FAT BIKES
WINTER APPAREL
TRAINERS
Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 101 to 125 of 154
  1. #101
    Ride 'Til Your Knees Hurt
    Reputation: cycljunkie's Avatar
    Re: 2014 Canfield Brothers Nimble 9
    Quote Originally Posted by djembe975 View Post
    How many of you are getting seat post slippage on the 2014 frames? I'm building up a chrome and wondering if it's just with the chrome.
    My buddy's is chrome.
    Sent from my Samsung Galaxy S3
    Can you hear me now?
  2. #102
    Quote Originally Posted by cycljunkie View Post
    He's having slippage problems as well?
  3. #103
    Not after putting in a shim.
  4. #104
    Where do you get those shims? Also, I'm using a Chromag clamp do you think that will remedy slipping issues?
  5. #105
    I think the best shim approach is to cut a section of beer can. I think any decent clamp should be fine. Just figure out how much shim you need to make the post stationary.
  6. #106
    Apr 2013
    my seat post slippage problem seems to have ceased: I took the post out and clamp off, squeezed a lot more fibre grip down the ST, put some more on the post and worked it up and down, reassembled. no slipping on about 40km riding yesterday, let's hope it's fixed.
    @djembe975 mine is a chrome, though I don't see why frame finish would be an issue in this problem
    attached gratuitous "colourful shiny logo" pic
    Attached Thumbnails Attached Thumbnails 2014 Canfield Brothers Nimble 9-canfield_logo.jpg
  7. #107
    Do you think a good clamp like the Chromag I have will solve the problem?
  8. #108
    Apr 2013
    sorry I don't know. my clamp is Thompson (the bolt rounds out easily!). I'm riding again tonight, I'll update later if the post moves. If not, that's 2 rides so I think I'm done.
  9. #109
    Reputation: tomcraw's Avatar
    I just got mine built up, I also have the thomson clamp. I've only ridden on the street yesterday dialing in the drivetrain and brakes. Should get a full ride in Wednesday. Waiting on some new ESI chunky's.
  10. #110
    A couple pics:
    2014 Canfield Brothers Nimble 9-201407a7_02989.jpg2014 Canfield Brothers Nimble 9-201407a7_02998.jpg
  11. #111
    First ride yesterday, leisurely 5 miles to dial in my cockpit.
    I really like the geometry. I was able to manual off a very small ledge, something I could never do with my MCR. Didn't have any issue keeping the front down on a short climb, but it isn't very steep. Definitely faster acceleration and way more nimble in switchbacks.
    I moved to 60mm stem with my 685mm bars and the front is too twitchy for me, especially at speed. Don't really want to go back to my 90mm stem, so thinking of ordering the Enve 730mm carbon bars.
    Final build:
    Large chrome Nimble 9
    2.4 Ardent front and rear on Stan's Flow
    1x10 XT drivetrain
    SLX m660 cranks
    Wolftooth 32T front ring
    MRP chain guide
    Avid BB7 brakes (old, definitely want to upgrade)
    Chris King headset
    Fox F32 100mm fork (2014)
    Easton EC70 carbon bars 685mm
    cheap 60mm race face stem while I figure out cockpit
    Thomson elite seatpost with thomson clamp
    WTB rocket seat
    ESI chunky grips
  12. #112
    Reputation: jmiah's Avatar
    These seem awesome! They do seem heavy though. Anyone noticing any issues with weight. 6.5 lbs seems like a lot for a medium frame, even steel. I currently ride a steel Salsa El Mariachi set up single speed.
  13. #113
    Apr 2013
    It doesn't ride heavy to me. The Yelli is 2 pounds lighter if you are concerned about weight and can deal with the alu ride.
  14. #114
    Apr 2013
    Anyone had any issues with an expanded 10 speed cassette? I've put a Hope T Rex 40T expander at the back of my cassette (and taken out the 17T) - the rear arm of the M786 XT mech is close enough to the cassette that in some shifts it obstructs the chain from shifting (in particular from 28T to 24T).
    Anyone have any knowledge of this?
    This pic shows the chain touching the RM after the shift has been clicked to upshift. It's not jammed, I can shift 2 up then 2 back if I have to, but at the point on the cycle where the tooth is trying to throw the chain outwards, the link is touching the RM.
    Attached Thumbnails Attached Thumbnails 2014 Canfield Brothers Nimble 9-doesn_work.jpg
  15. #115
    Quote Originally Posted by ghetto View Post
    I think you need to buy a longer b-screw
  16. #116
    Apr 2013
    extended b-screw already fitted
  17. #117
    West Chester, PA
    I'd grind some clearance into the derail with a dremel. There's plenty of meat there, won't hurt anything.
  18. #118
    After 2nd ride realized that the headset had seated another mm, tightened that up and the twitchy steering disappeared, or by sometime in my third ride I just got everything dialed in. Loving the bike.
  19. #119
    Apr 2013
    I goofed and left my rear axle behind in a car park, it's not there now. Bugger, as we say over here.
    Could someone confirm what I need is this, in 135mm width: RockShox Rear Maxle Lite (Updated) | Chain Reaction Cycles
    Canfield Brothers
    Reputation: KillingtonVT's Avatar
    Correct, the 135x12 is the Maxle you'll need on the 2014 N9. We also have these in stock and can help you out with pricing as it's a replacement.
    Cheers!
  21. #121
    Apr 2013
    thx for that, am in UK so probably easier to get from a local supplier this time.
  22. #122
    Apr 2013
    Anyone reckon it's OK to run the N9 SS, chain stays slammed very short without the tensioner bolt nut in place (the bolts are in and tight, but if I add the nut I'm going to have to push the sliders back, add a chain link and a bunch more chain stay length)?
    I guess the principle risk is loosing a bolt on the trails.
    (Gearing is 32:18 with a chain that's a bit stretched).
  23. #123
    Canfield Brothers
    Reputation: flymybike's Avatar
    If your dropouts are slammed forward, there is no where for it to go because it always slips forward. I say go for it.
    http://www.canfieldbrothers.com/frames
    Building bikes that make you smile!
    www.mtbparks.com
    All Bike Park, All the time.
  24. #124
    Apr 2013
    sure, they're not actually 100% slammed, the screws are still applying a little tension, though not enough to get the nut in there.
    anyway I'll give it a try and keep an eye on it.
  25. #125
    Reputation: jkidd_39's Avatar
    Sep 2012
    Anyone out there running anything bigger than a 160mm rotor in the rear?
    I got a 180mm rotor at the moment and i'm trying to find an adapter to make it work.
    I think I found one that could work. It's a Avid 203mm adapter
  1. Slack Nimble
    By atamayo in forum Canfield
    Last Post: 03-14-2014, 01:24 PM
  2. A Nimble 9 too?
    By elroyj in forum 29er Bikes
    Last Post: 04-19-2013, 12:34 PM
  3. Should I have gotten an xl Nimble 9?
    By WVJon75 in forum All Mountain
    Last Post: 10-04-2012, 02:56 PM
  4. My Nimble 9
    By Click Click Boom in forum Canfield
    Last Post: 08-14-2012, 09:57 AM
  5. Nimble 9
    By dubthang in forum Singlespeed
    Last Post: 08-04-2011, 02:51 PM
Follow MTBR on Facebook
