Results 1 to 3 of 3
    customized
    Sep 2003
    Rear shock for Instinct
    I am about to rebuild my Cloud Nine but I am wondering if there is a better shock out there for my bike. The C9 has always seemed inconsistant. Never leaked, just never could get a constant good feeling from it.
    I am looking a swinger 3 way but I hear it's not as good for low leverage designs. My other choices are to get a Float pushed or even a RP3.
    Any input would be appreciated.
    Louis
    ups and downs
    RP3 is a sweet and VERY light shock
    I'd give the RP3 a shot, it is very light and the Pro Pedal damping works very well.
    chips & bier
    Reputation: eric's Avatar
    I'm using a DT Swiss SSD
    It's a little more linear through the most part of its travel, so the bike feels as if it's getting more travel. I'm actually not sure wether that's a bad or a good thing...I don't think the bike feels unbalanced with an 80 mm fork (FYI, my Instinct is '01).
    The DT SSD 210L only has lockout and a rebound adjustment, so it's a pretty simple shock. Hoewever, the big issue with the Float I had was the rear reducers would wear at an alarming rate. The DT has spherical eyelets, which seem to fare better.
    I'm not sure at all how well a swinger would work. I do know Cube - a German manufacturer - makes an Element-like design with largely similar linkage dimensions but a Hort link. They deliver some bikes with Swingers.
    I think an important aspect of your choice should be how much you want to eliminate bobbing and sacrifice small-bump response. I think the RP3 has several different ProPedal settings, which - I'm guessing - is the easy way out because it allows you to turn off the PP function at will.
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Replies: 45
    Last Post: 10-12-2004, 12:04 PM
  4. K2 Noleen Mega Air rear shock
    By joejm14 in forum Shocks and Suspension
    Last Post: 02-29-2004, 08:44 AM
