Page 1 of 2 12 LastLast
Results 1 to 100 of 119
    Reputation: rsullivan's Avatar
    2014 Canfield Jedi- Post your pictures and build list:
    Now that the 2014 Jedi's have been released. It is time to start showing them off. Got mine today and built it up but since it is dark will wait until tomorrow to post a pic. If you have yours done and ready start posting them up!!!!
    Fresh Pic!!!!
    Build list:
    Frame- Canfield Jedi- Size Large
    Rear Shock- CCDB Coil (550lb) will change to Ti later
    Chain Guide- MRP G3
    Fork- Marzocchi 888 RC3 EVO V.2 - extra stiff spring, Custom Gloss Black
    Wheels- Easton Havoc DH ( for now until I rebuild my Canfield hubs into carbon rims)
    Front Tire-Maxxis HR2 -26x2.4
    Rear Tire-Maxxis Ardent EXO 26x2.4
    Cassette- Sram 1070 12-28
    Seat- Prologo
    Seatpost- Carbon Easton Haven
    Chain- Ultegra 10spd
    Rear Derailluer- Zee
    Shifter- Zee 10spd
    Cranks- Canfield 165mm
    Pedals- Canfield Ultimates
    Headset- Cane Creek Zero Stack -1-1/8
    Bars- RaceFace Altlas 15mm rise
    Stem- RaceFace Direct mount
    Brakes- Hayes Prime Expert
    Rotors- Alligator-203mm F/R
    Grips-LizardSkin Lockon
    I was gonna hold off on the build till I can get a hold of Craig and get a quote on some updates to my v1 888 cartridge (I want to get knobs on it), but decided to do some small stuff, like install some needle bearings in the CCDB's eyelet.
    Just a heads up about the CCDB...seems the eyelet dia isn't like the standard eyelet diameter to use the 1/2" x 1/2" DU bushing. The RWC needle bearing got stuck, along w/ the tool used to install it. I had to Dremel the tool in half to get it out so I can punch out the needle bearing (destroyed in the process...sacrificed to save the shock). This didn't make sense so I tried to put in a standard Fox DU bushing. It too got stuck, and I used the original CCDB DU to get the Fox one out...which I ruined in the process. Once everything was out, I mic'd the eyelet and got 0.58" diameter. Then, I mic'd a RS Monarch Plus damper body I recently replaced which had that now destroyed needle bearing installed in at one point, and got a 0.593" dia. And lastly, I mic'd a X-Fusion Vector HLR coil, the latest shock that same needle bearing was installed in and it had a 0.595".
    I've got a msg into CC asking what's up. Will update when I get info. Until then, don't try to put needle bearings into the CCDB eyelet.
    Edit: Chris from RWC...BEST help ever! Apparently CC has 3 eyelet sizes, 14.7mm (0.58"), 15mm (0.59"), and 16mm (0.63")...WHAT IN THE HOLY LIVING HELL!?
    Fox's spec is 15.02mm (0.591"). Both of my eyelets are 14.7mm (0.58"). So, off to RWC to get it reamed out, $20/end, and CC is okay w/ it and won't void their warranty. Doing both ends so I can use needle bearing standard DUs later.
    2014 Canfield Jedi-  Post your pictures and build list:-p4pb10685951.jpg
    I will update more pics once it's done
    Here is my list:
    Frame Canfield Brothers 2014 Jedi large
    Rear Shock Marzocchi Moto C2R
    Fork Marzocchi 380 C2R2 6.5nm Ti spring
    Headset Cane Creek 110 Series red
    Handlebar Easton Havoc 35 Carbon 780 wide
    Stem Easton Havoc 35 DM
    Grips ODI Rouge
    Brakes Formula T1s
    Shifters Shimano Saint M820
    Rear Derailleur Shimano Saint M820 10spd
    Chainguide MRP G3
    Cranks Canfield Bros 160mm
    Chainrings MRP Bling Ring 36t
    Bottom Bracket Canfield Bros
    Chain KMC X10SL DLC black / red
    Cassette Shimano Ultegra 11-28
    Pedals Canfield Brothers Crampon Ultimate red
    Front Rim ENVE DH
    Rear Rim ENVE DH
    Hubs E-13 LG1+
    Spokes DT Swiss Bladed
    Front Tire Schwalbe Hans Dampf 2.35 SG
    Rear Tire Schwalbe Hans Dampf 2.35 SG
    Saddle Kore T-Rail Torsion
    Seatpost Kore T-Rail Torsion Carbon
    Seatpost Clamp Canfield Bros red
    May 2010
    Quote Originally Posted by rsullivan View Post
    How much do you weight with gear ? How much sag with 550 on the 2014 ?
