    etsx 50 headset leakage
    I have a 2003 etsx 50 and a lot of black grease seems to be coming out of the headset. maybe not a lot, but enough to wipe off a good amount every once and awhile.
    is this a problem?
    thanks
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    I dont think so
    Quote Originally Posted by garychanchan
    is this a problem?
    thanks
    It sounds to me like the head set was packed with to much grease so it is squezing out the excess. If you head set dos'nt feel sloppy then I would'nt worry about it.
    loose headset?
    okay, i tried grabbing the front brake and moved the bike back and forth and it feels like the headset, or something is loose. I tried tightening the screw on top of the stem, but it didnt make a difference.... unless i need to crank that screw?
    any thoughts?
    thanks for any help.
    headset vs. shock legs?
    (if anyone is still reading this..)
    the "play" or knocking i feel when grabbing the front brake and moving back and forth might be the "play" in the shock legs vs a loose headset,.. anyone concur?
    do other ETSX owners experience this? (the knocking when grabbing front brake and moving back and forth)
  1. Replies: 14
    Last Post: 05-25-2005, 03:59 PM
  2. Replies: 4
    Last Post: 07-11-2004, 04:11 PM
  3. Opinions on greasing headset cups
    By Lab Worker in forum Tooltime
    Last Post: 06-14-2004, 07:28 PM
  4. ETSX versus....
    By jawry in forum Rocky Mountain
    Last Post: 06-03-2004, 03:58 PM
  5. How to change an intergrated headset for a regular?
    By BanzaiRider in forum General Discussion
    Last Post: 05-19-2004, 10:06 PM
