Results 1 to 5 of 5
    2012 one rear spring weight
    I have a cane creek double barrel on the rear and like both the 450 and 500 springs I have with a rider weight of 178 lb
    What are you guys using ?
    I weigh 180 without gear and use a 450lb spring. Great results so far!
    I get full travel a lot with the 450 spring and bottom easily even with the high speed compression raised .
    Great for flowy - semi rough DH .
    500 pedals better and I get full travel on most jumps as well as it making the front end track a little better , better for trail riding .
    Not the purpose of the bike but have only 1 bike .
    Reputation: savo's Avatar
    I'm building my One, and I'm 180 lb without gear too.
    Do you ride your Ones in 7" mode or 8" mode? That definetly makes a difference in the spring weight choice.
    I'll start with a 500lb in 8" mode I think, mostly AM riding.
    Savo- 500 sounds like a heavy spring for a 180lb rider. Typically a 500# is for someone in the 210-220 range. A 450# would be a better place to start.
    Cheers!
  1. Need Help With CCDB Spring Weight.
    By Master Slater in forum Downhill - Freeride
    Last Post: 08-13-2013, 12:08 PM
  2. spring weight for sx trail, help
    By adamantane in forum Downhill - Freeride
    Last Post: 01-27-2013, 06:52 PM
  3. M9 spring weight question....
    By SHIVER ME TIMBERS in forum Intense
    Last Post: 05-04-2011, 05:06 PM
  4. converting rear hub, rear spring weight
    By ows in forum Downhill - Freeride
    Last Post: 04-17-2011, 02:45 AM
  5. rear shock size for wfo and spring weight question?
    By david8613 in forum 29er Bikes
    Last Post: 02-15-2011, 07:13 AM