    Quote Originally Posted by xetal View Post
    I weigh about 220 geared up. Sean Gollub suggested the 550 spring. I have only set up up on the base tune for now. Will start playing with the settings when I can. Just climbing on the bike and feeling it sag it feels like this spring with 4 turns of preload will be fine
    Oh and the fork I replaced the spring to a extra firm to keep it higher in the travel
    May 2010
    Awesome thank you for the reply.
    Mine
    Went the DVO treatment. Build is nearly complete, waiting on front rubber and a new front rotor
    Large with CCDB
    Canfield wheels
    Canfield cranks in 165
    Avid XO/Code hybrid brakes
    Renthal bar
    Gravity stem
    X0 rear mech
    990 cassette
    Maxxis HR2 front and rear when done
    Odi Rogue grips
    weighs just shy of 40 as it sits so should be right on 40 when done. Very pumped to get her out.
    Attached Thumbnails Attached Thumbnails 2014 Canfield Jedi-  Post your pictures and build list:-20140307_223525.jpg
    Sweet... love the green.... looks like a bunch of builds coming with the Bros cranks on them.... was really impressed how they looked and feel. .. great job guys
    Pretty stoked to wake up and see this thread going with build pics today! Scrolling through, not only seeing our new Jedi, but so many sets of our AM/DH Cranks as well is quite rewarding. Thank you all for the support! You guys are the heart of our customer base and we couldn't do it without you guys!
    Can't wait to hear ride reports! Everyone that has had the opportunity to hop on mine has been blown away.
    Speaking of which:
    2014 Canfield Jedi-  Post your pictures and build list:-jedi-full.jpg
    Cody - Stoked to see the first pics of a DVO kit! Sadly, we never had the chance to see one at the office as forks were sent out before the Jedi's landed.
    Ryan - Yeah bro! Loving the custom paint on the 888 Evo! (Not sure why that fork isn't offered in Black)
    Brian - Your build is going to be one of the most blinged out Jedi's this year! Just a note that Brian's baller 380 is the fork we used for our press release photos. Pinkbike and Vital approved!
    Paul - Can't wait to see your new beast!
    Vincent - Welcome to the club!
    Hey Vin..... With pleasure we support the best rider owned company in the business!!!! And as always your Jedi looks killer but......where is Seans????
    Sean's is currently in a box on it's way to Bootleg for the race next weekend. We did something special with Seaner's Jedi for all of his kick a$$ work! I'm sure he'll post pics after the race.
    Cool... can't wait to see it.... pass on to Sean to kill it at Bootleg
    May 2010
    My Jedi made it to Canada. Just have to wait for it to travel all the way to me on the east coast. Once up ill also put pics.
    This thread keep me alive waiting thanks to all of you teasing my eyes.
    My bench is all cleaned up with all my parts lined up. i NEVER was so ready!
    Alright... Got out to Lake Michigan for a couple of shots... Still a little cold on the Shore...lol
    Feb 2006
    xetal, was there duty applied coming across the border? How much? I guess you won't know until it arrives at your door, but can you post up when you find out?
    Thanks.
    May 2010
    Quote Originally Posted by Squidley Diddley View Post
    Thanks.
    Will do. The bike passed the border in Vancouver. I have no idea if i will get taxed for BC or QC, the province i live in. If i get BC taxes only, you can split the bill in half.
    If your concern about them you can ask Sean to get the bike shipped to the closest UPS store across the border and manage your way back.
    I will let you know what taxes i get charged. What province do you live in ?
    Vincent
    May 2010
    Question here for previous owners. Is it any good to protect the frame finish with 3M tape or heli tape ?
    I had one bike in the past that was anodized and forgot how tough the finish was.
