Results 1 to 7 of 7
    Dekerf hardtail sizing
    Hi,
    I was wondering if there were any Dekerf riders out there around 5ft 7 that could tell me what size frames they ride.
    I'm looking to get an order in for an SST, but I am unsure if I should get a 16" or a 17.5" frame.
    I usually ride a 16", but Dekerf top tube lengths seem to be quite short.
    My nearest Dekerf dealer is a plane ride away, so I can't just go and have a sit on one.
    Thanks for looking
    Dec 2005
    Hi Andy,
    what bike do you ride in 16"?
    5ft7 is 173cm?
    Robert
    Hi Robert,
    Yeah, 5ft 7 is 173cm.
    My Kona Unit is a 16" with a 22.5" eff top tube and my Potts is also a 16" with a 23" eff top tube.
    I previously had a Litespeed Obed which was also a 16" with a 22.5 eff top tube.
    I've found that a 90mm stem is comfy on the bikes with the 22.5" top tube, but run an 80mm with a 23" top tube.
    I like to have a lot of standover which is why I usually go for a 16" frame.
    Thanks, Andy
    Dec 2005
    Hi Andy,
    you are looking for a 29ner?
    Robert
    Hi Robert,
    No, it's going to have 26" wheels.
    I've just sorted out a 16" SST frame, but with a a 22.5" top tube, which will be spot on.
    Chris is a great guy and he's going to build me up a 16" frame with a bit more length.
    Dec 2005
    Hi Andy,
    Chris makes great bikes. I got 5 of them
    The Unit is a 29ner with a 22.4 TT and usually you take a 26" 1" bigger for equal stand over. If you keep this in mind, DK does long TT, longer than most other Manufactures.
    But you already sorted thing out
    Wish you a lot of fun with the DK and would be happy to see some pictures!
    Robert
    I should have it by the end of July, so I'll get some pics up then
    I was really torn between which frame size to get, but a 16" with a 410mm Thomson post, it will give me just over 130mm of post in the frame; with approx 25 - 30mm below the seat tube / top tube junction.
