park it is pretty XC fast flowy. Red rocks open space as well captain jacks and 666 trail are good ones. For you I would avoid palmer park, ute valley and any trail in monument area. They are all either slow tech stuff or just flat out chunky beat you up trails. I ride them all so the 140mm travel riot works perfect for a daily driver. If you are not going to ride anything but the more XC stuff then a EPO is fine but if you venture away from those the riot will be the best choice. Mine is a large so I cant really help you on test fitting a medium.
  99. #5899
    Feb 2012
    Right on thanks for the info. The more I read the more Iím starting to think a medium is just gonna be too small for me. At this point I may just give it a little time to see if they release a carbon Riot or just pull the trigger on a Trail Pistol
  100. #5900
    Maxxis High Roller 2 2.5" WT x 29 on a WTB KOM i29 rim are a no go.
  1. The NEW Canfield Brothers Nimble 9
    By KillingtonVT in forum 29er Bikes
    Last Post: 04-04-2015, 07:03 PM
  2. Some more Canfield Brothers DJ love....
    By rsullivan in forum Canfield
    Last Post: 11-04-2014, 10:53 AM
  3. 2015 Canfield Jedi or 2015 Trek Session 9.9 650b
    By metalMTB in forum Downhill - Freeride
    Last Post: 08-15-2014, 03:14 PM
  4. New Canfield Brothers Softgoods
    By KillingtonVT in forum Canfield
    Last Post: 10-09-2012, 08:32 PM
  5. Canfield Brothers Canada
    By atlanticrider in forum Canfield
    Last Post: 05-26-2011, 08:10 AM
Members who have read this thread: 234