    I already have the tape but dont know if it's worth putting it on.
    Thank you
    Vincent
    DT guard
    Spent a couple of hours modifying Cytoe's DT guard w/ a heat gun an da Dremel tool...prettied it up and made it much more form-fitting. Looking at 3M Dual Lock to hold it on the frame...
    2014 Canfield Jedi-  Post your pictures and build list:-jedi-dt-guard-01.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-jedi-dt-guard-02.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-jedi-dt-guard-03.jpg
    Looking good there...Pau11y
    Aug 2010
    I had some 3m carbon fiber tape on the underside of my Jedi for a season. Looks cool too.
    Aug 2013
    I'm interested in a jedi and it seems like everyone is going for larges. I'm 5'9" would the large fit me or stick with a medium?
    Aug 2010
    If I was your height I would definitely ride a Medium.....
    1/8" thick cutting board stuff...HDPE I believe.
    Wait till you see the tape job I'm putting on it tonight...2 layers of hilo tape on the rest of the DT, and then the stays w/ 3M 2155 rubber tape.
    Aug 2013
    Quote Originally Posted by meSSican View Post
    That's what I thought. There's a perfectly specd Jedi for sale in my area but it's a large
    ******ed or Branded??
    Reputation: doodooboi's Avatar
    Spam Alert:
    I have a '13 Large Jedi frame and shock for sale, which is basically this years' medium. I'm 5'10" and it fits me perfect, was a bit cramped on the '11-'12 medium, hence the bump to large on the '13. Pm if interested.
    Quote Originally Posted by Fullcoilmojo View Post
    .Hoog just texted me and said it's "Surface area to G2 tangential force vector ratio optimization. "
    Aug 2013
    What about the 2013 and earlier models? Would a large fit?
    Yes, the '13 large will fit you perfect. The '13 large is the '14 medium due to the frame refinements.
    Like I mentioned my '13 frame is for sale with shock, it's the raw frame with black links. Pm if you have any further questions.
    Quote Originally Posted by doodooboi View Post
    The 2014 sizes are are half way between the gen 2's as we lengthened the TT's by 12.5mm's.
    At 5'9" we would recommend a medium for sure on the new bike.
    As Vin said on the '14 you'd want to be on a medium. On the previous ('11, '12, and '13) you could do either. A large would work for anyone 5'8"-6'2" so you'd be right on the cusp. Shorten your handlebars and a large could work for you.
    I also can spam this up as I have a large '13 full build for sale as well. PM for details.
    Feb 2006
    Hi Vincent, I live in BC. Using the Canada Border Services website duty and taxes estimator, Duty and Taxes Estimator, it looks like there is 13% duty tacked on after taxes. I am not sure if the CSBA website is up to date, because for BC it applies provincial sales tax as well, but there is no PST on bikes in BC. For a frame+fork package, if the CSBA percentages are right, then there would be about $900 added for me in BC, and $1400 for you in QC. Yikes!
    Mike
    May 2010
    Mike
    Thanks for the info. Let's just hope that your calculation is wrong
    Reputation: BTTR's Avatar
    Jun 2012
    Oh man i'm jealous of this thread!
    Congrats to all the 14 owners
    May 2010
    Thanks.
    Got the frameset yesterday. It aint bad at all. I just payed the Quebec sale taxe TVQ. Aint bad at all.
    DO IT !
    Vincent
    I can't believe this thread has had zero action since last weekend! I'd LOVE to see some more NON GARAGE build pics! Great work Ryan on getting out there in the cold last weekend to give us some RAD shots.
    First two solid outside shots gets posted to our Facebook page. And any good shots posted will be featured in our 2014 Jedi build gallery on our website.
    Get 'er dun!
    May 2010
    Garage shot it will be for me this week end after the build is completed. We just got snowed big time once more..... The new Jedi will be seeking for some action in May !
    Quote Originally Posted by KillingtonVT View Post
    Get 'er dun!
    Mmm, delicious bait!!
    I still have some more details to sort out but it's pretty much ready to ride. Sorry about the thumb...
    2014 Canfield Jedi-  Post your pictures and build list:-p4pb10708827.jpg
    Quote Originally Posted by TheRage43 View Post
    Wow! That's all I have to say!
