Results 1 to 6 of 6
Thread: slayer stem
    Reputation: fishercat's Avatar
    slayer stem
    does anyone know what size stem comes on a stock 2004 16.5" slayer? is it 100mm or 110mm? also what size seatpost? thanks
    keep the shiny side up!
    Reputation: Phat_Head's Avatar
    26.8 seatpost but don't know the stem length
    Group Hug Participant
    Reputation: <sL4yEr>RuLz's Avatar
    Pushed Float ???'s
    Quote Originally Posted by Phat_Head
    Phat_Head, you were on the pushed Float RL right? I'm thinking next week I'll send mine out. Curious though, how does this affect your ability to lift "wheelie" your front tire up when you step on it? Also, how would you compare the ride, Pushed versus "locked-out" RL? Smoother, or do you bounce around?
    it's a float r. the shock has no affect on wheelie. as far as locking out vs. push, the shock still works so it doesn't bounce. when you get out of the saddle to hammer it does move a little since you have all that weight being moved around.i think the best comparison would be when you are out of the saddle stomping with the push'ed shock it moves about as much as it would on a seated climb with a normal shock. make sense?
    Totally makes sense! Thanks. One more question if I may? What sort of "Riding Style" did you specify when ordering? Obviously, I can see the difference between XC and Freeriding. But what about trail riding, aggressive trail riding versus XC?
    well i didn't specify. i work within a mile of the company so i just dropped it off. i don't remember him asking me what my riding style was.
  1. steerer tube vs stem vs bar wt
    By drc in forum Weight Weenies
    Last Post: 07-23-2004, 08:03 PM
  2. Need a HS stem quickly!
    By trukweaz in forum Cannondale
    Last Post: 06-05-2004, 10:32 AM
  3. quill-type stem questions
    By chuffer in forum Singlespeed
    Last Post: 04-29-2004, 06:17 AM
  4. Rim cutting the valve stem
    By MrXC in forum Wheels and Tires
    Last Post: 04-27-2004, 06:18 AM
  5. Worth it?
    By crank in forum Tooltime
    Last Post: 03-29-2004, 10:14 PM
