Results 1 to 2 of 2
    New question here. Need help- '03 or '04 etsx?
    I am in the market for an ETSX. Money is a concern and I see some '03 ETSX's (frames) available for roughly $1,000. I know there are some differences in hardware between '03 and '04 frames but I am not really sure what they are and more importantly, I am not sure what they would mean to me... were there problems with the '03 rear link and hardware?
    I'm not a racer, but I do weigh 210lb.s so would the Rad Tubing on the '03 be stronger and better for me?
    I already have a Fox Vanilla C/O Pro Pedal rear shock that will fit the frame (I would just need to get a stiffer spring) so the difference between the older float and newer AVA is not a deal breaker...
    Any help in perspective would be greatly appreciated!
    Hey Molasses,
    There is a structural difference between the 03 and 04 ETSX frames. There are a couple of previous ETSX threads where some of the other guys detail the differences. Sorry, I can't recall those differences exactly, but I think the rear end of the 04 frames is beefier, but don't quote me on that. If you have a quick browse, you'll probably come across the info.
    I had the same choice between an 03 ETSX-30 and an 04 ETSX-30. However, being around the end-of-financial-year when I was buying, the bike shop did a better deal on the 04 than the 03 model, so I went for the 04. Either way, I don't think you'll be unhappy with the ETSX!
    Cheers,
    tt
  1. 03 or 04 Brain? Should I be suspicious?
    By Odie in forum Specialized
    Last Post: 06-06-2004, 11:19 AM
  2. 03 vs 04 S works Epic frames
    By WOY in forum Specialized
    Last Post: 04-13-2004, 12:37 PM
  3. '03 Specailized Epic or '04 Stumpjumper Comp?
    By Theadict in forum Bike and Frame discussion
    Last Post: 03-30-2004, 12:48 AM
  4. '03 vs. '04 Iron Horse Hollowpoints, Changes
    By Speedub.Nate in forum Bike and Frame discussion
    Last Post: 03-22-2004, 11:02 AM
  5. could 03 stamped be 04 forks?
    By greenchops in forum Shocks and Suspension
    Last Post: 03-17-2004, 06:13 PM