    Absolutely sick!!!!!!!! Looks a little warmer than my pics...... lol... Lake Michigan is very cold at this time. ..
    May 2010
    Here is mine. Finished building her late but heh still a shot of her beauty
    I will take better shots later on when i get back from work !
    2014 Canfield Jedi-  Post your pictures and build list:-20140313_204513.jpg
    Build list:
    Rear Shock- CCDB Coil 500lbs Ti
    Chain Guide- MRP G3
    Fork- Fox 40 Titanium Green Sping
    Wheels- DT440 Hubs on Mavic Ex823 Rims UST Setup (stealthed out)
    Front Tire- Schwalbe Magic Mary Wire DH casing 2.35
    Rear Tire- Schwalbe Magic Mary Wire DH casing 2.35
    Cassette- Shimano ultegra 9700 custom 7 speed setup
    Seat- SDG Ti Fly
    Seatpost- Thomson
    Chain- KMC X10SL
    Rear Derailluer- Saint M820
    Shifter- Saint M820 I-spec
    Cranks- Truvativ Descendant 165mm
    Pedals- Funn
    Bars- Spank Spike 777 (Stealthed out)
    Stem- Production Privéé 548 50mm
    Brakes- Shimano Saint M820
    Rotors- Shimano RT86
    Grips- ESI
    Weight 39.06lbs
    BTW for those wondering how much the frame weight it is for a Large 9.5LBS (shockless) with shock bolts.
    Re: 2014 Canfield Jedi- Post your pictures and build list:
    So much bike porn!
    Sent from my MyTouch 4G Slide using Tapatalk
    Reputation: katsooba's Avatar
    Nov 2008
    2014 Canfield Jedi-  Post your pictures and build list:-img-20140314-wa0035.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-img-20140314-wa0041.jpg
    A build coming from Israel
    i will update soon with more pictures!
    2014 Jedi w\ red links size M
    CCDB coil
    Marzocchi 380
    Easton Carbon 35mm bar
    Easton 35mm Stem
    SDG I-beam saddle + seat
    Canfield Crampon Ultimate pedals
    Industry 9 hubs laced on Stan FLOW EX rims
    Shimano saint brakes
    more updates will follow as build finishes
    17' Canfield Jedi 27.5" - The fast just got faster!
    15' Canfield Balance - The go to guy of the bike world!
    Katsooba, are you running a zero stack bottom cup headset? What's the thinking behind that...is what you have on hand or to steepen up the front end a touch?
    Nov 2008
    Hi Pau11y,
    the zero stack buttom cup is just what we had in hand, if that bothers the rider, i'de suggest him to switch to an external bottom cup.
    personally i dont see why that would be an issue
    with the GEO numbers on the brothers website stating that its a 63.3 HA with internal headset, i think it would be awesome.
    no need to go UCI crazy with the 62.7
    Thank you guys for posting more build pics! I'll start sharing these next week. Hope you guys have a great weekend, I'll leave you with this banger of Seaner ripping through some Bootleg GNAR on his custom polished Jedi:
    2014 Canfield Jedi-  Post your pictures and build list:-seaner.jpg
    Killer bike there ....Sean!!!!! Kill it this weekend
    May 2010
    Sean has some secret Jedi lines ! CB podium for sure !
    There are some beautiful pics in this thread boys!! I will have some more pics to add soon. EVERYONE'S build's has been so drool-worthy so far! Come on spring weather!! I LOVE THIS BIKE!!!
    My build is completed and up and running. But it's not ready for the "pretty" shot yet. Needs some black stanchions (not just for the color), and some black thin pedals (this IS for the color ). Ninja Jedi when done!
    Canfield Brothers
    Reputation: flymybike's Avatar
    I took these a couple weeks ago in Virgin Utah at the old Red Bull site. Lorin is one of the coolest kids I know and sends it way bigger than most anyone I know on his 2014 Canfield Jedi.
    Attached Thumbnails Attached Thumbnails 2014 Canfield Jedi-  Post your pictures and build list:-loren-1.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-img_8038.jpg
    http://www.canfieldbrothers.com/frames
    Building bikes that make you smile!
    www.mtbparks.com
    All Bike Park, All the time.
