Results 1 to 6 of 6
    Sep 2004
    ETSX70: confused about front derailleur- help!
    MY ETSX70 frame nears full assembly. I have a XTR front derailleur (top pull), which fits nicely. I am confused about the cable routing from the shifter. The cable seems to slide across the frame, just above the derailleur, on the pivet bracket that supports the rear frame assembly. Am I routing the cable incorrectly (if so, please explain the correct way), or am I stuck with this "feature"?
    Thanks,
    Almost assembled....
    born again
    Reputation: gearz's Avatar
    I'm afraid you're stuck
    Quote Originally Posted by etsx70
    Thanks,
    Thats the way it is. Both my original 2002.5 ETSX and my 2004 ETSX replacement frame both featured the cable rub on the bracket just above the derailleur. It really doesn't seem to affect the shifting and it's not cutting into the frame so functionally I don't think its a big deal. It does look kind of weak though and they probably could have done something different but I guess RM wasn't that concerned about it. Enjoy the ride!
    Classic Cascade Rides
    Original quote by Pinchflat:
    The faster you go the shorter the ride!
    Sep 2004
    Quote Originally Posted by gearz
    Ok that clears it up. Thanks much for the reply! Stay tuned for images as soon as my tires arrive.
    Almost Assembled
    Jag
    Jag is offline
    Reputation: Jag's Avatar
    I put a carbon sticker there....
    Thanks,
    so the cable doesn't rub on the pivot bracket. It seems quite odd for this to happen on such a high-end frame.
    When I'm sitting on my bike the cable doesn't actually touch... only when I'm not on it. I agree is does seem a little weird but it doesn't effect it at all.
    Sep 2004
    Quote Originally Posted by Cynan
    When I installed the cable, I put a short section of 1/8" teflon tubing over the cable, just above the derailleur. The cable slides smoothly inside the tubing, rather than against the frame pivot. Not sure if it makes much of a difference, but it looks better! Thanks for all the replies!!!!!!!!!!!!
  1. broken front derailleur question
    By jman0war in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2004, 01:43 AM
  2. Tracer front derailleur noise
    By I need training wheels in forum Intense
    Last Post: 09-20-2004, 06:43 PM
  3. Shimano XT or XTR front derailleur?
    By stumpy2324 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2004, 11:52 PM
  4. XT761 front derailleur installation question
    By pumba in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-13-2004, 08:46 AM
  5. front derailleur adjustment question
    By KSC in forum Tooltime
    Last Post: 03-19-2004, 07:27 AM
