Results 1 to 2 of 2
    hyprlterdr
    replacement bearing for brodie devo
    I bought a used brodie devo, I believe its a 2004 and I took it a part to paint the frame, when I went to put it back together the big bearing that bolts the rear end to the main frame. The 5mm bolt that goes through it broke inside the opposite side. Is there a way to get a replacement bearing?
    Thanks,
    Nick West
    Apr 2005
    You mean you broke the bolt - not the bearing, right? ...two separate things you're talking about there. Anyway call or email Brodie about it and they'll hook you up. Their CS is awesome. They'll give you bearing sizes too so you can find those cheap on your own.