    May 2012
    First time Jedi owner. 2014 went together perfect. CB wheelset and cranks to top it off. Took it for a test spin locally and also bed the brakes in. Can't wait to go gravity with this shredzilla monster bike.
    Props to Vin and the whole CB crew for outstanding craftsmanship, build advice and tips!
    Really hope to make it to whistler this September!
    Attached Thumbnails Attached Thumbnails 2014 Canfield Jedi-  Post your pictures and build list:-imageuploadedbytapatalk1397505593.820789.jpg
    I got more bikes than skills, son!
    Reputation: Turbocharged's Avatar
    Finally got mine put together...click the pictures...
    Build Specs:
    2014 Jedi (large) frame w/ CCDB
    2011 Manitou Dorado Pro
    Canfield Brothers DH cranks w/ 36T MRP BlingRing
    Canfield Brothers Crampon Ultimate pedals
    Renthal Fatbar handlebars
    Renthal Integra stem
    Stans ZTR Flow EX rims on Hope Pro2 Evo hubs
    Maxxis Minion DHF ST and DHR II tires
    Shimano Saint M820 brakes
    Shimano Saint M820 shifter
    Shimano Zee M640 DH derailleur
    Shimano Ultegra CS6700 11-28 cassette
    Shimano XT chain
    Cane Creek 110 headset
    Thomson Elite seatpost
    SDG Ti-Fly saddle
    Total weight: 38.7 lbs
    More Pictures Here
    2014 Canfield Jedi - 2015 Canfield Balance - 2012 Canfield DJ
    May 2010
    Updated picture of my sled !!!
    Ready to rock.
    The GEO of this bike is amazing. I feel like i could destroy everything with it.
    Attached Thumbnails Attached Thumbnails 2014 Canfield Jedi-  Post your pictures and build list:-10265420_1504014643072245_2585524712635358983_o.jpg
    Canfield Brothers
    You can! ; )
    www.mtbparks.com
    Reputation: roxtar's Avatar
    2014 Canfield Jedi-  Post your pictures and build list:-dscn4163.jpg2014 Canfield Jedi-  Post your pictures and build list:-dscn4164.jpg2014 Canfield Jedi-  Post your pictures and build list:-dscn4165.jpg2014 Canfield Jedi-  Post your pictures and build list:-dscn4166.jpg2014 Canfield Jedi-  Post your pictures and build list:-dscn4167.jpg
    2014 Jedi
    40 Float
    Saint drivetrain & brakes
    Canfield Bros cranks
    Hadley/Spank Spike wheels
    Democracy is two wolves and a sheep voting on what's for dinner.
    Liberty is a well armed sheep, contesting the vote.
    May 2010
    Slick ride bro. Did you ride it yet ? Impressions ?
    Not yet.
    Angel Fire opens next weekend but hoping to get some shuttle runs here at Pajarito this week. New Mexico DH Championship is here on June 7.
    May 2010
    It will be my first day on the Jedi tomorrow at Bromont. Can't wait to Monster truck the gnar with my beast.
    May 2014
    This is a sweet thread! I'm just getting started on a Yelli Screamy build, very pumped! Will update with pictures as things start to come together!
    Cheers!
    Quote Originally Posted by roxtar View Post
    Not yet.
    Incredible.
    The Jedi took everything Angel Fire had to throw at it and laughed. It consistently made up for stupid line choices. I'm generally not comfortable in the air but the Jedi is so stable it had me looking for opportunities to put space between my tires and the earth. I even loved Candyland, AF's jump run. Some credit has to go to the new 40 Float. It's incredibly plush while also being stable.
    May 2010
    What a day it was at Bromont riding the JEDI. That bike is stable and fast. The suspension design really works in all situations. I was hucking, bombing, monster trucking, jumping with a smile. As my first JEDI i can really say the bikes lives up to the expectations i got. This one is a Keeper.
    May 2010
    Here is my Jedi suspension in action. Litle unedited clip of mid #20 at Bromont
    2014 Canfield Jedi action Video - Pinkbike
    Aug 2010
    Awesome....side note, how do you like those knee/shin guards?
