Page 1 of 9 12345 ... LastLast
Results 1 to 50 of 416
    Reputation: V.P.'s Avatar
    2011 Canfield Bros "THE ONE" info
    "The ONE" info is a bit scattered, so I thought ill collect all info about the 2011 model we got so far in this post, so its more easy to obtain.
    PRICE MSRP:
    $2,500.00 USD including an unknown shock. (Price in the EU is 1999 euro, without shock)
    AVAILABLE FRAME COLORS:
    Anodized Black or Titanium Grey
    AVAILABLE LINK COLORS:
    Black, White, Blue and Red (decals follow the link color)
    WEIGHT:
    10 lbs with Coil (4,55kg)
    Warranty:
    2 years
    Confirmed Shock options: FOX (coil and air), RockShox (coil and air), X-Fusion, Elka, Cane Creek. A No-Shock-Option will be available as well.
    FRAME
    "ONE" Suspension
    7005 Aluminum
    Internally ribbed Chainstays
    68mm BB shell
    135x12mm through axle
    1.5" Headtube
    20mm seal bearings
    Replaceable rear derailleur hanger
    6.5"-7.5" with 2.5" shock / 7"-8" with 2.75 shock (165mm-190mm with 216x63mm shock / 177mm-203mm with 222x70mm shock)
    Shock bushing sizes - 22x8mm both sides
    Front derailleur - Direct mount
    Seat post - 31.6mm
    Seat clamp - 35mm
    International standard disk brake mount
    Standard ISCG tabs
    Headtube - 1.5
    About running this bike with a 160mm fork:
    "It's a great way to run this bike. A 160 on the front will drop the HA to 65.6 degrees. You can get a as steep as 67 degree HA with a CC Angle set. I'm planning to build mine with a Fox 180 talas so I can drop to 140mm climbing and have a 66 HA, but I'll get a Angleset too so I can play with it a bit. A 36 160mm Talas would be a good way to build it if your not using a Angleset.
    Seat tube angle will steep when you drop front travel giving it a better climbing position. The seat angle steepens about a half degree per inch shorter fork. The BB will be around 13.5.
    " - Flymybike
    Whats the shock mount kit size for the frame? - I guess thats the only missing info.
    Anyway, some pics to complement this thread:
    Reputation: cSquared's Avatar
    Just raced the ONE-
    setup at 38.5 lbs
    Took 2nd in SS DH on that bad boy-
    pit
    pit is online now
    What about the warranty on this frame, here, in France ?
    Thanks,
    Steve.
    The ONE still shipping in Mid-March?
    Looking forward to it.
    Quote Originally Posted by cSquared
    Just raced the ONE-
    setup at 38.5 lbs
    Quote Originally Posted by pit
    Thanks,
    Steve.
    We just change to a 2 year this year--
    The shock bushing sizes- 22x8mm both sides-
    Same on the Jedi
    thanks, ill update the first post.
    pit
    pit is online now
    Ok....with the shorter length of shock and my 160 mm fork in the front, it would be fine i think.....beautiful frame.
    thanks you very much.
    About the shock options; will there be a RS Vivid air, Monarch, Vivid coil option?
    Reputation: Dude!'s Avatar
    Out of curiosity...
    Why does the ONE have longer chainstays and a longer corresponding wheelbase than the Jedi? Is the ONE suppose to be snappier being an AM/FR bike, whereas the Jedi is more of a DH bike? It is just counter intuitive in my brain, but this isn't saying too much (ie my brain).
    How is the suspension different for the ONE and the Jedi. The Jedi has 2" rear wheel travel. I am assuming the ONE doesn't, what does this result in as far as performance?
    Both bikes look amazing! Nice job!
    Purveyor of Trail Tales!
    Aug 2005
    +1
    Hey Folks,
    Lovely frame! Bump for info!!
    Thanks,
    Michael
    If you can't keep the rubber side down......at least smile for the camera!
    ventanakaz
    Reputation: 1962's Avatar
    +2
    Quote Originally Posted by Dude!
    Out of curiosity...
    ...+2 on that, I would like to know too maybe the canfields can answer that Q.
    i need to ride more. building jumps takes to much time...my other hobby is kicking the crap outta my home built mook jong.
    (international price is adjusted in the first post)
    POLAND (Europe)
    Reputation: Pawel's Avatar
    Quote Originally Posted by V.P.
    Any news about shock?
    No, they have been tight lipped these last days.
    Canfield Brothers
    Reputation: flymybike's Avatar
    Yes, RS will be a option. We can get most any shock you want, availability dependant. It just has to be a 8.75 x 2.75 or a 8.75 x 2.5.
    Canfield Brothers
    Out of curiosity...
    Chainstay length is based off of wheel path. So the Jedi is very rearward so it has to start short to feel normal whereas the One is a more traditional wheel path so it can start at a length that is stable and shorten when compressed to make it turn quicker.
