Results 1 to 5 of 5
Thread: Slayer Bushings
    Group Hug Participant
    Reputation: <sL4yEr>RuLz's Avatar
    New question here. Slayer Bushings
    Anyone had their Slayer bushings replaced yet? I'm noticing slight play on my BB pivot and linkage plates on my '02.
    Official Chocolate Fountain Spokesman
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    I dont own one but
    my friend dos and I looked at his and the main pivot by the bb looks like it has a cartraige bearing not a bushing. So it might just need to be properly tourqued and the hardware greased but the outher pivots are definatly bushings. They are simple to change out and should proably be done every couple of years to keep things good and snug. You might want to check the bushings in the rear shock eyelets as well.
    Thanks, I was planning on having everything done at a LBS, since I can't order directly from RM. The BB pivot is definitely bigger than the bushings, so that might be the case. Yeah, I haven't touched any bushing since owning the bike. I'm betting that replacing everything will solidify the bike nicely.
    Quote Originally Posted by Johnny Hair Boy
    LBS Manager
    It will feel brand new
    If you change all the bushings including the ones in the rear shock eyelets all at once the bike or at least the rear linkage will feel like new again.
    Good luck, the main pivot also has a grease port you can squirt some new grease in there every couple of mounths to keep the main pivot running smooth for years to come.
    livin' large
    Reputation: canadian-clydesdale's Avatar
    Check the bushing at the rear end of the shock, It was a major pain for me not long ago, if you change the aluminum reducers for a stainless T-sleeve (availble from FOX) it tightens the whole rig up (and change the bush at the same time). As for the bearings I've had no Issues andI'm going on a year and half of (ab)use.
    Also periodically check to make sure all the bolts are snugged up, I've had a couple slowly loosen up over time.
    it tied the room together man!
  1. Where to get shock bushings?
    By racer234 in forum Shocks and Suspension
    Last Post: 03-25-2005, 10:35 PM
  2. heckler vs. slayer 50
    By reddog98 in forum Bike and Frame discussion
    Last Post: 01-13-2005, 06:57 PM
  3. heckler v. slayer 50
    By reddog98 in forum Santa Cruz
    Last Post: 01-03-2005, 10:22 PM
  4. drilling out rear shock bushings...
    By volvo13 in forum Shocks and Suspension
    Last Post: 10-19-2004, 11:02 PM
  5. Slayer 70 versus Slayer 03
    By Braumeister in forum Rocky Mountain
    Last Post: 06-23-2004, 01:54 AM