    May 2010
    Hahaha good question. I just noticed i was so excited to ride that i put them on the wrong leg !!! Aside from that that are the best pad i ever had. I tried quite a bunch and these are the best confortable protection money can buy. I bailed few times and they stay put and do their job. The top padded par also work good for hablebar strikes
    Im 6'1" 210lbs and needed XL.
    Vince
    Right, so I just sent back my Woodie from the '11 frame to get resized. But after seeing your vid, I dont' think that shock will work in that tunnel at full compression. Thanks for taking that vid, it'll save me a couple of hundred bucks!
    May 2010
    Quote Originally Posted by Pau11y View Post
    Glad it could help. My setup is with the CCDB and a 500LBS ti coil. I dont see much clearance left once the shock start doing it's magic.
    Sorry man.
  67. #67
    Sorry man.
    Thanks for the details! Yeah, looks like I'll have to stick w/ the CCDB...it's torture I tell ya! HAH!
    Hey xetal, what was the tune on your CCDB...the published base tune or did you change things up? I'm mainly curious if you've added or reduced any setting...possibly increased your compressions and reduced your rebounds?
  68. #68
    May 2010
    Good question mate i indeed changed one setting. I have the base tune posted on the Brothers web site. I did take off two click of high speed rebound. It was a tad to slow for my taste.
    The compression so far seems spot on. I can just bomb down trails. Places i use to go around are now just history, they are getting monster trucked by the JEDI.
    Did you ride the new bike a bit ?
  69. #69
    Nope, not yet. I'm waiting to pop her cherry when the lifts open up. I'm trail riding right now to get strong.
    Sean just msg'd me that my Emerald is en route. Getting SO FRIGGIN' excited for this season to start. But, our (Colorado) mountains are still snow capped! :/
  70. #70
    Reputation: stepneo's Avatar
    Dec 2010
    New Jedi Owners,
    Is anyone running a shock other than the CCDB Coil? Or, a shock with a Ti spring on the 2014 Jedi? I'm just about done with my build & will post it up once it's done.
    Quote Originally Posted by stepneo View Post
    New Jedi Owners,
    I've got a Ti coil on my CCDB...
    Craig at Avalanche has my Woodie and he's telling me w/ a steel spring a Woodie fit a '13 but not a Ti coil. So I might have a go w/ the Woodie using a steel coil in the '14.
  72. #72
    Dec 2010
    Yeah, i spoke to Craig earlier today, who just completed a Woodie for my 2014 Jedi with a steel spring. I transferred most of the parts from my Sinister R9 to the Jedi, and also tested the Avy DHS for spacing on the Jedi. (which is similar to the Woodie, but runs the DHS remote res for the R9). Short story is, it's pretty tight, but, looks like the steel spring will be ok when the Jedi's travel is compressed 100%. ~7mm gap or so on both sides and top, when measuring with a caliper, between the spring and frame through the shock slot. That, however, would make it too tight for a 450 lb Ti Coil which is typically a larger gauge and wider diameter. The 56mm diameter steel Avy spring on my DHS seems ok. I also tested the spacing with a Fox DHX 5.0 tuned by Suspension Experts in NC, with a 53 diameter steel spring, which seemed ok. Most of the Jedi builds i've seen so far are running the CCDB. I've been running Avy since 2001 on all my rigs, so, i'm looking to make the Woodie work on the Jedi.
  73. #73
    New Jedi Owners,
    Manitou Revox Pro with a 450lb Manitou ti coil on mine
  74. #74
    New Jedi Owners,
    I've got a Marz Moto C2R with a 550 Ti from Tisprings.com
    Fits fine
  75. #75
    Dec 2010
    Do you guys happen to know the diameter of the Ti Springs you have on your Marz & also the Manitou? Typically 36.5mm or 38mm.
    Thanks.
  76. #76
    May 2010
    do you guys happen to know the diameter of the ti springs you have on your marz & also the manitou? Typically 36.5mm or 38mm.
    Thanks.
    1.43"id or 36.5mm
  77. #77
    Thanks.
    Manitou, CCDB, and a few others share the 1.45" or 36.5mm. Marz and Fox use a 1.36" ID. Rock shox and the Ava woodie use a 1.5".
