Results 1 to 7 of 7
    My dogs are killin me
    Reputation: LLrider's Avatar
    Sep 2004
    Need help with Handjob...
    Man, I have been searching forever and can't find any posts that state the exact weight of the Cove Handjob XC frame. I can find whole bike build weights but have no idea how much it weighs.
    Can anyone tell me the weight?
    resident crackpot
    Reputation: loonyOne's Avatar
    It may take a few weeks to get a response, but try emailing Cove. I'm sure they'd be glad to tell you, especially if you were to give a competitor's frame's weight...I just bought a DeKerf, but the Handjob was in the top three on my list. Good luck.
    Sep 2004
    I did that but that's exactly what i'm trying to avoid.
    There's got to be some Handjob XC owners on this forum that have weighed the frame alone.... Anyone??
    born again
    Reputation: gearz's Avatar
    Weight Weenies lists the '03 19inch at 2088 grams..
    Quote Originally Posted by LLrider
    ...if you already haven't seen this---http://weightweenies.starbike.com/li...hardtailframes
    I have no idea what a current one would weigh. I don't know if I could ride a "Handjob" but that's just me. Love that name.........
    Classic Cascade Rides
    Original quote by Pinchflat:
    The faster you go the shorter the ride!
    HandJob weight
    Hey,
    I worked at the cove this summer. I believe the 05 Handjob weighed between 4.4-4.6 lbs depending on what size. For 2006 the down tube is being beefed up a bit so the weight will increase accordingly.
    Hope this helps,
    Craig.
    Sep 2004
    It helps a bunch!! Thanks for the information.
    Wow, that's not bad at all for a steel frame. I have a Mountain Cycle Rumble that I thought is pretty light at 5 pounds. I've just been aching to get a Cove Handjob XC frame.
    All I need is to save my pennies now...Thanks!
    Heads up Flyboy!!
    Reputation: mountaingoatepics's Avatar
    my '05 Handjob weighed in at 4.5 lb. frame only. its built up around 27-28 lbs with a Manitou 130mm Minute, Sun Singletrack rims, RaceFace Atlas Cranks. Its handled about 1200 miles of abuse this year with rides that usually last 20-30 miles and some sick singletrack in the Mountains on the East Coast of the US.
    Jeremy
