Results 1 to 9 of 9
    ETSX-70 Rear suspension
    I have read nothing but rave reviews on the ETSX frame. However, I have also read about it's flexin' rear end. Was this addressed on the 2004 model? What exactly is this flex being spoke of and how does it effect the bike?
    Doug
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    I demo'd a 2003 ETSX50 for a short ride and didn't feel the flex the reviews mention.
    They did change the way the rear swingarm is bolted to the linkage for 04 though.
    Quote Originally Posted by CraigH
    Yep...sounds right...I spoke with them today about it and you are correct. Thanks for the feedback though
    Reputation: FireDog46's Avatar
    the ETSX phantom flex issue...
    Quote Originally Posted by k0zu
    I own and have ridden an ETSX since 2002. I have never experienced any flex. However
    I weigh only 165 lbs. Apparently the ones experiencing flex were heavy weights. The
    upper rear pivots have since been changed to a clevis style connection, increasing
    lateral rigidity.
    michael
    keep the shiny side up!
    Reputation: Phat_Head's Avatar
    part of the reason the flew was reported by mag reviews were that they had a pre-production bike. the production bikes all had beefier links so that's why you don't hear of owners complaining about flex.
    My LBS is willing the last pc of the 03 ETSX70 at a very good price. So should I take it. Is there a lot of flex? I like the RAD oval tubing, looks very strong. Is this bike good for climbing? I have an element 70, very difficult to climb and bobs alot.
    Thanks.
    how much of a discount?
    How well does it climb? The 2003 ETSX-70 won the TransAlp Challenge.
    Does it flex? Not for me and a lot of others.
    Does it bob? Get your pressures and rebound dialed in and you won't notice any.
    2003 vs 2004.
    2003 has a stronger front triangle...different tubing and a 100mm fork.
    2004 stiffer rear upper linkage...uses clevis pivot points and a propedal shock + 125mm fork.
    In the end it's up to you to fully test ride it but I'd go for a discounted 2003.
    michael
    Quote Originally Posted by evolution_gsr
    Thanks.
    your element should be a better climber than the etsx. maybe you should look into getting the element set-up right.
    I never noticed flex when I demo'ed a 03 XTS-50.
  1. Trade-offs in anti-squat suspension theory
    By derby in forum Bike and Frame discussion
    Last Post: 05-24-2010, 03:46 PM
  2. Replies: 14
    Last Post: 05-25-2005, 03:59 PM
  3. '04 Stumpjumper FSR thoughts (long)
    By chrisjohn78 in forum Specialized
    Last Post: 04-15-2004, 03:26 PM
  4. rear der. for two ring set up?
    By FishMan473 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-17-2004, 12:14 PM
  5. Horst Link FSR vs. FSR lookalike / Any Noticeable Differences?
    By Keith in forum Bike and Frame discussion
    Last Post: 01-19-2004, 11:38 PM