    My Ti spring is the 1.43" so I have some spacers I put on to stop any moving around the spring may want to do.
  78. #78
    Dec 2010
    Cool. Thanks for the info. Avy Woodie is on its way. Hope to have the build complete by the end of the week.
  79. #79
    Is it new or used/resized? If used/resized, how long did you have to wait?
  80. #80
    Dec 2010
    I went with a new Woodie for the Jedi as opposed to getting the DHS rebuilt. Ordered the Woodie May 9th. It's due to arrive today.
  81. #81
    My resize and retune of a Woodie is still about a month out. I'd be curious of your impression on the tune. Do you know if he did anything special? BTW, what's your rider weight and what spring weight did Craig suggest you use?
  82. #82
    Dec 2010
    I'm ~195 lbs. (~205+ with gear). The Avy DHS i had was tuned for the R9 with a 500 lbs spring. I had been running that DHS for years. The new Woodie is tuned specifically for the 2014 Jedi with a 450 lbs spring. (450 lbs was what Craig recommended). I've been running a Woodie w/Ti Spring & Fox 36 Avy Cartridge on my Knolly Chilcotin trail bike, and have been very happy.
    2014 Canfield Jedi-  Post your pictures and build list:-p4pb9677140.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-p4pb9244397.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-p4pb9677136.jpg
  83. #83
    Aug 2010
    Size Large
    Classic Cramps
    DVO Emerald
    CCDB
    Crank Bros Sage wheelset
    Desendant Cranks
    Saint M820 Rear Derailleur, Shifter and Brakes w/xt 203 rots
    Havoc Bar
    Twenty6 stem
    Ready to shready!!
  84. #84
    Murdered out enough...
    ...and traces of red
    39 lbs as it sits.
    14 1/8" BB height
    ~61.5* HTA
    9spd, limited to 8 using X0 shiftie to Zee rear mech, Dura Ace 11-27 cluster, and 36T ring.
    Found some XTR Trail lever/MC for a deal and made a set of XTR/Saint brakes w/ Goodridge hoses.
    400lbs Ti sprg and 70psi on the Emerald.
    The Havoc 35 stuff look quite proportional w/ that fork, no?
    Had some decals/stickers left over from the '13 Jedi, and decided to redo the Emerald's CTA badging...
    2014 Canfield Jedi-  Post your pictures and build list:-p4pb11046125.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-p4pb11046121.jpg
    Upgrades left would be a Saint rear mech and maybe a pair of black Crampon Ultimates...later...but good enough to hit Trestle next wknd as it sits
  85. #85
    I am looking for used downhill bike and am wondering about sizing. I am just over 5'11". I found a medium 2013 Jedi that I am going to take a look at but, after reading some posts here, sounds like it might be a bit small for me. Any thoughts?
  86. #86
    Aug 2013
    I'm 5'9" and a large fits me perfectly
  87. #87
    Nov 2008
    hey guys,
    any way to get design overlays for sizing between the 12\13 jedi and the 14?
    could help making size choices easier i think
  88. #88
    Quote Originally Posted by katsooba View Post
    hey guys,
    Would this help?
    http://ep1.pinkbike.org/p4pb10442500/p4pb10442500.jpg
  89. #89
    Dec 2010
    Ready to shred.
    2014 Canfield Jedi-  Post your pictures and build list:-20140611_193530.jpg
    Jedi - step's Bike Check - Vital MTB
    2014 Jedi Black/Black Large
    Avalanche Woodie
    Fox 40 Avalanche Cart
    Chris King Headset
    Race Face Carbon SIXC 35
    Race Face Atlas 35
    ODI Rogue Grips
    Hayes Prime Pro
    Shimano Zee Shifter
    Shimano Zee Derailleur
    Shimano Zee 165mm
    SRAM 10sp chain
    SRAM 11-26T 10sp cass
    Canfield Crampon Ultimate Pedals
    Halo SAS hoops
    Wheelsmith Spokes/Nips
    Hadley Hubs
    Maxxis Minion DHF front/rear
    SDG Saddle
    Thompson Seatpost
  90. #90
    So, am I nuts for liking the way the medium felt being 5 '11"? No way would I want a bike this size for all mountain riding but dh, it might be ok.