    The Jedi has 3 shock mounts that control the progression rate. It does effect travel but only 0.2" per adjustment. It's meant as a means to precisely tune the bike per race track. Linear (top hole) for rough tracks to very progressive (bottom hole) for tracks with more burms and jumps.
    The One has a travel adjust (notice it's on the link, not the main frame) that changes from 7" to 8" with a 2.75 stroke and 6.5 to 7.5" with a 2.5 stroke shock.
    Updated first post, with EU pricing(again), and shock options.
    I have put my PRE-ORDER on the ONE!! WHOOO!!! Looking forward to get the frame!! : ) Sofar canfieldbrothers.eu have been a joy to work with, and they reply their emails fast.
    Now all I can do is wait. Apparently Chris is in TW right now assembling the frames.
    ban
    ban is online now
    is there any EU pricing quote for the Jedi '11??
    Quote Originally Posted by ban
    No but im quite sure canfieldbrothers.eu knows the price if you mail them.
    I have seen the 2011 jedi on a norwegian website, and the price tag was 3.241 euro, if you convert the currency to euro's
    http://www.extremebikes.no/catalog/p...roducts_id=263
    7MGTE
    Reputation: supramk388's Avatar
    Just raced the ONE-
    setup at 38.5 lbs
    Sure was a fun race to watch and you killed it that day on the One!
    I can not wait as well The new frames are pimp!
    Working hard to get the 2011s done
    Quote Originally Posted by supramk388
    Awesome, I ordered a black frame, with white links, and a monarch plus, I think its going to look sick!
    is that a ti-grey ONE with red links I spot on the table?
    More ONE info here, and a vid as well:
    http://www.sicklines.com/2011/03/03/...-brothers-one/
    POLAND (Europe)
    Hi guys, have a question about front derailleur: should I take top or down swing ?
    Quote Originally Posted by Pawel
    I just helped Lance install the front derailler on the One. This is what I would use.
    BTI Part Number SH-40739.
    The new D-Mount derailler is top and bottom swing.
    Lance drew in enough room in the link to adjust for a tripple chain ring.
    I think most people will use a single or double.
    Vaughn
    7MGTE
    One more...
    Bad A$$ your One should be sweet. I was not going to buy a One till next year but the more I look at them I want one. I am going to order a small One after my Jedi is done
    Yep How about black and red?
    POLAND (Europe)
    Looks cool, but I ordered titanium gray with white links
    7MGTE
    Very nice white is tight! I got white coming on my 2011 Jedi and I am not sure what color I am going with for my One. I just saw a video from Chris on the 2011 frames and man the white One links look killer.
    Maybe Chris or Lance will post video
    Cool, got pics of the entire frame?
    POLAND (Europe)
    Please show me this film or pics guys
    7MGTE
    PM sent!!! Enjoy
    POLAND (Europe)
    PM sent!!! Enjoy
    thanks man
    PM sent!!! Enjoy
    Could you send me one as well?
    7MGTE
    Do you FB?
    thanks man
    No prob man hope you liked it.
    Yep, PM sent.
    For any others just check out this FB page:
    http://www.facebook.com/pages/Canfie...63956136971393
    ******ed or Branded??
    Reputation: doodooboi's Avatar
    Alright, so far we know there was at least 44 Jedi's making its way here over the pond. Now any news or updates to One frames hitting our shores? I am officially anxious about getting both of my bikes.
    I already know that I am probably not one of the 44 that's getting their jedi, but hopefully sooner than later it will be in my hands. Hence the super anxiousness of getting the One cause I can definitely live with that till the jedi gets here! All my parts are sitting here wondering why they are on the shop floor!!!! ahhaha
    Lbs
    spoke with the Brothers yesterday, the One is 4 - 5 weeks away.
    Quote Originally Posted by clarkgriswald
    I spoke with canfieldbrothers.eu, and my ONE frame might be here next week if shipment goes according to plan!
    Stoked for you! But I hope my frame will be here just as soon.
    Quote Originally Posted by doodooboi
    what did you order, and what build are you going for?
    Its here:
    Reputation: kameraguy's Avatar
    A picture of a box is not nearly as interesting as a photo of the contents inside
    : ) stay tuned, ill post more on my blog ASAP
    POLAND (Europe)
    I admire your patience, first what I will do is open the box in the hurry and check the content :-)
    well I did peak a little ; )
    Well I originally ordered ablack frame with black links. But after seeing the new red stuff I asked if I could change to red. I think my request has pushed my frame back a little but I hope not. I'm planning on a full on AM build with parts to handle dh/fr. So basically a heavy build. Its going to literally be my One bike. I have come to accept that a heavy pedal bike will pay off more when I am grinning ear to ear on the descents.
    Updated the blog with pics and details, go check it out:
    Bike looks great but surely that BB heigh is verging on the impractical?
    Considering it's a bike made to pedal, I can't see myself pedalling through much with it that low....
