Results 1 to 2 of 2
Thread: Spice mods
    Jun 2005
    Spice mods
    Has anyone ever messed with the linkage under the top bar of a spice to get a bit more travel? I was looking at my Slayer beside my wife's spice and wondering if you could put the linkage from a slayer onto a spice.
    Reputation: Gazz's Avatar
    Quote Originally Posted by Manard
    Never tried this, although I had a chance to buy the rocker links from a Slayer back when I had a Spice. Given that you have a Slayer kicking around, it might be worth experimenting. Swap the links, leave the spring off the shock and move rear triangle through it's travel by hand to make sure it doesn't contact anything.
    Be aware that you would probably be increasing the leverage ratio on the shock, increasing the risk that you might blow it. Also, I would be concerned with how the geometry might get messed up. If the rear end gets jacked up, you would need a longer fork to retain the same angles.
  1. Stance Kingpin mods
    By aschir01 in forum Downhill - Freeride
    Last Post: 06-24-2005, 12:06 PM
  2. Interpreting PUSH mods...
    By jrm in forum Turner
    Last Post: 02-25-2005, 11:38 AM
  3. 03 S-Works Epic Parts and Mods: Rear end
    By Mo-Tay in forum Specialized
    Last Post: 01-15-2005, 08:23 AM
  4. Ghetto Mods (#2431.7 in a series): Z1 Dropoff project
    By zedro in forum Downhill - Freeride
    Last Post: 07-24-2004, 07:50 PM
  5. mods to SSV damper system
    By dirtpaws in forum Shocks and Suspension
    Last Post: 02-05-2004, 01:39 PM