  91. #91
    Aug 2013
    I say if it feels right, it is right 😁
  92. #92
    Aug 2010
    I am just under 6' and 31" inseam and was told I was on the cusp of the L and M. So with my '12 Jedi I went with a L and never even thought about it. I would rather err on the larger side as I like to plow more than I like the air. Granted I have never had an issue with jumping so I think the L was a perfect fit for me. I stuck with a L for the '14 Jedi for the same reasons.
  93. #93
    May 2012
    I am 6'1", 32" Inseam and ride a large 14 Jedi. Spot on for me. That said I have seen guys taller than me on other brands in a medium. Before I got the 14 Jedi I demoed a fury and a trek in mediums and it felt way to tight in the cockpit.
    Ha! I said cockpit!
  94. #94
    Thanks for the sizing responses. Just realized I took this thread a little OT. Have a good weekend everyone.
  95. #95
    Lance, I don't know what you did to tweak the old design to arrive at the '14, but that voodoo is pretty impressive! 4 runs down Trestle and the speed just kept getting faster and faster and the bike just performed better and better w/ each increment of speed!
    Base tune is pretty spot-on on the CCDB. I'm 197 kitted up and on a 400lbs Ti spring, 4.5 turns of preload w/ RWC needle bearing hardware and Ti-Springs.com linear thrust bearing on the spring seat. Sag is at 7/8", or ~29%. Paired w/ an Emerald at ~23% sag, the bike is pretty damn neutral coming off of even really lippy kickers! 800mm bar pulls me over the front end and even w/ tires at 40psi, traction was pretty unreal w/ the der Kaisers!
    And no, the DVO is NOT a noodle. Base tune for the Emerald is completely open, and it was still amazing!
  96. #96
    Yeah Paul... Glad you are stoked!!!
  97. #97
    May 2010
    I am looking to improve my FOX 40 settings. I got a descent set yet but feels i should ask around to see what people are running.
    So fox 40 owners wanna share their tune please ?
    Nov 2008
    hey guys,
    i see everyone here getting a large 2014 Jedi,
    comming from a 2013 Large Jedi it always seemed too long for me, and fixed that with a 35 or 40 mm intergrated stems,
    i am 6' and 178 lbs, am i crazy to think the Med 2014 is my fit?
    still didnt wrap my head around the sizing, but the large 2014 just looks loooong
  99. #99
    Canfield Brothers
    The sizing went 1/2 size larger this year. I'm 6' and I'm on a medium but I love the jumps and like to keep the bike a little smaller for the playfulness. Chris is also 6' and he's on a large. Better stability at speed for racer types.
    www.mtbparks.com
  100. #100
    Jan 2005
    2014 Jedi Medium
    I'm 5'11'' and it fits me perfect
    Medium frame
    SIXC 35 bars
    Easton Havoc direct mount stem
    Chris King Inset headset
    Fox 40 Float
    CCDB Shock
    XT Shifter
    Canfield 160 mm cranks w/34t bling ring & MRP Bash/Guide
    Canfield Magnesium Pedals
    SRAM Chain PC991
    Zee rear derailleur FR one
    Shimano 11-36 Cassette (have some uphill pedaling here and there)
    Canfield DH wheelset
    Hope V4 brakes 203mm rotors
    Chromag seat
    Race face seat post
    Schwalbe Big Betty 2.4 tires FR casing
    39 Pounds
    2014 Canfield Jedi-  Post your pictures and build list:-jedi.jpg
    2014 Canfield Jedi-  Post your pictures and build list:-img_2817.jpg
  1. canfield jedi
    By ddfuji in forum Downhill - Freeride
    Last Post: 07-19-2014, 08:27 PM
  2. 2014 Canfield Brothers Jedi
    By KillingtonVT in forum Downhill - Freeride
    Last Post: 03-03-2014, 09:50 PM
  3. Replies: 41
    Last Post: 03-03-2014, 08:47 AM
  4. 2011 Canfield Jedi
    By ciscolangot in forum Canfield
    Last Post: 01-11-2012, 12:19 PM
  5. canfield jedi
    By ddfuji in forum Colorado - Front Range
    Last Post: 05-28-2011, 12:54 AM
